    MP3 Player
    59 Posts 5 Posters 32.8k Views 4 Watching
      sdetweil @bachoo786
      @bachoo786 better if you make a github repo
      but the main problem is you cannot sendNotification to yourself…
      BUT you CAN call the notificationReceived function instead
      B 1 Reply Last reply
        bachoo786 @sdetweil
        @sdetweil what do I do then ?
          sdetweil @bachoo786
          @bachoo786 change the one line of code
          mumblebajM 1 Reply Last reply
          • mumblebajM
            @sdetweil and @bachoo786 There is a lot wrong with that code snippets. Can’t make it work the way it stands.
              sdetweil @mumblebaj
              @mumblebaj @bachoo786 here is a repo for this module
              it is built with name sensitive constructs, so if you rename the files it will adjust automatically… (except for the css file… today it has no module prefix on its selectors)
              https://github.com/sdetweil/new-MP3Player
              (as I already have a module repo with MMM)
              put some music files in the music folder
              install instructions
              cd ~/MagicMirror/modules
              git clone https://github.com/sdetweil/new-MP3Player
              cd new-MP3Player
              npm install
              change the modulename in config.js if u had the prior code
                I updated the player to get rid of as many global variables as possible
                  bachoo786 @sdetweil
                  Hi Sam thanks for that I will try it out soon.
                  I am currently working on the existing mp3 player module and have added another songList i.e. songList2 as per my get dom function. Trouble is I get this error when I restart the MagicMirror, the error is from the developer console. I am scratching my head to resolve it but it doesnt work.
                  here is the code:
                  MMM-MP3Player.js:
                  var MP3;
                  var substr;
                  Module.register("MMM-MP3Player", {
                    defaults: {
                      songs: [],
                      songs2: [],  // Add this line for the second song list
                      musicPath: "modules/MMM-MP3Player/music",
                      musicPath2: "modules/MMM-MP3Player/music2",
                      extensions: ["mp3", "wma", "acc", "ogg"],
                  //    songs: null,
                      autoPlay: false,
                      random: false,
                    audio: null,
                    songTitle: null,
                    mediaPlayer: null,
                    dataAvailable: true,
                    curSong :0,
                    curLength : 0,
                    time: null,
                    play: null,
                    firstTime: true,
                    substr: null,
                    getStyles: function(){
                      return ["MMM-MP3Player.css", "font-awesome.css"];
                  start: function() {
                    MP3 = this;
                    console.log("Starting module:", MP3.name);
                    this.sendSocketNotification('SOURCE_MUSIC', {musicPath: this.config.musicPath, extensions: this.config.extensions});
                    this.sendSocketNotification('SOURCE_MUSIC2', {musicPath: this.config.musicPath2, extensions: this.config.extensions}); // Send notification to load songs from the second directory
                  getDom: function(){
                      if(MP3.config.songs != null) {
                          // Display the list of MP3 files
                          var songList = MP3.createElement("ul", "songList", "songList");
                          for(var i = 0; i < MP3.config.songs.length; i++) {
                              var listItem = MP3.createElement("li", "songItem", "songItem" + i);
                              listItem.innerHTML = MP3.config.songs[i].substr(0, MP3.config.songs[i].length - 4);
                              listItem.addEventListener("click", function(index) {
                                  return function() {
                                      MP3.setCurrentSong(index);
                                      MP3.audio.play();
                                      MP3.play.getElementsByTagName('i')[0].className = "fa fa-pause";
                                      MP3.mediaPlayer.classList.add("play");
                                      MP3.updateDurationLabel();
                              }(i));
                              songList.appendChild(listItem);
                          wrapper.appendChild(songList);
                    if (MP3.config.songs2 != null) {
                      var songList2 = MP3.createElement("ul", "songList2", "songList2");
                      for (var i = 0; i < MP3.config.songs2.length; i++) {
                        var listItem = MP3.createElement("li", "songItem2", "songItem2-" + i);
                        listItem.innerHTML = MP3.config.songs2[i].substr(0, MP3.config.songs2[i].length - 4);
                          return function() {
                            MP3.setCurrentSong(index, 'music2');
                            MP3.audio.play();
                        }(i));
                        songList2.appendChild(listItem);
                      wrapper.appendChild(songList2);
                          // Add the rest of the existing code...
