    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 13.6k Views 3 Watching
      sdetweil @FSAHD
      @FSAHD I got the metar to work, then the faa data is all different not by airport request. and all the variable names have changed too
      don’t know if the data is different for display
      and the data is xml
      F 1 Reply Last reply
      • F
        FSAHD @sdetweil
        @sdetweil I know the airport delay item is last on the wish list.
        I can take over and update variables and such. wherever you left off ill be happy to take over!
        S 2 Replies Last reply
          sdetweil @FSAHD
          @FSAHD ok, let me finish the faa data . I was working on it this morning
            sdetweil @FSAHD
            @FSAHD ok, here is the partially updated MMM-aviationwx
            https://github.com/sdetweil/MMM-aviationwx
            there is a file of the output sent back from the node_helper( this morning) in formatted json (sample-data.txt)
            so you can see the field names and values…
            I marked in the MMM-aviationwx.js in getDom() where all this needs to be corrected with correct variable names and values…
            as an example
                  var icao = airport.id;
            airport.id is now airport.station_id
            “station_id”: “KSFO”,
            • F
              FSAHD @sdetweil
              @sdetweil Thanks again for the help.
              I think I have all the variables updated. Im c urrently working on trying to get the dependencies to install on my pi so I can test.
              You were a big help and I see where I went wrong in a lot of places when I was trying to build from scratch. It was a lot of simple mistakes lol
                sdetweil @FSAHD
                @FSAHD great news.
                dependencies?
                package.json has them all for the module
                so npm install will do all for the module
                use my install script for mm
                  sdetweil @FSAHD
                  @FSAHD a lot of simple mistakes…
                  computers do things fast. whatever we tell them… lol
                  • F
                    FSAHD @sdetweil
                    @sdetweil I tried that after I cloned the git into the modules folder.
                    I ended up getting this error.
                    I also don’t remember if I used your script for this instance of mm or if I installed manually if that makes any difference
                      sdetweil @FSAHD
                      @FSAHD ok, let me look at it in a couple hours
                      mumblebajM 1 Reply Last reply
                      • mumblebajM
                        @sdetweil I think to resolve just do npm uninstall request and will remove request from the package,json. Else it will try to install it and you will run into the errors above.
                          sdetweil @mumblebaj
                          @mumblebaj but the code uses request…
                          It downloads a now gz folder, with one xml file in it… I tried to use fetch and couldn’t get it to unzip the file in stream…
                          2 days, gave up
                          I installed ok on a pi4 after doing my script install
                          warnings but no failures
                          npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated joi@13.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                          added 66 packages, and audited 67 packages in 46s
                          2 packages are looking for funding
                            run `npm fund` for details
                          6 vulnerabilities (2 moderate, 4 high)
                          To address issues that do not require attention, run:
                            npm audit fix
                          To address all issues possible (including breaking changes), run:
                            npm audit fix --force
                          Some issues need review, and may require choosing
                          a different dependency.
                          Run `npm audit` for details.
                          sam@raspberrypi4:~/MagicMirror/modules/MMM-aviationwx $
                          mumblebajM 2 Replies Last reply
                            sdetweil @FSAHD
                            @FSAHD i just pushed a fix to package.json and a new postinstall script
                            git pull to get the updates…(watch out that it doesn’t overwrite your code)
                            then the postinstall script from the module folder
                            ./postinstall
                            it will be called by npm install as well…
                            • mumblebajM
                              @sdetweil I think it is possible with axios. Let me have a look at it. Will fork module from you and see what I can do and push a PR if it works.
                                sdetweil @mumblebaj
                                @mumblebaj said in Can anyone revive AviationWX, PilotWX, or TAF:
                                really don’t want axios… better to get native fetch working…
                                thats what I was trying. and you can use node xxx.js to test it without MM in the way…
                                its ‘possible’. just all the different ‘it works like this’ didn’t work.
                                there are two fetches in the node helper… one gets the gz file
                                and one gets an xml file… that one should be easy, but I didn’t want to mix in the same code path
                                • mumblebajM
                                  @sdetweil The below code works fine. Tested it. Having issues with my system at the moment and can’t make the changes. Can you incorporate?
