    want to add 3 buttons. reset/power/change page
    7 Posts 2 Posters 1.5k Views 2 Watching
      captheavenger
      Hi guys, have been working on this mirror on and off for about a year and finally have it exactly-ish where i want it.
      i’m ready to build the frame and order the glass but looking for some advice.
      (im using a ras pi 3model B+)
      3 buttons i want to build into the side, i’m thinking of ordering like simple momentary press buttons like you would use in a video game cabinet build.
      1 button to do a complete power on/off (not standby). i have been looking at modules like the ATXRasPi3 or the WittyPi4 but its a bit overwhelming and wondering who has had any luck with these or something similar.
      1 button will basically be a “reload” button, basically refresh button for the Magic Mirror. When i first run the magic mirror my Calendar doesnt populate completely and needs a little extra kick until it does its own update ( set to every 10 minutes). using MMM-CalendarEXT3
      1 button to advance the pages (i have 3) using MMM-pages
      Thanks in advance. I will be thrilled to finally get this bad boy up on the wall
        sdetweil @captheavenger
        @captheavenger mmm-buttons and mmm-remotecontrol (reboot and restart)
        buttons can talk to pages.
        calext3, I’d fix that in config, change the refresh delay
          captheavenger @sdetweil
          thanks
          so it’s weird…when magic mirror starts the just the US Holidays in that calendar module are filled out. i have 2 gmail calendars that literally take me refreshing the MM to fully populate. (Ctrl-R)
          What i probably didnt make clear in my original post was does anyone have any recommendations or experience on ATXRasPi3 or WittyPi and how exactly to accomplish what i am looking to do with 3 physical buttons?
            @captheavenger SO… I answered all those questions
            use MMM-Buttons for the physical connection to MM…
            this module sends notifications
            now to reboot or restart MM, the MMM-RemoteControl module does that , (with notifications)
            so wire those up from MMM-Buttons
            and MMM-Buttons can send the notifications to MMM-Pages
            all as you requested.
            not hard, all the config is in MMM-Buttons… the others just respond
            3 buttons, or 10, its the same.
            buttons are momentary… whatever you like… connected to the pi GPIO pins
            CalExt3… the calendars are big, the main calendar sends a notification , which the EXT3 modules expect… and then fill in from there…
            BUT. he doesn’t KNOW when to expect the cal data to arrive, and doesn’t want to flash the screen every second…
            SO… he has a timeout… if they don’t come in the first 5 seconds, he WAITS 10 MINUTES… and THEN draws all the data he has… EVEN THO
            the data might have arrived at 3 MINUTES…
            SO… change the timeout to 2 minutes, look at the output of npm start (pm2 logs --line=100 if you use pm2)
            and calculate how long it takes and make the timeout just longer than that
              ok, just so i am clear. in the js there are these values
              refreshInterval: 1000 * 60 * 10
              waitFetch: 1000 * 5,
              glanceTime: 1000 * 60
              popoverTimeout: 1000 * 30
              so are you saying when MM starts, the initial calendar population is controlled by the popover timeout? it seems like the interval of fetching calendar data is about 5 mins.
              for reference,
              npm start at [27.04.2024 22:49.21.737]
              [27.04.2024 22:50.39.725] [LOG] Create new calendarfetcher for url: http://www.xxxxxxxx.ics - Interval: 300000
              [27.04.2024 22:50.49.003] [INFO] Calendar-Fetcher: Broadcasting 21 events from http://www.xxxxxxxx
              then it happens again 5 mins later and then 5 mins later again
                @captheavenger the ext3 modules fo not read the ics data at all. they let the default(or other) calendar modules do that.
                the calendar module then broadcasts the data to whoever might be interested.
                ext3
                so wait fetch is the number.
                but if it takes 5 minutes …
                  @sdetweil ok hopefully last question and thanks for the help
                  that wait fetch is that just the first time it checks for calendar info or every time?
                  and bonus question, what if i set it to 2 minutes…is there any downside to checking more often?
                  3 calendars in total
                  28 events
                  27 events
                  1404 events (thats the primary calendar)
