    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 12.6k Views 3 Watching
    • F Offline
      FSAHD @sdetweil
      @sdetweil I tried that after I cloned the git into the modules folder.
      I ended up getting this error.
      I also don’t remember if I used your script for this instance of mm or if I installed manually if that makes any difference
        sdetweil @FSAHD
        @FSAHD ok, let me look at it in a couple hours
        • mumblebajM Offline
          @sdetweil I think to resolve just do npm uninstall request and will remove request from the package,json. Else it will try to install it and you will run into the errors above.
            sdetweil @mumblebaj
            @mumblebaj but the code uses request…
            It downloads a now gz folder, with one xml file in it… I tried to use fetch and couldn’t get it to unzip the file in stream…
            2 days, gave up
            I installed ok on a pi4 after doing my script install
            warnings but no failures
            npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated joi@13.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
            added 66 packages, and audited 67 packages in 46s
            2 packages are looking for funding
              run `npm fund` for details
            6 vulnerabilities (2 moderate, 4 high)
            To address issues that do not require attention, run:
              npm audit fix
            To address all issues possible (including breaking changes), run:
              npm audit fix --force
            Some issues need review, and may require choosing
            a different dependency.
            Run `npm audit` for details.
            sam@raspberrypi4:~/MagicMirror/modules/MMM-aviationwx $
            mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @FSAHD
              @FSAHD i just pushed a fix to package.json and a new postinstall script
              git pull to get the updates…(watch out that it doesn’t overwrite your code)
              then the postinstall script from the module folder
              ./postinstall
              it will be called by npm install as well…
                @sdetweil I think it is possible with axios. Let me have a look at it. Will fork module from you and see what I can do and push a PR if it works.
                  sdetweil @mumblebaj
                  @mumblebaj said in Can anyone revive AviationWX, PilotWX, or TAF:
                  really don’t want axios… better to get native fetch working…
                  thats what I was trying. and you can use node xxx.js to test it without MM in the way…
                  its ‘possible’. just all the different ‘it works like this’ didn’t work.
                  there are two fetches in the node helper… one gets the gz file
                  and one gets an xml file… that one should be easy, but I didn’t want to mix in the same code path
                    @sdetweil The below code works fine. Tested it. Having issues with my system at the moment and can’t make the changes. Can you incorporate?
                    async function fetchData(metarUrl, airports) {
                      try {
                        const response = await axios.get(metarUrl, {
                          responseType: 'arraybuffer', // ensure response is treated as binary
                          headers: {
                            'Accept-Encoding': 'gzip', // request gzip compression
                        // Unzip the gzip response
                        const unzippedData = zlib.gunzipSync(response.data).toString();
                        let json_string = convert.toJson(unzippedData);
                        var json = JSON.parse(json_string);
                        var metarData = json.response.data.METAR;
                        var airportData = new Object();
                        var airports = payload.airportList.split(",").map(function (airport) {
                            airport = airport.trim();
                            return (airport.length < 4) ? "K" + airport : airport;
                        airports.forEach(function (airport) {
                            metarData.forEach(function (metar) {
                                if (airport === metar.station_id) {
                                    if (this.debug)
                                        console.log("METAR data found for " + airport);
                                    airportData[airport] = metar;
                                    return; // check next airport in list
                            console.log(metarData)
                      } catch (error) {
                        console.error('Error fetching data:', error);
                      @sdetweil I can fix the other fetch as well no issues. Give me a few on this one.
                        @sdetweil Both calls working.
