    MMM-OpenWeatherMapForecast 3.0 API calls and freeze issue
    21 Posts 5 Posters 4.8k Views 5 Watching
      jfields @sdetweil
      @sdetweil Thanks for the response. The freezing is not from exceeding the 1,000 API calls. The system is bogging down. I can watch it get worse over time by watching how often the seconds update on the clock. Also, I have a credit card on file and allow up to 2,000 call. I haven’t exceeded that but I have gone up to 1,700.
      I have reverted to using MMM-OpenWeatherMapForecast for just one call and that is working fine. I’m using the standard weather module for the rest of the calls.
      API calls
      pm2 status
      For the config.js, I copied the module section and pasted it above. Do you need more than that?
      I wasn’t sure what to grab from the console tab, but I did see some errors and grabbed those.
      Video of some error messages popping up. They were really flashing fast at first, hard to get a screen grab so I made a video. The longer it went, the more errors, and the longer you could see them. Something is compounding.
      https://imgur.com/a/QXU5SzI
      The longer it goes, the more errors I see.
      One of the POST error messages
        sdetweil @jfields
        @jfields which version of MMM-OpenWeatherMapForecast are you using?
        in the module folder do
        git remote -v
          jfields @sdetweil
          origin https://github.com/MarcLandis/MMM-OpenWeatherMapForecast.git (fetch)
          origin https://github.com/MarcLandis/MMM-OpenWeatherMapForecast.git (push)
            sdetweil @jfields
            @jfields that one is quite old
            I’d try this one, as the author is active
            https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
              jfields @sdetweil
              @sdetweil Thanks. I haven’t tried that one. I honestly only thought there were two, one that was way old and the one I’m using (MarcLandis). The one I’m using did get a recent update so it is somewhat supported, although I cannot open an Issue on it.
              From where I’m at now, I have a good working solution but using the MarcLandis version on one side and the built-in for everything else. If I do change, I will look at the Tom-Hirschberger version. It’s getting updates and has a tab to open Issues.
                sdetweil @jfields
                @jfields good debug on the multiple problem
                lets try this temp fix
                in the MM/js folder do
                curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror/fixloading/js/app.js >app.js
                stop and restart MM
                this adds a hash to check for loading or already loading the node_helper for this module
                S J 2 Replies Last reply Reply Quote 0
                  Socrates @sdetweil
                  Sorry to hijack this post. I can create a new one if needed. I’ve been using the “MMM-OpenWeatherMapForecast” module for a while, but for the past few weeks, it hasn’t been showing up on my MM. I’ve rebooted MM several times and made sure the module is up to date, but no luck.
                    sdetweil @Socrates
                    @Socrates
                    yes openweather changed their api
                    module needs update
                      jfields @sdetweil
                      @sdetweil Hello, been away for a bit. I ran the curl and added a couple of the OpenWeatherMapForecast calls back in. They’re showing nominally, time is updating regularly. No issues right now. I opened the browser developer window and it’s showing 3 errors and the count is not incrementing. Does this fixloading script stop errant calls? I’m not sure where to look for the logs. I’m using pm2 to start/stop/restart.
                        sdetweil @jfields
                        @jfields logs are captured by pm2
                        pm2 logs --lines=xxxx
                        xxxx is the number of lines to show
                        the curl loads a version of the MagicMirror file that now only loads the node helper once per module.
                        nothing else is changed
                          Rags @sdetweil
                          @sdetweil said in MMM-OpenWeatherMapForecast 3.0 API calls and freeze issue:
                          @Socrates
                          module needs update
                          Greetings fellow MagicMirror fans, I also noticed that the weather is not updating since a few days. I ran a git pull to update the module , it says already updated, but the module is not displaying the weather. DId i miss doing something . I have a free account and an api key. Need help to resolve this, Thanks.
                            sdetweil @Rags
                            @Rags open the developers window, curl-shift-I, select the console tab, and put wea in the filter field to see messages just from the weather module
                            You should see some error, maybe 401
                            They have dropped support for the older 2.5 spikes, you need a 3.0 key which requires a credit card
                              Rags @sdetweil
                              YIKES !
                              I had changed the helper module to
                              “var url = “https://api.openweathermap.org/data/3.0/onecall?” +” as suggested in an earlier post. I also changed the config.js with weatherEndpoint: “forecast/daily”. It still did not work.
                              So i am not comfortable to use a credit card for the website. So does it mean curtains for this module as far as “Free” is concerned.?
                                sdetweil @Rags
                                @Rags you didn’t need to edit the file
                                my erased comments were for the default weather module
                                yes, they give you 1000 api calls per day, no charge, but you must register a card
                                  jfields @sdetweil
                                  I turned two more MMM-OpenWeatherMapForecast sections for a couple days and left it running. No issues that I could see. Your script seems to have fixed it. I’ll probably go back to 4 standard weather sections and one MMM-OpenWeatherMapForecast. Thank you for your help though.
                                  Here are the logs.
                                  d39d1a38-1b43-4005-b081-ad66cb32cddb-image.png 0|mm | > magicmirror@2.28.0 start
                                  0|mm |
                                  0|mm | [2024-08-01 21:20:05.292] [LOG] Loading config …
                                  0|mm | [2024-08-01 21:20:05.299] [LOG] Loading module helpers …
                                  0|mm | [2024-08-01 21:20:05.301] [LOG] No helper found for module: alert.
                                  0|mm | [2024-08-01 21:20:05.310] [LOG] Initializing new module helper …
                                  0|mm | [2024-08-01 21:20:05.312] [LOG] No helper found for module: clock.
