    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 12.8k Views 3 Watching
      sdetweil @mumblebaj
      @mumblebaj thx. but there is a way to not have to use zlib. I just haven’t found any that work
      • mumblebajM Online
        @sdetweil If you want to use fetch you can do the first call as follows.
        try {
            const response = await fetch(metarUrl, {
              headers: {
                'Accept-Encoding': 'gzip', // Request gzip compression
            if (!response.ok) {
              throw new Error(`HTTP error! Status: ${response.status}`);
            // Read response body as buffer
            const buffer = await response.buffer();
            // Manually decompress gzip data
            const zlib = require('zlib');
            const decompressedData = zlib.gunzipSync(buffer).toString();
        You could use pako.
        const decompressedData = pako.inflate(buffer, { to: 'string' });
          sdetweil @mumblebaj
          @mumblebaj but… you are not supposed to have to do either
          • mumblebajM Online
            @sdetweil I have not seen another way. Sorry…:man_facepalming:
            • F Offline
              FSAHD @mumblebaj
              @mumblebaj @sdetweil fwiw, and I don’t know if this would be any easier for the situation.
              There is a site called avwx.rest
              (I believe the pilot wx all was using that source)
              It’s an API built solely for pilot data
              You do need a key but maybe the data will be easier to pull?
              https://avwx.docs.apiary.io/#
                sdetweil @FSAHD
                @FSAHD I might use that for pilot.
                we are just talking about using more current support , so the module lasts longer
                • mumblebajM Online
                  @sdetweil There is a simple api call from the site to get the metar data whicg might be simpler to use.
                  https://aviationweather.gov/api/data/metar?ids=KMCI%2CKORD%2CKBOS&format=json&taf=true&hours=1&bbox=-26.139%2C28.246&date=2024-03-10T23%3A44%3A22Z
                    sdetweil @FSAHD
                    @mumblebaj
                    thanks to your help I fixed the code to use the airport specific request which returns json and not gzip…
                    @FSAHD the output changed metar output changed again… sorry
                    i updated the sample text again
                    so git pull, and npm install
                    • F Offline
                      FSAHD @sdetweil
                      @sdetweil No worries. I really appreciate both of you alls help. Ill spend as much time I need on my end to get it up and going!
                      @mumblebaj thanks for adding your .02 cents to help this move forward.
                      Im new to this MM forum so I am not sure how to go about this but I would love to either get you both a cup of coffee or just donate to your efforts as a thank you!
                      S mumblebajM 2 Replies Last reply Reply Quote 0
                        sdetweil @FSAHD
                        @FSAHD I don’t accept donations.
                        I do this for fun and learning, so I’m already rewarded.
                        • mumblebajM Online
                          mumblebaj Module Developer @FSAHD
                          @FSAHD No donations required. We love this project and this forum. :winking_face:
