    MagicMirror compliments for specific days at specific times
    4 Posts 2 Posters 893 Views 2 Watching
    • H Offline
      Horyzon
      Hi everyone,
      I want to change the code of my MMM-compliments .js so that some compliments are displayed only on specific days (friday, saturday, sunday) at specific times (around beer o’clock so 6pm to 8pm).
      Issue is that the documentation of the module isn’t mentioning how to go about it, even though I’m 100% sure it’s possible.
      So if someone knows how to do it, or has done it and doesn’t mind sharing the code, it would be very much appreciated !
      Thanks a lot and have a good one !
        sdetweil @Horyzon
        @Horyzon currently the code only supports a date mask
        yyyy-mm-dd
        that is done by this section of code
        complimentArray () {
        		const hour = moment().hour();
        		const date = moment().format("YYYY-MM-DD");
        		let compliments = [];
        // Add compliments for special days
        		for (let entry in this.config.compliments) {
        			if (new RegExp(entry).test(date)) {
        				Array.prototype.push.apply(compliments, this.config.compliments[entry]);
        		return compliments;
        it gets the date/time NOW
        and prints it YYYY-MM-DD
        2024-04-19
        and in the later code checks the selector field of the compliment entry to match that
        . means any character.
        to do what you want the selector would need a different format, crontab like
        * 18-20 * * 4-6
        which is (* means any)
        any minute
        hours 18-20
        any day
        any month
        4-6 days of the week
        so one could envision printing that layout
        and building a regular expression to test it
        see https://stackoverflow.com/questions/14203122/create-a-regular-expression-for-cron-statement/57639657#57639657
        and adding those 2 or 3 lines of code to the module function
          sdetweil @Horyzon
          @Horyzon SO… I think I have this working if you’d like to try it.
          uses the cron nomenclature
          “56-57 16-18 * * 4-6”
          “minute hour day month day_of_week”
          any of those can be ranges like above for minute, hour and day of week
          • means any
          so, the mask above says
          valid for last 3 days of week, thur-sat
          between 16:00 and 18:00
          during the two minutes at hh:56-57
          so 16:56-57. 17:56-57 , on thur, fri, sat nights all year
          the values can also be treated with some divisor
          mm/2 means the even minutes
          mm/30 means every 30 minutes
          hh/2 even other hour
          etc
          commas are allowed too 3,5,7,8 on the 3rd, 5th, 7th,8th (minute,hour, month day of month,
          7/8 are invalid for day of week 0-6, sunday is day 0
          there are crontab generators… click some boxes and it will spit out the string
            @Horyzon my update to compliments to support cron type entries was accepted and will be published in the next release (Oct 1)
            you can try it today by using the the develop branch of the MagicMirror repo
            see the troubleshooting section topic on how to get the develop branch
            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
            my MMM-Config module has support for this approach today
            you can use this page to generate the cron expression
            https://crontab-generator.org/
            use some dummy command to complete their config operation,
            and only take the first 5 space separated fields of the result…
