    Open weather Api 3.0
    16 Posts 4 Posters 7.3k Views 5 Watching
      sdetweil @Peter
      @Peter the same config.js has entries for weather (Openweather is the default provider)
      just add the property
      apiVersion: ‘3.0’,
      and replace the other property values with yours
      the doc for weather is here
      https://docs.magicmirror.builders/modules/weather.html
      you do not need to specify anything that is the same as the doc indicates (like provider)
      as the design is your config.js overrides the defaults for a module.
      read the two links in my signature below. I didn’t write them, they are very helpful
        sdetweil @Peter
        @Peter free for limited number of calls per day
        P 2 Replies Last reply Reply Quote 0
          Peter @sdetweil
          @sdetweil after adding the version to my config, the weather module does not start.
          module: “weather”,
          position: “top_right”,
          weatherProvider: “openweathermap”,
          apiVersion: ‘3.0’,
          type: “current”,
          locationID: “2759705”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          apiKey: “xxxxxxxxxxxxxxxxxxxxxxxxxxkey removed”
          It works fine with Api 2.5, but do I need lat, lon instead of Location and Locatio ID?
          It is confusing.
          Peter
            Peter @sdetweil
            @sdetweil what does this limited number mean?
            If I use the default settings do I stay under the limit?
            Peter
              sdetweil @Peter
              @Peter there are multiple providers under weather, some need locationId, some need location name, some need lat/lon
              the top section of the doc applies to all providers, and further down is specifics for each provider
              if it works, then it works.
              limited calls per day 1000 I think., so their doc says
              divide seconds per day by 1000
              stay under that rate.
              we will next release fixes July 1, every 90 days
                Peter @sdetweil
                @sdetweil thanks for your help but I cannot get it working.
                Maybe somebody else has an idea how to get it working?
                Peter
                  sdetweil @Peter
                  @Peter I took the sample
                  and added my 3.0 api key… no other changes, I commented out provider as openweather is the default
                  my 2.5 key did not work
                        module: "weather",
                        header: "Weather Forecast",
                          //weatherProvider: "openweathermap",
                          type: "forecast",
                          locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          apiKey: "mykey"
                          module: "weather",
                          config: {  // type:"current is default"
                            apiKey: "mykey",
                  sorry, had some funky icons in test…
                  also had three instances, picked wrong 2… forecast first, current second
                    Peter @sdetweil
                    @sdetweil ok, I did the same, so I removed apiVersion:‘3.0’, now it works.
                    But how can I see if it works on version 2.5 or version 3.0?
                    And how do I recognise a version 3.0 Api key?
                    On the site of Openweather I have several Api keys, but how to recognise a version 3.0?
                    Peter
                      sdetweil @Peter
                      @Peter they don’t tell you. I have many as well.
                      they will tell you to try it… not much use
                      version 3 is only one endpoint, onecall
                      I don’t know how to force the module like that, it changes the endpoint based on the type (current, forecast…)
                        Peter @sdetweil
                        @sdetweil ok, I will see what happens when 2.5 stops working.
                        Have a nice day.
                        Peter