                          MP3.mediaPlayer = MP3.createElement("div", "mediaPlayer", "mediaPlayer");
                          MP3.audio = MP3.createElement("audio", "audioPlayer", "audioPlayer");
                          MP3.audio.addEventListener("loadeddata", () => {
                              MP3.dataAvailable = true;
                              MP3.curLength = MP3.audio.duration;
                          MP3.audio.addEventListener("ended", () => {
                              Log.log(" play ended")
                              MP3.audio.currentTime = 0;
                              if(MP3.config.autoPlay)
                                  MP3.loadNext(MP3.config.random)
                              else
                                  MP3.mediaPlayer.classList.toggle("play");
                  MP3.audio.addEventListener("timeupdate", () => {
                          MP3.mediaPlayer.appendChild(MP3.audio);
                          // Add the rest of the controls to MP3.mediaPlayer
                          var controls = MP3.createElement("div", "controls", false);
                          MP3.songTitle = MP3.createElement("span", "title", "songTitle");
                          MP3.setCurrentSong(MP3.curSong);
                          controls.appendChild(MP3.songTitle);
                          var discArea = MP3.createElement("div", "discarea", false);
                          discArea.appendChild(MP3.createElement("div", "disc", false));
                          var stylus = MP3.createElement("div", "stylus", false);
                          stylus.appendChild(MP3.createElement("div", "pivot", false));
                          stylus.appendChild(MP3.createElement("div", "arm", false));
                          stylus.appendChild(MP3.createElement("div", "head", false));
                          discArea.appendChild(stylus);
                          MP3.mediaPlayer.appendChild(discArea);
                        var buttons = MP3.createElement("div", "buttons", false);
                        //  Previous Button
                        var prev = MP3.createButton("back", "prevButton", "fa fa-backward");
                        prev.addEventListener("click", () => {
                          MP3.dataAvailable = false;
                          MP3.loadNext(MP3.config.random);
                          MP3.audio.play();
                        }, false),
                        buttons.appendChild(prev);
                        //  Play Button
                        MP3.play = MP3.createButton("play", "playButton", "fa fa-play");
                        MP3.play.addEventListener("click", () => {
                          if (MP3.audio.paused) {
                            setTimeout(() => {
                              MP3.audio.play();
                            }, 300);
                            MP3.timer = setInterval(MP3.updateDurationLabel, 100);
                          } else {
                            //MP3.loadNext(MP3.config.random);
                            MP3.play.getElementsByTagName('i')[0].className = "fa fa-play";
                            clearInterval(MP3.timer);
                            MP3.audio.pause();
                        }, false);
                        buttons.appendChild(MP3.play);
                        //  Stop Button
                        var stop = MP3.createButton("stop", "stopButton", "fa fa-stop");
                        stop.addEventListener("click", () => {
                          MP3.mediaPlayer.classList.remove("play");
                          MP3.audio.pause();
                        }, false);
                        buttons.appendChild(stop);
                        //  Next Button
                        var next = MP3.createButton("next", "nextButton", "fa fa-forward");
                        next.addEventListener("click", () => {
                        }, false);
                        buttons.appendChild(next);
                          controls.appendChild(buttons);
                          var subControls = MP3.createElement("div", "subControls", false);
                          var duration = MP3.createElement("span", "duration", "currentDuration");
                          duration.innerHTML = "00:00" + "&nbsp&nbsp&nbsp";
                          subControls.appendChild(duration);
                          var volumeSlider = MP3.createElement("input", "volumeSlider", "volumeSlider");
                          volumeSlider.type = "range";
                          volumeSlider.min = "0";
                          volumeSlider.max = "1";
                          volumeSlider.step = "0.01";
                          volumeSlider.addEventListener("input", () => {
                              MP3.audio.volume = parseFloat(volumeSlider.value);
                          }, false);
                          subControls.appendChild(volumeSlider);
                          controls.appendChild(subControls);
                          MP3.mediaPlayer.appendChild(controls);
                          wrapper.appendChild(MP3.mediaPlayer);
                      if(MP3.firstTime && MP3.config.autoPlay){
                          console.log("First time and autoPlay are true. Setting firstTime to false.");
                          MP3.firstTime=false;
                      return wrapper;
                    createElement: function(type, className, id){
                      var elem = document.createElement(type);
                      if(className) elem.className = className;
                      if(id)  elem.id = id;
                      return elem;
