    Can anyone revive AviationWX, PilotWX, or TAF
    36 Posts 3 Posters 11.4k Views 3 Watching
    • F Offline
      FSAHD @sdetweil
      @sdetweil that is what I believe it it, also what the AI helped me deduce.
      I attempted to solve that but was unsuccessful. I believe that was the problem with all 3 modules I mentioned.
      I tried using npm install request. that didnt work.
      Then I attempted to update the code to use axios
        sdetweil @FSAHD
        @FSAHD OK, let me look at them
          sdetweil @FSAHD
          @FSAHD well every url changed, and all the data
          changed. some has to be calculated (avg airport delay) or that info display deleted.
          too much work for me., given my avaliable time
          • F Offline
            FSAHD @sdetweil
            @sdetweil I appreciate you looking into this. ill take some time and see wat I can do!
              sdetweil @FSAHD
              @FSAHD I got the metar to work, then the faa data is all different not by airport request. and all the variable names have changed too
              don’t know if the data is different for display
              and the data is xml
              • F Offline
                FSAHD @sdetweil
                @sdetweil I know the airport delay item is last on the wish list.
                I can take over and update variables and such. wherever you left off ill be happy to take over!
                  sdetweil @FSAHD
                  @FSAHD ok, let me finish the faa data . I was working on it this morning
                    sdetweil @FSAHD
                    @FSAHD ok, here is the partially updated MMM-aviationwx
                    https://github.com/sdetweil/MMM-aviationwx
                    there is a file of the output sent back from the node_helper( this morning) in formatted json (sample-data.txt)
                    so you can see the field names and values…
                    I marked in the MMM-aviationwx.js in getDom() where all this needs to be corrected with correct variable names and values…
                    as an example
                          var icao = airport.id;
                    airport.id is now airport.station_id
                    “station_id”: “KSFO”,
                    • F Offline
                      FSAHD @sdetweil
                      @sdetweil Thanks again for the help.
                      I think I have all the variables updated. Im c urrently working on trying to get the dependencies to install on my pi so I can test.
                      You were a big help and I see where I went wrong in a lot of places when I was trying to build from scratch. It was a lot of simple mistakes lol
                      S 2 Replies Last reply Reply Quote 1
                        sdetweil @FSAHD
                        @FSAHD great news.
                        dependencies?
                        package.json has them all for the module
                        so npm install will do all for the module
                        use my install script for mm
                        • 1 / 4
