    MMM-MealieMenu Fetch Error
    30 Posts 3 Posters 12.3k Views 3 Watching
      sdetweil @WallysWellies
      @WallysWellies i have watchtower maintain all my docker stacks
      W 1 Reply Last reply
      • W
        WallysWellies @sdetweil
        @sdetweil I’ll look into it, thanks.
        • zanixZ
          zanix
          I normally use an API key but I just tried my username/password and it worked. I’m on Mealie 1.7.0.
          Go ahead and restart MM and see if that works.
          Are you on the latest MMM-MealieMenu (1.5.0)? I added an additional log when the auth token fetch fails.
          • zanixZ
            zanix
            I just realized this error occurs when the meal plan is fetched. I wonder if the auth token is expiring.
            • W
              WallysWellies @zanix
              @zanix Restarting the MM service fixed the issue with no additional steps so it may well be an expiring token or something.
              I have updated the Mealie container so I am now on v1.7.0 and switched to using the API key for auth. I have also checked and I am using the current version of your module, v1.5.0.
              I’ll report back if anything interesting happens. Thanks again for your advice.
              zanixZ 1 Reply Last reply
              • zanixZ
                zanix @WallysWellies
                @WallysWellies Thanks!
                I think the token does expire. I just checked the token on my instance and it expires 1 month from now.
                I will work on fixing that soon.
                • zanixZ
                  zanix
                  @WallysWellies I just updated the module to account for token expiration.
                  It took me a bit to test since I needed to let the token expire to make sure it worked.
                  W 3 Replies Last reply
                  • W
                    @zanix that’s dedication, thanks!
                    I see the update notification so I’ll get it updated tonight. Cheers.
                    • W
                      @zanix Hi Zanix. Just updated the module and all meal entries now seem to use the default image. I updated the docker image in case that was the problem but they’re all still showing the default orange image.
                      Possible bug introduced in the latest release?
                      • W
                        @zanix Sorry, ignore me - it seems to only be using default images on my laptop. On the actual screen it’s showing the images. Maybe it’s something to do with resolution or something. Apologies.
                        • zanixZ
                          @WallysWellies I opened MM on my desktop (MM runs on a Pi5) and I can see the meal images.
                          The default image only displays when the meal image cannot load. Maybe the URL of the images isn’t accessible on your laptop?
                          • W
                            @zanix You are correct. Looking in the console it’s trying to load from localhost. I’m not greatly fussed but one day I might look into where I can fix that.
                            Cheers!
                            • zanixZ
                              @WallysWellies Are you running MM and Mealie on the same computer? And do you have the MMM-Mealie URL set as localhost?
                              If so, try changing the MMM-Mealie URL to the IP address of the computer it’s running on.
