    updating MMM-mmpm using mmpm web UI and now MagicMirror won't start
    mmpmmmm-mmpmmpmm-ui
    3 Posts 2 Posters 1.4k Views 2 Watching
    • T
      travishardiman
      $ pm2 list
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 557  │ errored   │ 0%       │ 0b       │
      │ 1  │ mmpm.api           │ fork     │ 4    │ online    │ 0%       │ 27.0mb   │
      │ 2  │ mmpm.log-server    │ fork     │ 4    │ online    │ 0%       │ 27.7mb   │
      │ 3  │ mmpm.repeater      │ fork     │ 4    │ online    │ 0%       │ 27.7mb   │
      │ 4  │ mmpm.ui            │ fork     │ 4    │ online    │ 0%       │ 17.4mb   │
      Here are the logs I see in the mmpm ui:
      {"timestamp": "2024-04-03 21:59:35,412", "level": "INFO", "version": "4.1.1", "message": "Received request to start MagicMirror", "logger_name": "mmpm.api.endpoints.endpoint", "module": "ep_mm_ctl", "function": "start", "line": 92}
      {"timestamp": "2024-04-03 21:59:35,414", "level": "DEBUG", "version": "4.1.1", "message": "pm2 process set as MagicMirror", "logger_name": "mmpm.api.endpoints.endpoint", "module": "controller", "function": "start", "line": 189}
      {"timestamp": "2024-04-03 21:59:35,416", "level": "DEBUG", "version": "4.1.1", "message": "Attempting to start MagicMirror using pm2 start MagicMirror ", "logger_name": "mmpm.api.endpoints.endpoint", "module": "controller", "function": "start", "line": 205}
      {"timestamp": "2024-04-03 21:59:35,418", "level": "DEBUG", "version": "4.1.1", "message": "Executing command `pm2 start MagicMirror`", "logger_name": "mmpm.api.endpoints.endpoint", "module": "utils", "function": "run_cmd", "line": 111}
      {"timestamp": "2024-04-03 21:59:36,054", "level": "INFO", "version": "4.1.1", "message": "Started MagicMirror", "logger_name": "mmpm.api.endpoints.endpoint", "module": "controller", "function": "start", "line": 216}
      {"timestamp": "2024-04-03 21:59:53,609", "level": "DEBUG", "version": "4.1.1", "message": "Client disconnected: kIMuN9OtxFxs50T0AAAJ", "logger_name": "mmpm.api.repeater", "module": "repeater", "function": "disconnect", "line": 63}
      {"timestamp": "2024-04-03 21:59:53,612", "level": "DEBUG", "version": "4.1.1", "message": "Removed kIMuN9OtxFxs50T0AAAJ from known Client IDs", "logger_name": "mmpm.api.repeater", "module": "repeater", "function": "disconnect", "line": 66}
      {"timestamp": "2024-04-03 22:00:03,614", "level": "DEBUG", "version": "4.1.1", "message": "Client disconnected: nhuaaGBQFvkiqkhMAAAL", "logger_name": "mmpm.api.repeater", "module": "repeater", "function": "disconnect", "line": 63}
      {"timestamp": "2024-04-03 22:00:03,615", "level": "DEBUG", "version": "4.1.1", "message": "Removed nhuaaGBQFvkiqkhMAAAL from known Client IDs", "logger_name": "mmpm.api.repeater", "module": "repeater", "function": "disconnect", "line": 66}
      {"timestamp": "2024-04-03 22:00:03,617", "level": "DEBUG", "version": "4.1.1", "message": "No clients connected. Disconnecting from MagicMirror SocketIO Server.", "logger_name": "mmpm.api.repeater", "module": "repeater", "function": "disconnect", "line": 70}
      I have tried reinstalling mmpm, the UI, and MMM-mmpm and restarting.
      These logs might be more helpful:
      /home/pi/.pm2/logs/MagicMirror-error.log last 75 lines:
      0|MagicMir | [2024-04-03 22:10:07.178] [ERROR] App threw an error during load
      0|MagicMir | [2024-04-03 22:10:07.182] [ERROR] Error: Cannot find module '/home/pi/MagicMirror/node_modules/systeminformation/lib/index.js'. Please verify that the package.json has a valid "main" entry
      0|MagicMir |     at tryPackage (node:internal/modules/cjs/loader:422:19)
      0|MagicMir |     at Module._findPath (node:internal/modules/cjs/loader:672:18)
      0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:1041:27)
      0|MagicMir |     at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
      0|MagicMir |     at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:908:27)
      0|MagicMir |     at c._load (node:electron/js2c/node_init:2:13672)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1122:19)
      0|MagicMir |     at require (node:internal/modules/helpers:130:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/utils.js:3:12)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      0|MagicMir |     at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:1098:32)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:945:12)
      0|MagicMir | A JavaScript error occurred in the main process
      0|MagicMir | Uncaught Exception:
      0|MagicMir | Error: Cannot find module '/home/pi/MagicMirror/node_modules/systeminformation/lib/index.js'. Please verify that the package.json has a valid "main" entry
      0|MagicMir | [13400:0403/221008.167490:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.167856:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.168715:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.168844:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.169012:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.169118:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.169270:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.169833:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.170142:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.170267:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.171101:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.171215:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.171929:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.172108:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.173290:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.173450:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174025:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174154:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174316:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174413:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174557:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174658:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174799:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.174895:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.175032:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.175122:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.175265:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
      0|MagicMir | [13400:0403/221008.175355:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
        sdetweil @travishardiman
        @travishardiman said in updating MMM-mmpm using mmpm web UI and now MagicMirror won't start:
        this library is missing systeminformation
        npm install systeminformation
        T 1 Reply Last reply
        • T
          travishardiman @sdetweil
          @sdetweil said in updating MMM-mmpm using mmpm web UI and now MagicMirror won't start:
          Thanks! That fixed it!!
