    Internet-Monitor display issue
    6 Posts 2 Posters 787 Views 2 Watching
      Richtw
      I installed the internet-monitor module from https://github.com/BrianHepler/internet-monitor .
      It’s working fine and showing me speed for wifi or ethernet connections.
      But on the screen I don’t get the labels above the two graphics that should say “Download Speed” and “Upload Speed”, and while I get the color and arc that shows the speed, I don’t get the white portion that completes the semi-circle.
      I don’t see any option to turn the labels on or off and I am not seeing any error messages.
      Wondering if anyone else had this issue?
        sdetweil @Richtw
        @Richtw what position did you put it in?
          Richtw
          thanks for asking
          here is the portion of my config file for this module.
          I tried changing it to “top_center” but it did not make a difference
                                 module: 'internet-monitor',
                                 position: 'bottom_right',
                                 header: 'Internet Monitor',
                                 config:{
                                     type: '',
                                     maxTime: 20000,
                                     updateInterval:3600000,
                                     verbose: false,
                                     serverId: '',
                                     displayStrength: false,
                                     displaySpeed: true,
                                     strengthIconSize: 80,
                                     maxGaugeScale: 1000,
            Richtw @Richtw
            just a quick follow-up: I created a VirtualBox instance with Debian and installed MagicMirror. the only extra module I added was the internet-monitor.
            I set it for top_center.
            the result is the same as I see on the pi - no labels on the gauges and the arc is only filled in for the colored part that indicates speed.
            I am thinking it’s not an install error but some kind of issue with the package…perhaps an incompatibility with other updates?
              sdetweil @Richtw
              @Richtw
              did you do the npm install in the module folder?
                Richtw
                yes, for both of them
                It does throw some warnings that I captured earlier:
                rich@raspberrypi:~/MagicMirror/modules/internet-monitor $ npm install
                added 359 packages, and audited 360 packages in 38s
                99 packages are looking for funding
                run npm fund for details
                5 vulnerabilities (2 moderate, 3 high)
                Some issues need review, and may require choosing
                a different dependency.
                Run npm audit for details.
                this happened on both the pi installation and the debian vbox version.
                I ran the audit on the pi version:
                npm audit report
                got <=11.8.3
                Severity: high
                Got allows a redirect to a UNIX socket - https://github.com/advisories/GHSA-pfrx-2q88-qq97
                Depends on vulnerable versions of cacheable-request
                No fix available
                node_modules/got
                download >=4.0.0
                Depends on vulnerable versions of got
                node_modules/download
                @lh2020/speedtest-net *
                Depends on vulnerable versions of download
                node_modules/speedtest-net
                http-cache-semantics <4.1.1
                Severity: high
                http-cache-semantics vulnerable to Regular Expression Denial of Service - https://github.com/advisories/GHSA-rc47-6667-2j5j
                No fix available
                node_modules/http-cache-semantics
                cacheable-request 0.1.0 - 2.1.4
                Depends on vulnerable versions of http-cache-semantics
                node_modules/cacheable-request