                        try {
                                    headers: {
                                            if (this.debug)
                                    // console.log(metarData)
                            } catch (error) {
                            const checktype = { "Airspace_Flow_List":"Airspace_Flow", "Ground_Delay_List": "Ground_Delay", "Arrival_Departure_Delay_List": "Delay","Airport_Closure_List":"Airport" }
                            try {
                                const response = await axios.get(FAAUrl);
                                // Your further processing
                                let json_string =
                                    //convert.toJson(test_data)     swap comments to use test FAA data
                                    convert.toJson(response.data.toString());
                                if (this.debug)
                                    console.log("json faa=" + json_string);
                                const faa_data = JSON.parse(json_string);
                                if (!Array.isArray(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)) {
                                    // save the current entry
                                    const x = faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type
                                    //  init as an array
                                    faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type = []
                                    // add the element into the array
                                    faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.push(x)
                                // loop thru the delay types
                                faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.forEach(t => {
                                    if (t.name !== "Airspace Flow Programs") {
                                        // for each the  there are two major keys, name and the list for that type
                                        // get the key of the list
                                        const keyname = Object.keys(t)[1]
                                        // remove the "_list"  part for passing to front end
                                        const key = keyname.split('_').slice(0, -1).join('_')
                                        if (this.debug)
                                            console.log("key data=" + JSON.stringify(t[keyname][checktype[keyname]]) + "keyname=" + keyname + " key=" + checktype[keyname] + "\n")
                                        if (!Array.isArray(t[keyname][checktype[keyname]])) {
                                            const x = t[keyname][checktype[keyname]]
                                            t[keyname][checktype[keyname]] = []
                                            t[keyname][checktype[keyname]].push(x)
                                        } else {
                                            console.log("checkytype=" + checktype[keyname])
                                        if (this.debug)
                                            console.log("data=" + Object.keys(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)[0] + " data=" + JSON.stringify(t) + " keyname=" + keyname + " key=" + key + " last part=" + JSON.stringify(t[keyname][key]) + "\n")
                                        // look thru all the aaffected airports for this record type
                                        t[keyname][checktype[keyname]].forEach(airport_record => {
                                            // if the airport is one the user requested
                                            if (airports.includes('K' + airport_record.ARPT)) {
                                                if (airportData['K' + airport_record.ARPT]['FAA'] == undefined)
                                                    airportData['K' + airport_record.ARPT]['FAA'] = {}
                                                // save this data record
                                                airportData['K' + airport_record.ARPT]['FAA'][key] = airport_record
                                // Emitting data to Socket
                                //self.sendSocketNotification("WX_RESULT", airportData);
                            } catch (error) {
                                console.error('Error fetching FAA data:', error);
                          sdetweil @mumblebaj
                          @mumblebaj thx. but there is a way to not have to use zlib. I just haven’t found any that work
                            @sdetweil If you want to use fetch you can do the first call as follows.
                            try {
                                const response = await fetch(metarUrl, {
                                  headers: {
                                    'Accept-Encoding': 'gzip', // Request gzip compression
                                if (!response.ok) {
                                  throw new Error(`HTTP error! Status: ${response.status}`);
                                // Read response body as buffer
                                const buffer = await response.buffer();
                                // Manually decompress gzip data
                                const zlib = require('zlib');
                                const decompressedData = zlib.gunzipSync(buffer).toString();
                            You could use pako.
                            const decompressedData = pako.inflate(buffer, { to: 'string' });
                              sdetweil @mumblebaj
                              @mumblebaj but… you are not supposed to have to do either
                                @sdetweil I have not seen another way. Sorry…:man_facepalming:
                                • F Offline
                                  FSAHD @mumblebaj
                                  @mumblebaj @sdetweil fwiw, and I don’t know if this would be any easier for the situation.
                                  There is a site called avwx.rest
                                  (I believe the pilot wx all was using that source)
                                  It’s an API built solely for pilot data
                                  You do need a key but maybe the data will be easier to pull?
                                  https://avwx.docs.apiary.io/#
                                    sdetweil @FSAHD
                                    @FSAHD I might use that for pilot.
                                    we are just talking about using more current support , so the module lasts longer
                                      @sdetweil There is a simple api call from the site to get the metar data whicg might be simpler to use.
                                      https://aviationweather.gov/api/data/metar?ids=KMCI%2CKORD%2CKBOS&format=json&taf=true&hours=1&bbox=-26.139%2C28.246&date=2024-03-10T23%3A44%3A22Z
                                        sdetweil @FSAHD
                                        @mumblebaj
                                        thanks to your help I fixed the code to use the airport specific request which returns json and not gzip…
                                        @FSAHD the output changed metar output changed again… sorry
                                        i updated the sample text again
                                        so git pull, and npm install
                                        • F Offline
                                          FSAHD @sdetweil
                                          @sdetweil No worries. I really appreciate both of you alls help. Ill spend as much time I need on my end to get it up and going!
                                          @mumblebaj thanks for adding your .02 cents to help this move forward.
                                          Im new to this MM forum so I am not sure how to go about this but I would love to either get you both a cup of coffee or just donate to your efforts as a thank you!
                                          S mumblebajM 2 Replies Last reply Reply Quote 0
                                            sdetweil @FSAHD
                                            @FSAHD I don’t accept donations.
                                            I do this for fun and learning, so I’m already rewarded.