                    createButton: function(className, id, icon){
                      var button = document.createElement('button');
                      button.className = className;
                      button.id = id;
                      var ico = document.createElement("i");
                      ico.className = icon;
                      button.appendChild(ico);
                      return button;
                  updateDurationLabel: function() {
                    var duration = document.getElementById('currentDuration');
                    if (MP3.dataAvailable && MP3.audio.duration > 0) {
                      duration.innerText = MP3.parseTime(MP3.audio.currentTime) + " / " + MP3.parseTime(MP3.audio.duration);
                    } else {
                      duration.innerText = "00:00 / 00:00";
                    parseTime: function(time){
                      const minutes = Math.floor(time / 60)
                      const seconds = Math.floor(time - minutes * 60)
                      const secondsZero = seconds < 10 ? "0" : ""
                      const minutesZero = minutes < 10 ? "0" : ""
                      return minutesZero + minutes.toString() + ":" + secondsZero + seconds.toString()
                  setCurrentSong: function(index, type='music1') {
                    var path = type === 'music1' ? MP3.config.musicPath : MP3.config.musicPath2;  // Use musicPath2 from config
                    MP3.audio.src = path + '/' + MP3.config['songs' + (type === 'music1' ? '' : '2')][index];
                    MP3.songTitle.innerHTML = MP3.config['songs' + (type === 'music1' ? '' : '2')][index].substr(0, MP3.config['songs' + (type === 'music1' ? '' : '2')][index].length - 4);
                    MP3.curSong = index;
                    loadNext: function(next){
                     let index=0;
                        console.log("loadNext: Autoplay:", MP3.config.autoPlay); // Add this line for logging
                        MP3.audio.pause();
                        if(next)  index= (MP3.curSong + 1) % MP3.config.songs.length;
                        else      index = (MP3.curSong - 1) < 0 ? MP3.config.songs.length - 1 : MP3.curSong - 1;
                        MP3.audio.play();
                    notificationReceived: function (notification, payload) {
                      if(notification === "ALL_MODULES_STARTED")
                  		  MP3.sendSocketNotification('SOURCE_MUSIC', MP3.config);
                    if (notification === "RETURNED_MUSIC") {
                      if (payload.type === 'music1') {
                        MP3.config.songs = payload.songs;
                      } else if (payload.type === 'music2') {
                        MP3.config.songs2 = payload.songs;
                      MP3.setCurrentSong(0); // set initial song for each list
                      MP3.updateDom();
                  node-helper.js:
                  var NodeHelper = require('node_helper');
                  const Fs = require('fs');
                    start: function() {
                      console.log("Loaded MP3Player node_helper");
                  socketNotificationReceived: function(notification, payload){
                    var self = this;
                    if (notification === 'SOURCE_MUSIC') {
                      var songs = this.getSongs(payload.musicPath, payload.extensions);
                      self.sendSocketNotification("RETURNED_MUSIC", {songs: songs, type: 'music1'});
                    } else if (notification === 'SOURCE_MUSIC2') {
                      self.sendSocketNotification("RETURNED_MUSIC", {songs: songs, type: 'music2'});
                  getSongs: function(path, ext){
                    var songs = [];
                    var contents = Fs.readdirSync(path);
                    contents.forEach(file => {
                      if (this.checkExt(file, ext)) {  // Use the checkExt function to filter files
                        songs.push(file);
                    console.log("mp3 player returning song list="+ songs);
                    return songs;
                  the error I get is:
                  Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:196:2)
                  which is this
                    sdetweil @bachoo786
                    @bachoo786 said in MP3 Player:
                    MP3.updateDom();
                    yep, it’s that trailing comma saying another function is coming
                      bachoo786 @sdetweil
                      so I removed it to this:
                          MP3.updateDom();
                      but still doesnt like it gives this error:
                      :8182/modules/MMM-MP…MM-MP3Player.js:196 Uncaught SyntaxError: Unexpected token ','
                        sdetweil @bachoo786
                        @bachoo786 what is on line 195
                          bachoo786 @sdetweil
                          its this:
                          return wrapper;
                          which is around here :
                                  }, false);
                              return wrapper;
                              return elem;
                            sdetweil @bachoo786
                            @bachoo786 you have a missing close brace
                                 }   // <-----here
                            you need to use an editor with brace matching
                              bachoo786 @sdetweil
                              @sdetweil can you please recommend some editor with brace matching?
                              also I added close brace but that didnt resolve the issue got another error now right at the bottom.
