    Multiple Google Calendar issue
    5 Posts 2 Posters 1.2k Views 3 Watching
      Bobba86
      Hey!
      Im new in the MM community and got some issues setting up multiple Google Calendars.
      The first one works fine. Then i tried to set up two more from two different accounts.
      The URL i correct. But when I boot my mirror it says that there is nothing in the calendar and sometimes it says that there is an error in the module. I guess i have made an error somewhere, but cant figure it out. I have made changes to my url in the post since its my private calendar.
      Sorry about the mess in my config !
      		header: "Bobba",
      					symbol: "calendar-check",
      					url: "https://calendar.google.com/calendar/ical/my=private-url/basic.ics",
      					maximumEntries:7,
      					//url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
      		header: "Sara",
      					maximumEntries:7,
      		header: "Max",
      					url: "https://calendar.google.com/calendar/ical/my=private-urlbasic.ics",
      					maximumEntries:7,
        sdetweil @Bobba86
        @Bobba86 the logs are output where you do npm start.
        if you use pm2 to auto start, then it collects the info whi h an be show with a pm2 command
        pm2 logs --lines=xxxx
        xxxx is number of lines, default 15
        as you want them w different headers, .multiple modules is the right way
        BUT in a single…module it is.
               url:"...."
                other parms
                 url :"....."
                 other parms
        repeat
          sdetweil @Bobba86
          @Bobba86 can you show the error. you can do all 4 in one calendar module of you want too… then the events are combined
            Bobba86 @sdetweil
            Not sure how to show the error. Is there a log or something where i can get an error code? The calendar is showing in MM. But there is nothing in the calendar, no matter how many things i enter in my google calendar. The first one works just fine, but the second and third won´t show anything,
            Sometimes when i launch MM it says “error in the module” under the second and third calendar.
            If i would put all in one module. should i do it like this?
            Im new to this and have zero knowledge in coding :D
            	header: "Bobba",
            				maximumEntries:7,
            header: “Sara”,
            position: “top_left”,
            symbol: “calendar-check”,
            url: “https://calendar.google.com/calendar/ical/my=private-url/basic.ics”,
            maximumEntries:7,
            //url: “https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics”
            header: “Sara”,
            maximumEntries:7,
              sdetweil @Bobba86
                     url:"...."
                      other parms
                       url :"....."
                       other parms
              repeat
                Bobba86 @sdetweil
                Thanks! Followed your instructions and tadaaa! It works :D Thank you very much for the help!
                • B Bobba86 has marked this topic as solved on
