    problem with update magicmirror
    9 Posts 2 Posters 996 Views 2 Watching
      benoit73
      hello,
      i have a problem with magicmirror update.
      i think the repository in /etc/apt/source.list is not good but i don’t know what i write in.
      Sans-titre
        sdetweil @benoit73
        @benoit73 how did you try to update?
        what made you want to update?
        why are you using root? (sudo su)
        should be user
        NEVER use sudo for MagicMirror commands (npm, git)
          benoit73 @sdetweil
          OK but i just hae tried to configure one module and when i lauch npm install command it’s show npm : command not found.
          I precise i not using root
            sdetweil @benoit73
            @benoit73 where did npm go ?
            can you show output
            npm install
            thanks
              benoit73 @sdetweil
              Sans-titre
                benoit73 @benoit73
                how can i install npm ?
                  sdetweil @benoit73
                  @benoit73 if you were installing, my script would handle that (maybe, sometimes the system is screwed up)
                  maybe my upgrade script will fix it?
                  see https://github.com/sdetweil/MagicMirror_scripts
                  never had it disappear before
                  run the upgrade with the parm
                  force
                  instead of
                  apply
                  backup first
                  see https://github.com/sdetweil/MagicMirror-backup-restore
                    benoit73 @sdetweil
                    @sdetweil It’s ok work it !
                    Now how can i rotate screen to 90 ° ? I don’t find the files
                      sdetweil @benoit73
                      @benoit73 use the desktop menu, preferences, display configuration
