    problem with module MMM-Pollen-FR on github
    7 Posts 2 Posters 738 Views 2 Watching
      benoit73
      helo,
      i have a problem mith this module.
      I explain, i copy and paste the webcode just below in config.js file but magimirror indicate an error with this script.
      anyone have an idea ?
          module: "MMM-Pollen-FR",
          header: "Météo Pollen France",
              updateInterval: 3 * 60 * 60 * 1000, // every 3 hours
              region_code: "59",
              minLevel: 0
        sdetweil @benoit73
        @benoit73 please alwya use the code block for config or log output
        this preserves formatting (indentation and quotes), and minimizes long outputs to scrollable sections, which allows us to see better your questions away from all the other data
        in the forum message editor,
        paste the text you want to share
        blank line above and below
        select the text you just pasted
        then hit the </> button above the editor
        (you can have multiple code blocks in a message)
        can you please run the config checker and output its error messages
        npm run config:check
          benoit73 @sdetweil
          pi@raspberrypi:~/MagicMirror $ npm run config:check
          > magicmirror@2.27.0 config:check
          > node js/check_config.js
          [2024-06-19 15:54:24.553] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
          [2024-06-19 15:54:24.602] [ERROR] Your configuration file contains syntax errors :(
          [2024-06-19 15:54:24.603] [ERROR] Line 143 column 8: Parsing error: Unexpected token :
          pi@raspberrypi:~/MagicMirror $ pi@raspberrypi:~/MagicMirror $ npm run config:check
          it’s the line of begining of module MMM-Pollen
            sdetweil @benoit73
            @benoit73 said in problem with module MMM-Pollen-FR on github:
            can you show lines 130-150
            please xxx out any sensitive info
              benoit73 @sdetweil
              @sdetweil said in problem with module MMM-Pollen-FR on github:
                  showLogos: true,
                  displayTime: 60 * 1000,
                  showStandings: true,
                  showTables: true,
                  showScorers: false,
                  scrollVertical: true,
                  language: 'en', // supported values are en, de, it
                                      module: "updatenotification",
                                      position: "top_bar"
                      region_code: "59",
                      minLevel: 0
              it’s beginin line 130
                sdetweil @benoit73
                yes, the author module example shows that it goes inside the modules:[ list
                        region_code: "59",
                        minLevel: 0
                but you already have that…
                you only need the module part
                   module:
                   position:
                   config:{
                  benoit73 @sdetweil
                  thank you it’s ok