                                  async function fetchData(metarUrl, airports) {
                                    try {
                                      const response = await axios.get(metarUrl, {
                                        responseType: 'arraybuffer', // ensure response is treated as binary
                                        headers: {
                                          'Accept-Encoding': 'gzip', // request gzip compression
                                      // Unzip the gzip response
                                      const unzippedData = zlib.gunzipSync(response.data).toString();
                                      let json_string = convert.toJson(unzippedData);
                                      var json = JSON.parse(json_string);
                                      var metarData = json.response.data.METAR;
                                      var airportData = new Object();
                                      var airports = payload.airportList.split(",").map(function (airport) {
                                          airport = airport.trim();
                                          return (airport.length < 4) ? "K" + airport : airport;
                                      airports.forEach(function (airport) {
                                          metarData.forEach(function (metar) {
                                              if (airport === metar.station_id) {
                                                  if (this.debug)
                                                      console.log("METAR data found for " + airport);
                                                  airportData[airport] = metar;
                                                  return; // check next airport in list
                                          console.log(metarData)
                                    } catch (error) {
                                      console.error('Error fetching data:', error);
                                  • mumblebajM
                                    @sdetweil I can fix the other fetch as well no issues. Give me a few on this one.
                                    • mumblebajM
                                      @sdetweil Both calls working.
                                      try {
                                                  headers: {
                                                          if (this.debug)
                                                  // console.log(metarData)
                                          } catch (error) {
                                          const checktype = { "Airspace_Flow_List":"Airspace_Flow", "Ground_Delay_List": "Ground_Delay", "Arrival_Departure_Delay_List": "Delay","Airport_Closure_List":"Airport" }
                                          try {
                                              const response = await axios.get(FAAUrl);
                                              // Your further processing
                                              let json_string =
                                                  //convert.toJson(test_data)     swap comments to use test FAA data
                                                  convert.toJson(response.data.toString());
                                              if (this.debug)
                                                  console.log("json faa=" + json_string);
                                              const faa_data = JSON.parse(json_string);
                                              if (!Array.isArray(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)) {
                                                  // save the current entry
                                                  const x = faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type
                                                  //  init as an array
                                                  faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type = []
                                                  // add the element into the array
                                                  faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.push(x)
                                              // loop thru the delay types
                                              faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type.forEach(t => {
                                                  if (t.name !== "Airspace Flow Programs") {
                                                      // for each the  there are two major keys, name and the list for that type
                                                      // get the key of the list
                                                      const keyname = Object.keys(t)[1]
                                                      // remove the "_list"  part for passing to front end
                                                      const key = keyname.split('_').slice(0, -1).join('_')
                                                      if (this.debug)
                                                          console.log("key data=" + JSON.stringify(t[keyname][checktype[keyname]]) + "keyname=" + keyname + " key=" + checktype[keyname] + "\n")
                                                      if (!Array.isArray(t[keyname][checktype[keyname]])) {
                                                          const x = t[keyname][checktype[keyname]]
                                                          t[keyname][checktype[keyname]] = []
                                                          t[keyname][checktype[keyname]].push(x)
                                                      } else {
                                                          console.log("checkytype=" + checktype[keyname])
                                                      if (this.debug)
                                                          console.log("data=" + Object.keys(faa_data['AIRPORT_STATUS_INFORMATION'].Delay_type)[0] + " data=" + JSON.stringify(t) + " keyname=" + keyname + " key=" + key + " last part=" + JSON.stringify(t[keyname][key]) + "\n")
                                                      // look thru all the aaffected airports for this record type
                                                      t[keyname][checktype[keyname]].forEach(airport_record => {
                                                          // if the airport is one the user requested
                                                          if (airports.includes('K' + airport_record.ARPT)) {
                                                              if (airportData['K' + airport_record.ARPT]['FAA'] == undefined)
        airportData['K' + airport_record.ARPT]['FAA'] = {}
                                                              // save this data record
                                                              airportData['K' + airport_record.ARPT]['FAA'][key] = airport_record
                                              // Emitting data to Socket
                                              //self.sendSocketNotification("WX_RESULT", airportData);
                                          } catch (error) {
                                              console.error('Error fetching FAA data:', error);
                                        sdetweil @mumblebaj
                                        @mumblebaj thx. but there is a way to not have to use zlib. I just haven’t found any that work
                                        • mumblebajM
                                          @sdetweil If you want to use fetch you can do the first call as follows.
                                          try {
                                              const response = await fetch(metarUrl, {
                                                headers: {
                                                  'Accept-Encoding': 'gzip', // Request gzip compression
                                              if (!response.ok) {
                                                throw new Error(`HTTP error! Status: ${response.status}`);
                                              // Read response body as buffer
                                              const buffer = await response.buffer();
                                              // Manually decompress gzip data
                                              const zlib = require('zlib');
                                              const decompressedData = zlib.gunzipSync(buffer).toString();
                                          You could use pako.
                                          const decompressedData = pako.inflate(buffer, { to: 'string' });
                                            sdetweil @mumblebaj
                                            @mumblebaj but… you are not supposed to have to do either
