    MMM-MealieMenu Fetch Error
    30 Posts 3 Posters 12.3k Views 3 Watching
    • W
      WallysWellies
      • I have found the part of Mealie that allows creation of an API key so I could switch to that method for authentication.
      • I also see I am a couple of versions behind the Mealie master branch (I use version 1.5.1 - current version is 1.7.0). That looks drastic but it’s only 2 releases behind.
      I don’t think either of these things are causing my issue necessarily but it’s a couple of things I can change soon.
        sdetweil @WallysWellies
        @WallysWellies are you using watchtower to keep. your containers up to date?
        W 1 Reply Last reply
        • W
          WallysWellies @sdetweil
          @sdetweil Mealie is the first time I’ve used docker so it’s totally manual. I’ve never tried to update it - it was setup within the last couple of months.
          I was planning to do the update based on the Mealie docs but I could look into watchtower.
            @WallysWellies i have watchtower maintain all my docker stacks
            • W
              @sdetweil I’ll look into it, thanks.
              • zanixZ
                zanix
                I normally use an API key but I just tried my username/password and it worked. I’m on Mealie 1.7.0.
                Go ahead and restart MM and see if that works.
                Are you on the latest MMM-MealieMenu (1.5.0)? I added an additional log when the auth token fetch fails.
                • zanixZ
                  zanix
                  I just realized this error occurs when the meal plan is fetched. I wonder if the auth token is expiring.
                  • W
                    WallysWellies @zanix
                    @zanix Restarting the MM service fixed the issue with no additional steps so it may well be an expiring token or something.
                    I have updated the Mealie container so I am now on v1.7.0 and switched to using the API key for auth. I have also checked and I am using the current version of your module, v1.5.0.
                    I’ll report back if anything interesting happens. Thanks again for your advice.
                    zanixZ 1 Reply Last reply
                    • zanixZ
                      zanix @WallysWellies
                      @WallysWellies Thanks!
                      I think the token does expire. I just checked the token on my instance and it expires 1 month from now.
                      I will work on fixing that soon.
                      • zanixZ
                        zanix
                        @WallysWellies I just updated the module to account for token expiration.
                        It took me a bit to test since I needed to let the token expire to make sure it worked.
                        W 3 Replies Last reply
                        • W
                          @zanix that’s dedication, thanks!
                          I see the update notification so I’ll get it updated tonight. Cheers.
                          • W
                            @zanix Hi Zanix. Just updated the module and all meal entries now seem to use the default image. I updated the docker image in case that was the problem but they’re all still showing the default orange image.
                            Possible bug introduced in the latest release?
                            • W
                              @zanix Sorry, ignore me - it seems to only be using default images on my laptop. On the actual screen it’s showing the images. Maybe it’s something to do with resolution or something. Apologies.
                              • zanixZ
                                @WallysWellies I opened MM on my desktop (MM runs on a Pi5) and I can see the meal images.
                                The default image only displays when the meal image cannot load. Maybe the URL of the images isn’t accessible on your laptop?
                                • W
                                  @zanix You are correct. Looking in the console it’s trying to load from localhost. I’m not greatly fussed but one day I might look into where I can fix that.
                                  Cheers!
                                  • zanixZ
                                    @WallysWellies Are you running MM and Mealie on the same computer? And do you have the MMM-Mealie URL set as localhost?
                                    If so, try changing the MMM-Mealie URL to the IP address of the computer it’s running on.
