    MMM-Buttons to change pages
    7 Posts 3 Posters 1.2k Views 3 Watching
      Jimmy1502
      Hi, i wanna use a physical button to change the pages. Is this right?
                              module: 'MMM-Buttons',
                                      buttons: [
                                              pin: 26,
                                              shortPress: {
                                                      notification: "PAGE_INCREMENT",
                                                      payload: 1,
                                              shortPress: undefined
        Jimmy1502 @sdetweil
        @sdetweil Thx for your help! Kinda dumb mistake :(
        But here for the rest. This code was working:
                                        buttons: [
                                                pin: 26,
                                                shortPress: {
                                                        payload: 1,
          sdetweil @Jimmy1502
          @Jimmy1502 said in MMM-Buttons to change pages:
                                              shortPress: {
                                                      payload: 1,
          because you have shortPress defined twice, the last occurance wins…
          but other than that, looks on
          J 1 Reply Last reply
            Jimmy1502 @sdetweil
                                            buttons: [
                                                    pin: 26,
                                                    shortPress: {
                                                            payload: 1,
            • J Jimmy1502 has marked this topic as solved on
              captheavenger
              can i ask what kind of buttons/wiring you used? did you use a breadboard or just go straight to the pins?
              My coding and modules are done so i’m at the “physical” point
              thanks
                Jimmy1502 @captheavenger
                @captheavenger hi i just used a wire (with special connectors) to directly connect the 3.3V pin to the other gpio pin. It was just for testing purpose. I bought a button but i need to solder wires to it.
                C 1 Reply Last reply
                  captheavenger @Jimmy1502
                  @Jimmy1502
                  gotcha, so i’m going to purchase a couple of 30mm arcade buttons to put on the side of the frame. my question is what type of wire would you recommend to connect the button to the pi?
                  i’m not sure of the terminology of how to describe the connectors. so when you say special connectors i think thats the info i’m missing
                  thanks!
                    sdetweil @captheavenger
                    @captheavenger they sell wires with the GPIO pin sockets, the other end could be male or female, just clip that off and extend with anything…
                    I have a spool of 20ga wire…
