    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 13.6k Views 3 Watching
      sdetweil @FSAHD
      @FSAHD i just pushed a fix to package.json and a new postinstall script
      git pull to get the updates…(watch out that it doesn’t overwrite your code)
      then the postinstall script from the module folder
      ./postinstall
      it will be called by npm install as well…
      • mumblebajM
        @sdetweil I think it is possible with axios. Let me have a look at it. Will fork module from you and see what I can do and push a PR if it works.
          sdetweil @mumblebaj
          @mumblebaj said in Can anyone revive AviationWX, PilotWX, or TAF:
          really don’t want axios… better to get native fetch working…
          thats what I was trying. and you can use node xxx.js to test it without MM in the way…
          its ‘possible’. just all the different ‘it works like this’ didn’t work.
          there are two fetches in the node helper… one gets the gz file
          and one gets an xml file… that one should be easy, but I didn’t want to mix in the same code path
          mumblebajM 2 Replies Last reply
          • mumblebajM
            @sdetweil The below code works fine. Tested it. Having issues with my system at the moment and can’t make the changes. Can you incorporate?
            async function fetchData(metarUrl, airports) {
              try {
                const response = await axios.get(metarUrl, {
                  responseType: 'arraybuffer', // ensure response is treated as binary
                  headers: {
                    'Accept-Encoding': 'gzip', // request gzip compression
                // Unzip the gzip response
                const unzippedData = zlib.gunzipSync(response.data).toString();
                let json_string = convert.toJson(unzippedData);
                var json = JSON.parse(json_string);
                var metarData = json.response.data.METAR;
                var airportData = new Object();
                var airports = payload.airportList.split(",").map(function (airport) {
                    airport = airport.trim();
                    return (airport.length < 4) ? "K" + airport : airport;
                airports.forEach(function (airport) {
                    metarData.forEach(function (metar) {
                        if (airport === metar.station_id) {
                            if (this.debug)
                                console.log("METAR data found for " + airport);
                            airportData[airport] = metar;
                            return; // check next airport in list
                    console.log(metarData)
              } catch (error) {
                console.error('Error fetching data:', error);
            • mumblebajM
              @sdetweil I can fix the other fetch as well no issues. Give me a few on this one.
              • mumblebajM
                @sdetweil Both calls working.
                try {
                            headers: {
                                    if (this.debug)
                            // console.log(metarData)
                    } catch (error) {
                    const checktype = { "Airspace_Flow_List":"Airspace_Flow", "Ground_Delay_List": "Ground_Delay", "Arrival_Departure_Delay_List": "Delay","Airport_Closure_List":"Airport" }
                    try {
                        const response = await axios.get(FAAUrl);
                        // Your further processing
                        let json_string =
                            //convert.toJson(test_data)     swap comments to use test FAA data
                            convert.toJson(response.data.toString());
                        if (this.debug)
                            console.log("json faa=" + json_string);
                        const faa_data = JSON.parse(json_string);
                        if (!Array.isArray(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)) {
                            // save the current entry
                            const x = faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type
                            //  init as an array
                            faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type = []
                            // add the element into the array
                            faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.push(x)
                        // loop thru the delay types
                        faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.forEach(t => {
                            if (t.name !== "Airspace Flow Programs") {
                                // for each the  there are two major keys, name and the list for that type
                                // get the key of the list
                                const keyname = Object.keys(t)[1]
                                // remove the "_list"  part for passing to front end
                                const key = keyname.split('_').slice(0, -1).join('_')
                                if (this.debug)
                                    console.log("key data=" + JSON.stringify(t[keyname][checktype[keyname]]) + "keyname=" + keyname + " key=" + checktype[keyname] + "\n")
                                if (!Array.isArray(t[keyname][checktype[keyname]])) {
                                    const x = t[keyname][checktype[keyname]]
                                    t[keyname][checktype[keyname]] = []
