    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 78.3k Views 11 Watching
    • JakobudJ
      Jakobud @sdetweil
      @sdetweil Okay which one do you use specifically?
        sdetweil @Jakobud
        @Jakobud the top one on that page
        D 1 Reply Last reply
          davidgagne @sdetweil
          @sdetweil I am ripping my hair out trying to get MM running on a Pi Zero W. I’ve followed all of your (super helpful) suggestions across multiple posts, but no matter what I do, I keep getting:
          [PM2][ERROR] File ecosystem.config.js not found
          any time I try to execute pm2 start.
          I’ve run your upgrade / update scripts from github, I’ve removed Chromium and replaced it with Firefox, I’ve uninstalled and reinstalled ten different flavors of the PiOS, I’ve tried the MagicMirrorOS that someone else posted, etc. All with no luck.
          Do you have any ideas what could be the problem here?
          Thanks in advance,
          dvg
            sdetweil @davidgagne
            @davidgagne said in Raspberry Pi Zero 2 W for Magic Mirror:
            File ecosystem.config.js no found
            well, I haven’t seen that…, BUT it sounds like from a google search thgat you have the wrong node js version installed…
            but
            flash the sd card… its a pi02W, a 3 in pi0 form factor
            then run my install script. don’t dop anything else first
            you can try to see if you can fixup pm2 first…
            pm2 stop all
            pm2 status
            this will display a line
            pi@raspberrypi42:~ $ pm2 status
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
            you can use the name or number on any line
            pm2 delete 0
            pm2 save -f
            then run
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
            to recreate the app in pm2.
            lets see…
            else redo the install as above
              @sdetweil said in Raspberry Pi Zero 2 W for Magic Mirror:
              I’m sorry but I don’t understand what this means. Which PiOS should I flash? I have been trying with the Legacy, 32-bit.
              (If it makes a difference, I actually have a Raspberry Pi Zero W Rev 1.1. I don’t think it’s a 2.)
              Thank you!
                @davidgagne ok, if it IS a pi0W, then 32 bit legacy image
                flash sd card, boot to the desktop, use terminal window or ssh
                then my install script.
                they have removed the chromium browser, for armv6l, so you will have to use firefox or one of the others… midori or surf
                so YOU MUST use the environment variable in
                ~/MagicMirror/installers/mm.sh to set the browser to use ( all have to be installed manually)
                  @sdetweil Okay. I’m doing this right now.
                  1. Flashed card with Legacy 32-bit.
                  2. Connected via ssh to run your script.
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                    Answered yes to disable screen saver and use pm2 questions.
                  3. Removed chromium with:
                    sudo apt-get remove chromium-browser
                    sudo apt autoremove
                  4. Added Firefox with:
                    sudo apt-get update
                    sudo apt-get install firefox-esr
                  5. Enabled VNC using sudo raspi-config GUI
                  6. Connect via TigerVNC
                  7. Edit mm.sh via VNC in Pi's baked-in text editor by adding:
                    export external_browser=firefox
                    DISPLAY=:0 npm start
                  8. sudo reboot
                  9. Connect via ssh
                  10. cd MagicMirror
                    pm2 start MagicMirror
                  11. And now -- finally! -- some progress:
                    [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                    [PM2] PM2 Successfully daemonized
                    [PM2][ERROR] Script not found: /home/dvg/MagicMirror/MagicMirror
                  So … now what have I done wrong? What script is missing?
                    @davidgagne well…
                    it seems the pm2 setup failed for some reason
                    can you send me the ~/install.log
                    my same userid at Gmail.
                    you didn’t have to vnc to edit, nano works over ssh.
                    because the pm2 setup was not completed,
                    when you did pm2 start from the MagicMirror folder, it was trying to create the app MagicMirror command
                    /home/username/MagicMirror/MagicMirror
                    can you try to run the fixuppm2 script from my scripts page
                      @sdetweil Here’s what I got after running your fixup script:
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                      │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 27952    │ 0s     │ 1    │ online    │ 0%       │ 2.5mb    │ dvg      │ enabled  │
                      [PM2] Saving current process list...
                      [PM2] Successfully saved in /home/dvg/.pm2/dump.pm2
                      I’ll email install.log to you as soon as I can figure out how to … find and copy the install log.
                      S 2 Replies Last reply
                        @davidgagne and MagicMirror should have come up using firefox
                          you should install one of the windows ssh clients tools. Winscp or Bitvise ssh clients.
                          they provide the typical ssh terminal AND also a windows file manager view of the remote system.
                          so you can double click to edit on windows and automatically save the file back.
                          bitvise also provides drag and drop file copy support to/from the remote system… for logs and credential files
                          I use notepad++ or visual studio code to edit on windows.
                          such a time saver!!
                            @sdetweil I am not going to bother sending you the install log because it worked!
                            It took a long time to launch, but now I can see MagicMirror running when I VNC into the Pi.
                            After running your fixuppm2 script I executed pm2 start MagicMirror and got this:
                            [PM2] Process successfully started
                            │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 28553    │ 0s     │ 2    │ online    │ 0%       │ 2.5mb    │ dvg      │ disabled │
                            Now when I VNC into the Pi I see it running! So far the date and time is the only thing correctly displaying, but at least now MagicMirror is running. Thank you!
                              @davidgagne I am interested in the log to see why the inline pm2 setup failed.
                              yes, pi0w is not fast.
                              the default calendar and weather take configuration before they produce output.
                                @davidgagne you can also adjust the MagicMirror config so you can open your windows browser to see it too.
                                  @sdetweil I’m an Apple user. I am sure there’s something similar, though. Thanks.
                                    @sdetweil It looks like I spoke too soon. After a reboot, I cannot seem to get any output from MagicMirror.
                                    I rebooted and then called pm2 start MagicMirror from within the MagicMirror directory, and it seems to execute just fine. But … nothing happens. It doesn’t actually start the app, as far as I can tell. Even though the output seems the same:
                                    │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 4592     │ 1s     │ 148  │ online    │ 0%       │ 27.4mb   │ dvg      │ disabled │
                                    Any ideas?
                                      @davidgagne pm2 logs --lines=75
                                        @davidgagne that circle with the arrow heading column says times restarted. 148 is a problem
                                        D 2 Replies Last reply
                                          @sdetweil I emailed you the output from that. I’m guessing Error: Cannot find module 'electron' is bad?
                                            @sdetweil It’s frustrating because I swear it was working before I rebooted.
                                            • 1 / 4