                              error:
                              Uncaught SyntaxError: missing ) after argument list :8182/modules/MMM-MP…MM-MP3Player.js:264
                              here is line 263 and 264:
                              here is the full code:
                              var MP3;
                              var substr;
                                defaults: {
                                  songs: [],
                              //    songs: null,
                                  autoPlay: false,
                                  random: false,
                                audio: null,
                                songTitle: null,
                                mediaPlayer: null,
                                curSong :0,
                                curLength : 0,
                                time: null,
                                play: null,
                                firstTime: true,
                                substr: null,
                              start: function() {
                                MP3 = this;
                              getDom: function(){
                                              return function() {
                                                  MP3.audio.play();
                                          }(i));
                                      return function() {
                                        MP3.audio.play();
                                    }(i));
                                          else
                                    //  Previous Button
                                      MP3.audio.play();
                                    }, false),
                                    //  Play Button
                                        setTimeout(() => {
                                          MP3.audio.play();
                                        }, 300);
                                      } else {
                                        MP3.audio.pause();
                                    }, false);
                                    //  Stop Button
                                      MP3.audio.pause();
                                    }, false);
                                    //  Next Button
                                    }, false);
                                      }, false);
                                  return wrapper;
                                  return elem;
                                  button.id = id;
                                  return button;
                                } else {
                                 let index=0;
                                    MP3.audio.pause();
                                    MP3.audio.play();
                                  MP3.updateDom();
                              you see all I am trying to do is to add like a playlist to the module so basically I have added the songList and it shows all the songs i.e. .mp3 files in the music folder within the module’s folder.
                              I am now adding music2 folder to show another set of mp3 files and I thought of grouping each folder by artist name and display it on the front end.
                              this method is tedious as I need to repeat this for many artists.
                              a better method I think would be of having several artists folders in the module’s “single” music folder and in each artist’s folder there will be various mp3s.
                              this way the module should display the available artist i.e. folders in the front end and when I click on the artist’s name on the front end it would collapse down and show the mp3s in that respective artist’s folder.
                              I did try to work on this “better method” but didnt get far so I went for the easier option as I already had a single “songList” which was working and showing the mp3s in the “music” folder.
                                bachoo786 @bachoo786
                                here is the code for trying out the “better” method:
                                MMM-MP3Player.js:
                                var MP3;
                                var substr;
                                  defaults: {
                                    songs: [],
                                    songs: null,
                                    autoPlay: false,
                                    random: false,
                                  audio: null,
                                  songTitle: null,
                                  mediaPlayer: null,
                                  curSong :0,
                                  curLength : 0,
                                  time: null,
                                  play: null,
                                  firstTime: true,
                                  substr: null,
                                  start: function(){
                                    MP3 = this;
                                    console.log("autoPlay configuration:", MP3.config.autoPlay);
                                    Log.info("Starting module: " + MP3.name);
                                getDom: function(){
                                  if(MP3.config.folders) {
                                    var folderList = document.createElement("ul");
                                    folderList.className = "folderList";
                                    MP3.config.folders.forEach((folder, index) => {
                                      var folderItem = document.createElement("li");
                                      folderItem.className = "folderItem";
                                      folderItem.textContent = folder.name;
                                      folderItem.onclick = function() {
                                        this.classList.toggle("active");
                                        var songList = this.nextElementSibling;
                                        if (!songList) {
                                          songList = document.createElement("ul");
                                          songList.className = "songList";
                                          folder.songs.forEach(song => {
                                            var songItem = document.createElement("li");
                                            songItem.className = "songItem";
                                            songItem.textContent = song.substr(0, song.length - 4); // removes extension
                                            songItem.onclick = function() {
                                              // Set the song from the specific folder
                                              MP3.setCurrentSong(folder.name, song);
                                              MP3.audio.play();
                                            songList.appendChild(songItem);
                                          this.parentNode.insertBefore(songList, this.nextSibling);
                                        } else {
                                          songList.parentNode.removeChild(songList);
                                      folderList.appendChild(folderItem);
                                    wrapper.appendChild(folderList);
                                            else
