    Trying to create a white background with black text to the clock module title block.
    15 Posts 2 Posters 14.6k Views 2 Watching
      synint Project Sponsor @sdetweil
      His Sam applied the changes as detailed below but it still has not added a white background,
      /* Custom CSS Sample
       * Change color and fonts here.
       * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
      /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
      /* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap'); */
      :root {
        --color-text: #000;
        --color-text-dimmed: #000;
        --color-text-bright: #000;
        --color-background: black;
        --font-primary: "Roboto Condensed";
        --font-secondary: "Roboto";
        --font-size: 20px;
        --font-size-small: 0.75rem;
        --gap-body-top: 60px;
        --gap-body-right: 60px;
        --gap-body-bottom: 60px;
        --gap-body-left: 60px;
        --gap-modules: 30px;
      .clock {
         background-color:white;
         border-radius:8px;
         padding:8px;
      .clock .time{
       	color: black;
        sdetweil @synint
        @synint lack of a closing } on the root entry causes an error and the rest of the css is not processed
        I would NOT override the root… as it affects EVERY module…
          @synint I re-read your original post
          you said clock title block…
          what is that ? the header? (which is optional and not used on the clock)
            Hi Sam,
            I thought it would be easier if I showed an image of my MagicMirror screen and explain what I mean.
            As you can see the clock text top left of the image covers the image and when the image has a light background you can not see/read the text easily. So I would like to make the background of the text white with say 50% opacity and the text black. I have also added below the last CSS.Custom file but still not showing white background.
            CSS Custom file
            .module.clock (
               background-color:rgba(255,255,255,0.5);
               border-radius:8px;
               padding:8px;
            Cheers,
            John
            S 2 Replies Last reply
              sdetweil @synint
              @synint yes try mine instead
              Also add, after .time
              , .date
                sdetweil @synint
                @synint tge stuff before the open brace {
                is called the selector clause
                it selects the elements the stuff inside the braces will be applied to
                .module.clock
                on the elements with BOTH classes ( no space between them)… AND ONLY THOSE elements
                but (it, only one) doesn’t have text or a background
                Mine says
                for the elements within class .clock and below change its background.
                and secondly within .clock change the text color in .time
                  Hi Sam,
                  Thank you and based on your comments the clock is now working correctly.
                  I have 3 other modules I am trying to apply the same styling and using the CSS Customer file as detailed below I am getting the following visual appearance.
                  clock - Working
                  calendar - White box appears but text is also white
                  MMM-OpenmapWeather - No change to appearance
                  newsfeed - No change to appearance
                  .clock {
                     border-radius:8px;
                     padding:8px;
                  .clock .time, .date{
                   	color: black;
                  .calendar {
                     border-radius:8px;
                     padding:8px;
                  .calendar .calendar-check{
                   	color: black;
                  .MMM-OpenmapWeather {
                     border-radius:8px;
                     padding:8px;
                   	color: black;
                  .newsfeed {
                     border-radius:8px;
                     padding:8px;
                  .newsfeed {
                   	color: black;
                  Kind regards,
                  John
                    sdetweil @synint
                    @synint every module is different
                    many styles are not inherited from its parent
                    see this on how to use the developers window elements tab to find the classes and styles to use
                    https://forum.magicmirror.builders/post/90135
                      Hi Sam,
                      Thank you for the link and I am going to try and sort the style issue over the weekend.
                      I will let you know how I get on.
                      Cheers,
                      John
                        Hi Sam,
                        It has taken me some time but I have now managed to get white boxes around the module text. The white box was created adding additional lines of code to custom.css file see code below. However I was unable to change the text colour in the white boxes so ended up changing the root section of the main.css file see code below. I know you said do not change the root code but could not find any other way of changing font colour.
                        The one thing I would still like to do is remove image and date/time at the bottom right hand corner.
                        Cheers,
                        John
                        Custom CSS Code
                        .clock {
                           border-radius:8px;
                           padding:8px;
                        .clock .time{
                         	color: black;
                           border-radius:8px;
                           padding:8px;
                        .calendar {
                           border-radius:8px;
                           padding:8px;
                        .newsfeed {
                           border-radius:8px;
                           padding:8px;
                        .newsfeed .module-content{
                           color: black;
                        main.css file code
                        :root {
                          --color-text: #OOOOOO;
                          --color-text-dimmed: #OOOOOO;
                          --color-text-bright: #OOOOOO;
                          --color-background: #000;
                          --font-size: 20px;
                          --font-size-xsmall: 0.75rem;
                          --font-size-small: 1rem;
                          --font-size-medium: 1.5rem;
                          --font-size-large: 3.25rem;
                          --font-size-xlarge: 3.75rem;
                        ![0_1715368462168_20240510_200104-01.jpeg](Uploading 34%)
                        S S 2 Replies Last reply
                          synint Project Sponsor @synint
                          Did not attach image on past post.
                            sdetweil @synint
                            @synint said in Trying to create a white background with black text to the clock module title block.:
                            just copy that root section to custom.css
                            then modify.
                            again the developers window should make quick work of finding the right selector and style setting
