    MagicMirror (vers:2.27) : split Error - 07May2024
    6 Posts 2 Posters 910 Views 2 Watching
    • N
      nkc
      MagicMirror (vers:2.27.0) : split error occurs on every single module - 07May2024
      Hello;
      I have had troubles getting MM up - it was all working normal until it just crached - wth error as attached below :
      magicmirror@2.27.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js run dev
      [2024-05-07 09:21:07.079] [LOG] Starting MagicMirror: v2.27.0
      [2024-05-07 09:21:07.144] [LOG] Loading config …
      [2024-05-07 09:21:07.157] [LOG] config template file not exists, no envsubst
      [2024-05-07 09:21:07.197] [LOG] Loading module helpers …
      [2024-05-07 09:21:07.202] [LOG] No helper found for module: clock.
      [2024-05-07 09:21:08.086] [ERROR] (node:27333) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘split’)
      at loadModule (/home/pi/MagicMirror/js/app.js:156:27)
      at loadModules (/home/pi/MagicMirror/js/app.js:213:10)
      at async App.start (/home/pi/MagicMirror/js/app.js:261:3)
      (Use electron --trace-warnings ... to show where the warning was created)
      [2024-05-07 09:21:08.089] [ERROR] (node:27333) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [2024-05-07 09:21:17.744] [INFO] System information:
      SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
      OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.47-v7+
      VERSIONS: electron: 29.3.2; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
      OTHER: timeZone: Australia/Sydney; ELECTRON_ENABLE_GPU: undefined
      It crashes on every single module - I tested it by just having one module in the modules folder and the error above is same for all the modules. Here I have tested with ‘clock’ - and hence the errors above.
      The MM does not start.
      Can you please advise on how to fix the above issue.
      Thank you.
      Regards,
      Neel
      • N
        nkc @sdetweil
        @sdetweil - Hi - I have re-installed a clean version of MM ver 2.27 again (the third time) - And the modules have worked.
        Thank you for your time.
        I will press on to install other modules and test them.
        Thanks.
          sdetweil @nkc
          @nkc can u show me the modules/default folder
          ls
            @nkc what happened before this?
            • N
              nkc @sdetweil
              @sdetweil - The modules default folder - as of after installing MM 2.27 from your script raspberrypi.sh ;
              pi@raspi:~/MagicMirror/modules/default $ ls -l
              total 40
              drwxr-xr-x 5 pi pi 4096 May 7 08:10 alert
              drwxr-xr-x 3 pi pi 4096 May 7 08:10 clock
              drwxr-xr-x 2 pi pi 4096 May 7 08:10 compliments
              -rw-r–r-- 1 pi pi 395 May 7 08:10 defaultmodules.js
              drwxr-xr-x 2 pi pi 4096 May 7 08:10 helloworld
              drwxr-xr-x 2 pi pi 4096 May 7 08:10 newsfeed
              drwxr-xr-x 2 pi pi 4096 May 7 08:10 updatenotification
              -rw-r–r-- 1 pi pi 5855 May 7 08:10 utils.js
              drwxr-xr-x 3 pi pi 4096 May 7 08:10 weather
              Before this - It was on MM 2.25 and then I installed MM 2.27 with the script.
              Thanks,
              Regards,
              Neel.
                sdetweil @nkc
                @nkc my upgrade script?
                can you examine your config.js and look for any module
                that does NOT have that exact spelling
                all lowercase
                module
                • N
                  nkc @sdetweil
                  Thanks.