                                      //  Previous Button
                                        MP3.audio.play();
                                      }, false),
                                      //  Play Button
                                          setTimeout(() => {
                                            MP3.audio.play();
                                          }, 300);
                                        } else {
                                          MP3.audio.pause();
                                      }, false);
                                      //  Stop Button
                                        MP3.audio.pause();
                                      }, false);
                                      //  Next Button
                                      }, false);
                                        }, false);
                                    return wrapper;
                                setCurrentSong: function(folderName, songName){
                                  if(MP3.audio!= undefined){
                                    MP3.audio.src = MP3.config.musicPath + '/' + folderName + '/' + songName;
                                    MP3.songTitle.innerHTML = songName.substr(0, songName.length - 4); // update song title display
                                    // Update the current song, handling file paths
                                    MP3.curSong = MP3.config.folders.findIndex(folder => folder.name === folderName);
                                    return elem;
                                    button.id = id;
                                    return button;
                                  } else {
                                  setCurrentSong: function(index){
                                        MP3.audio.src = MP3.config.musicPath + '/' + MP3.config.songs[index];
                                        MP3.songTitle.innerHTML = MP3.config.songs[index].substr(0, MP3.config.songs[index].length - 4);
                                   let index=0;
                                      MP3.audio.pause();
                                      MP3.audio.play();
                                    if(notification === "RETURNED_MUSIC")
                                      // set the initial song index
                                      // paint the player
                                      MP3.updateDom(2);
                                and the updated node-helper.js:
                                const Path = require('path');
                                  start: function() {
                                    var self = this;
                                    if(notification == 'SOURCE_MUSIC'){
                                      var folders = this.getFoldersWithSongs(payload.musicPath, payload.extensions);
                                      self.sendSocketNotification("RETURNED_MUSIC", {folders: folders});
                                  getFoldersWithSongs: function(path, ext){
                                    var folders = [];
                                    var contents = Fs.readdirSync(path, { withFileTypes: true });
                                    contents.forEach(dirent => {
                                      if (dirent.isDirectory()) {
                                        let songFiles = Fs.readdirSync(Path.join(path, dirent.name))
                                                          .filter(file => this.checkExt(file, ext));
                                        if (songFiles.length > 0) {
                                          folders.push({name: dirent.name, songs: songFiles});
                                    console.log("mp3 player returning folder list with songs="+ folders)
                                    return folders;
                                  checkExt: function(file, ext){
                                    return ext.some(extension => file.toLowerCase().endsWith("." + extension));
                                  sdetweil @bachoo786
                                  @bachoo786 sorry, been out
                                  for editor, install winsvp or bitwise ssh clients. I like bitwise better myself.
                                  both will give you ssh window AND a file manager view from windows over the pi (other system) filesystem
                                  then you can double click to edit
                                  and save back.
                                  I use notepad++ or visual studio code as the editor. you a also install visual studio code o the MagicMirror system, UT then u need vnc or keyboard and mouse . I never edit ON the MagicMirror system anymore
                                    bachoo786 @sdetweil
                                    @sdetweil ah thanks will look into it no need to apologise mate.
                                    Did you have a chance to look into my 2 sets of codes ?
                                      sdetweil @bachoo786
                                      @bachoo786 yes,
                                      your function
                                      takes two parms
                                      on line 264 you called it with one
                                        bachoo786 @sdetweil
                                        @sdetweil ah right so I need to change it to something like this:
                                        MP3.setCurrentSong(0, 'songName');
                                        Also did you manage to look into my later code which I described as the “better way”
                                          sdetweil @bachoo786
                                          @bachoo786 I did not look at the better method… cause I don’t know what that means.
                                          I wasn’t looking at design, only syntax
                                            bachoo786 @sdetweil
                                            @sdetweil ok I will try and explain the “better” method:
                                            I’m basically trying to add a playlist feature to the MP3 player module I’m working on. My initial setup involved adding a songList to MP3Player.js, which lists all the songs—.mp3 files—in the ‘music’ folder of the module. I’ve also added a second folder, ‘music2’, to categorize songs by artist. Each artist’s name is tagged with an ‘h2’ in the CSS, for both songList and songList2.
                                            However, this setup becomes cumbersome because it requires repeating the process for multiple artists, creating many folders and modifying the code each time for songList3, songList4, etc.
                                            I thought a better approach would be to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder.
                                            I did start on this more streamlined method, but it proved challenging, so I reverted to the simpler, original method which we’ve been discussing since yesterday, as that uses a “single” songList displaying songs from the ‘music’ folder and has been working for me. So I have been trying to add another “songList2” to add more artists and their respective music.
                                            I hope that makes sense?
                                            • 2 / 3