                                    t[keyname][checktype[keyname]].push(x)
                                } else {
                                    console.log("checkytype=" + checktype[keyname])
                                if (this.debug)
                                    console.log("data=" + Object.keys(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)[0] + " data=" + JSON.stringify(t) + " keyname=" + keyname + " key=" + key + " last part=" + JSON.stringify(t[keyname][key]) + "\n")
                                // look thru all the aaffected airports for this record type
                                t[keyname][checktype[keyname]].forEach(airport_record => {
                                    // if the airport is one the user requested
                                    if (airports.includes('K' + airport_record.ARPT)) {
                                        if (airportData['K' + airport_record.ARPT]['FAA'] == undefined)
                                            airportData['K' + airport_record.ARPT]['FAA'] = {}
                                        // save this data record
                                        airportData['K' + airport_record.ARPT]['FAA'][key] = airport_record
                        // Emitting data to Socket
                        //self.sendSocketNotification("WX_RESULT", airportData);
                    } catch (error) {
                        console.error('Error fetching FAA data:', error);
                  sdetweil @mumblebaj
                  @mumblebaj thx. but there is a way to not have to use zlib. I just haven’t found any that work
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @sdetweil If you want to use fetch you can do the first call as follows.
                    try {
                        const response = await fetch(metarUrl, {
                          headers: {
                            'Accept-Encoding': 'gzip', // Request gzip compression
                        if (!response.ok) {
                          throw new Error(`HTTP error! Status: ${response.status}`);
                        // Read response body as buffer
                        const buffer = await response.buffer();
                        // Manually decompress gzip data
                        const zlib = require('zlib');
                        const decompressedData = zlib.gunzipSync(buffer).toString();
                    You could use pako.
                    const decompressedData = pako.inflate(buffer, { to: 'string' });
                      sdetweil @mumblebaj
                      @mumblebaj but… you are not supposed to have to do either
                      • mumblebajM
                        @sdetweil I have not seen another way. Sorry…:man_facepalming:
                        F 1 Reply Last reply
                        • F
                          FSAHD @mumblebaj
                          @mumblebaj @sdetweil fwiw, and I don’t know if this would be any easier for the situation.
                          There is a site called avwx.rest
                          (I believe the pilot wx all was using that source)
                          It’s an API built solely for pilot data
                          You do need a key but maybe the data will be easier to pull?
                          https://avwx.docs.apiary.io/#
                          S 2 Replies Last reply
                            sdetweil @FSAHD
                            @FSAHD I might use that for pilot.
                            we are just talking about using more current support , so the module lasts longer
                            • mumblebajM
                              @sdetweil There is a simple api call from the site to get the metar data whicg might be simpler to use.
                              https://aviationweather.gov/api/data/metar?ids=KMCI%2CKORD%2CKBOS&format=json&taf=true&hours=1&bbox=-26.139%2C28.246&date=2024-03-10T23%3A44%3A22Z
                                sdetweil @FSAHD
                                @mumblebaj
                                thanks to your help I fixed the code to use the airport specific request which returns json and not gzip…
                                @FSAHD the output changed metar output changed again… sorry
                                i updated the sample text again
                                so git pull, and npm install
                                • F
                                  FSAHD @sdetweil
                                  @sdetweil No worries. I really appreciate both of you alls help. Ill spend as much time I need on my end to get it up and going!
                                  @mumblebaj thanks for adding your .02 cents to help this move forward.
                                  Im new to this MM forum so I am not sure how to go about this but I would love to either get you both a cup of coffee or just donate to your efforts as a thank you!
                                  S mumblebajM 2 Replies Last reply
                                    sdetweil @FSAHD
                                    @FSAHD I don’t accept donations.
                                    I do this for fun and learning, so I’m already rewarded.
                                    • mumblebajM
                                      mumblebaj Module Developer @FSAHD
                                      @FSAHD No donations required. We love this project and this forum. :winking_face:
