    Setting up auto display off during the night.
    2 Posts 2 Posters 1.1k Views 3 Watching
    • G Offline
      greatm8nate
      It seems that in recent months the commands used to control HDMI out on the Raspberry Pi have changed. Most guides I’ve found online do not work anymore.
      I just want to turn my display off at 8pm and turn it back on at 8am.
      So I set up a cron job;
      20 14 * * * pm2 stop mm
      21 14 * * * WAYLAND_DISPLAY="wayland-1" wlr-randr --output HDMI-A-1 --off
      22 14 * * * WAYLAND_DISPLAY="wayland-1" wlr-randr --output HDMI-A-1 --on
      23 14 * * * wlr-randr --output HDMI-A-1 transform 270
      24 14 * * * pm2 start mm
      The timing is one minute apart for testing.
      Line 1 stops magic mirror.
      Line 2 should turn the display off.
      Line 3 turns it back on.
      Line 4 correct the screen orientation to portrait (it is not saved).
      Line 5 restarts the software.
      That command on line 2 works when manually typed into the terminal, but the cron job cannot execute it for some reason. Here is the error log I collected for lines 2-4;
      error: XDG_RUNTIME_DIR is invalid or not set in the environment.
      failed to connect to display
      As far as I have researched, the cron job is not in the same environment as me (the user), so it cannot execute this command. How to I make the cron job write as if I am typing the command into the terminal?
      • karsten13K Offline
        karsten13 @greatm8nate
        @greatm8nate
        looks like XDG_RUNTIME_DIR is unset, so you can check what value contains this variable in your user environment by executing echo $XDG_RUNTIME_DIR in the terminal and then change
        to
        XDG_RUNTIME_DIR="value-from-above" WAYLAND_DISPLAY="wayland-1" wlr-randr --output HDMI-A-1 --off
