    MMM-MealieMenu Fetch Error
    30 Posts 3 Posters 12.3k Views 3 Watching
    • W
      WallysWellies @zanix
      @zanix Thanks for your input :)
      I made the change after posting and it certainly doesn’t break anything but I have been playing with some other modules too so have restarted the software several times meaning I haven’t given it a chance to error but based on my understanding it probably shouldn’t anymore. I don’t know why it was in the first place though - the Mealie container is on the Pi so it’s using localhost to retrieve data. Who knows.
      I did make one other change because I wanted to see the next week of meals, rather than the remaining meals this week. So I changed this line:
      const startOfWeek = this.getFirstDayOfWeek(config.weekStartsOnMonday);
      to this:
      const startOfWeek = moment();
      It’s pretty crude but if you’re taking suggestions it might be nice to have the option to show x number of days in the future rather than until the end of the week. I don’t believe that’s currently possible natively?
      Thanks for the module though, it’s great!
      zanixZ 1 Reply Last reply
      • zanixZ
        zanix @WallysWellies
        @WallysWellies said in MMM-MealieMenu Fetch Error:
        Hopefully that fixes the issue, let me know otherwise.
        to this:
        Before now no, but I did just add the fetch fix, updateInterval default to 1 hour, and some additional meal entry options in version 1.5.0.
        The options are:
        • currentWeek: Only show meals for the current week.
        • dayLimit: How many days will be displayed after today.
        • entryLimit: How many entries from future days should be shown in total.
        Now you can just set currentWeek to false to get the same effect.
        I appreciate that, glad it’s useful!
        • W
          WallysWellies
          @zanix The mealie module has been in an error since yesterday and I wonder if you might be able to help me troubleshoot?
          I have run the following command:
          tail -100 .pm2/logs/mm-error.log
          And at the end I see the following:
          [2024-05-31 16:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 17:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 18:47:51.581] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 19:47:51.590] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 20:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 21:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 22:47:51.582] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-05-31 23:47:51.574] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 00:47:51.604] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 01:47:51.601] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 02:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 03:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 04:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 05:47:51.575] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 06:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 07:47:51.571] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 08:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 09:47:51.572] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 10:47:51.577] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 11:47:51.576] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 12:47:51.568] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          [2024-06-01 13:47:51.580] [ERROR] [MMM-MealieMenu] Fetch error: "Unauthorized"
          I have confirmed that the correct username / password is in my config.js file (and it has worked previously) - I can login via my laptop using http://raspberrypi:9925/ using these credentials.
          The config.js file is using the following line for the connection:
          host: "http://localhost:9925"
          I use browser / terminal / SSH etc. to access the Pi but if necessary I can connect a keyboard / mouse if that would aid in narrowing down the issue.
          Do you have any thoughts? I can probably just restart the mirror service but I haven’t yet in case that deletes any valuable information. Any advice would be appreciated.
          • W
            WallysWellies
            • I have found the part of Mealie that allows creation of an API key so I could switch to that method for authentication.
            • I also see I am a couple of versions behind the Mealie master branch (I use version 1.5.1 - current version is 1.7.0). That looks drastic but it’s only 2 releases behind.
            I don’t think either of these things are causing my issue necessarily but it’s a couple of things I can change soon.
              sdetweil @WallysWellies
              @WallysWellies are you using watchtower to keep. your containers up to date?
              W 1 Reply Last reply
              • W
                WallysWellies @sdetweil
                @sdetweil Mealie is the first time I’ve used docker so it’s totally manual. I’ve never tried to update it - it was setup within the last couple of months.
                I was planning to do the update based on the Mealie docs but I could look into watchtower.
                  @WallysWellies i have watchtower maintain all my docker stacks
                  • W
                    @sdetweil I’ll look into it, thanks.
                    • zanixZ
                      zanix
                      I normally use an API key but I just tried my username/password and it worked. I’m on Mealie 1.7.0.
                      Go ahead and restart MM and see if that works.
                      Are you on the latest MMM-MealieMenu (1.5.0)? I added an additional log when the auth token fetch fails.
                      • zanixZ
                        zanix
                        I just realized this error occurs when the meal plan is fetched. I wonder if the auth token is expiring.
                        • W
                          @zanix Restarting the MM service fixed the issue with no additional steps so it may well be an expiring token or something.
                          I have updated the Mealie container so I am now on v1.7.0 and switched to using the API key for auth. I have also checked and I am using the current version of your module, v1.5.0.
                          I’ll report back if anything interesting happens. Thanks again for your advice.
                          • zanixZ
                            @WallysWellies Thanks!
                            I think the token does expire. I just checked the token on my instance and it expires 1 month from now.
                            I will work on fixing that soon.
                            • zanixZ
                              zanix
                              @WallysWellies I just updated the module to account for token expiration.
                              It took me a bit to test since I needed to let the token expire to make sure it worked.
                              W 3 Replies Last reply
                              • W
                                @zanix that’s dedication, thanks!
                                I see the update notification so I’ll get it updated tonight. Cheers.
                                • W
                                  @zanix Hi Zanix. Just updated the module and all meal entries now seem to use the default image. I updated the docker image in case that was the problem but they’re all still showing the default orange image.
                                  Possible bug introduced in the latest release?
                                  • W
                                    @zanix Sorry, ignore me - it seems to only be using default images on my laptop. On the actual screen it’s showing the images. Maybe it’s something to do with resolution or something. Apologies.
                                    • zanixZ
                                      @WallysWellies I opened MM on my desktop (MM runs on a Pi5) and I can see the meal images.
                                      The default image only displays when the meal image cannot load. Maybe the URL of the images isn’t accessible on your laptop?
                                      • W
                                        @zanix You are correct. Looking in the console it’s trying to load from localhost. I’m not greatly fussed but one day I might look into where I can fix that.
                                        Cheers!
                                        • zanixZ
                                          @WallysWellies Are you running MM and Mealie on the same computer? And do you have the MMM-Mealie URL set as localhost?
                                          If so, try changing the MMM-Mealie URL to the IP address of the computer it’s running on.