                                  0|mm | [2024-08-01 21:20:05.445] [LOG] Initializing new module helper …
                                  0|mm | [2024-08-01 21:20:05.445] [LOG] Module helper loaded: calendar
                                  0|mm | [2024-08-01 21:20:05.447] [LOG] No helper found for module: weather.
                                  0|mm | [2024-08-01 21:20:05.479] [LOG] Initializing new module helper …
                                  0|mm | [2024-08-01 21:20:05.771] [LOG] Initializing new module helper …
                                  0|mm | [2024-08-01 21:20:05.772] [LOG] All module helpers loaded.
                                  0|mm | [2024-08-01 21:20:05.782] [LOG] Starting server on port 8080 …
                                  0|mm | [2024-08-01 21:20:06.923] [LOG] Server started …
                                  0|mm | [2024-08-01 21:20:06.929] [LOG] Connecting socket for: calendar
                                  0|mm | [2024-08-01 21:20:06.930] [LOG] Starting node helper for: calendar
                                  0|mm | [2024-08-01 21:20:06.936] [LOG] Sockets connected & modules started …
                                  0|mm | [2024-08-01 21:20:07.302] [LOG] Launching application.
                                  0|mm | [2024-08-01 21:20:08.895] [INFO] System information:
                                  0|mm | ### SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
                                  0|mm | [2024-08-01 21:20:11.736] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-01 21:20:13.338] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                  0|mm |
                                  0|mm | [2024-08-01 21:20:05.264] [LOG] Starting MagicMirror: v2.28.0
                                  0|mm | [2024-08-01 21:20:05.295] [LOG] config template file not exists, no envsubst
                                  0|mm | [2024-08-01 21:20:05.311] [LOG] Module helper loaded: updatenotification
                                  0|mm | [2024-08-01 21:20:05.479] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
                                  0|mm | [2024-08-01 21:20:05.772] [LOG] Module helper loaded: MMM-SunRiseSet
                                  0|mm | [2024-08-01 21:20:06.926] [LOG] Connecting socket for: updatenotification
                                  0|mm | [2024-08-01 21:20:06.927] [LOG] Starting module helper: updatenotification
                                  0|mm | [2024-08-01 21:20:06.930] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
                                  0|mm | [2024-08-01 21:20:06.931] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                                  0|mm | [2024-08-01 21:20:06.932] [LOG] Connecting socket for: MMM-SunRiseSet
                                  0|mm | [2024-08-01 21:20:06.933] [LOG] Starting node_helper for: MMM-SunRiseSet
                                  0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.31+rpt-rpi-v8
                                  0|mm | ### VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 20.15.0; npm: 10.7.0; pm2: 5.4.1
                                  0|mm | ### OTHER: timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined
                                  0|mm | [2024-08-01 21:20:10.636] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics - Interval: 7200000
                                  0|mm | [2024-08-01 21:20:10.779] [LOG] Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 7200000
                                  0|mm | [2024-08-01 21:20:10.802] [INFO] updatenotification: Updater Class Loaded!
                                  0|mm | [2024-08-01 21:20:10.803] [INFO] updatenotification: Checking PM2 using…
                                  0|mm | [2024-08-01 21:20:10.981] [INFO] Checking git for module: MMM-OpenWeatherMapForecast
                                  0|mm | [2024-08-01 21:20:11.025] [INFO] Checking git for module: MMM-SunRiseSet
                                  0|mm | [2024-08-01 21:20:11.046] [INFO] Checking git for module: MagicMirror
                                  0|mm | [2024-08-01 21:20:11.104] [INFO] updatenotification: [PM2] You are not using pm2
                                  0|mm | [2024-08-01 23:20:12.320] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-01 23:20:15.036] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 01:20:12.733] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 01:20:16.007] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 03:20:13.161] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 03:20:16.894] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 05:20:13.547] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 05:20:17.909] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 07:20:13.922] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 07:20:18.813] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 09:20:14.301] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 09:20:19.727] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 11:20:14.714] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 11:20:20.683] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 13:20:15.100] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 13:20:21.534] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 15:20:15.498] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 15:20:22.471] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 17:20:15.885] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 17:20:23.362] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 19:20:16.281] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 19:20:24.207] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 21:20:16.685] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 21:20:25.164] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-02 23:20:17.133] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-02 23:20:26.039] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-03 01:20:17.538] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-03 01:20:26.948] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-03 03:20:17.938] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-03 03:20:27.814] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-03 05:20:18.339] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-03 05:20:28.745] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  0|mm | [2024-08-03 07:20:18.699] [INFO] Calendar-Fetcher: Broadcasting 5 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                  0|mm | [2024-08-03 07:20:29.567] [INFO] Calendar-Fetcher: Broadcasting 122 events from https://calendar.google.com/calendar/ical/mycalhex%40group.calendar.google.com/private-number/basic.ics.
                                  • J jfields has marked this topic as solved on
                                    sdetweil @jfields
                                    @jfields cool, thanks for the feedback. . I’ll submit a pull request to fix the base
                                      jfields @sdetweil
                                      @sdetweil and @Rags
                                      You can limit your calls as well. For example, I have mine set to 2,000. I get the 1,000 for free, and allow for another 1,000. This happened once while I was troubleshooting my issue here. I got to just over 1,900 calls total and the charge was $1.35 USD. You can set the max call limit to whatever you want.
                                        sdetweil @jfields
                                        @jfields very helpful, thanks
