    CalendarExt3 and Google Calendar event display
    8 Posts 4 Posters 2.9k Views 4 Watching
      movingfish
      howdy - have spent entirely too many hours trying to get this to display properly so resorting to the experts.
      At this point in time, I’m just trying to have my Google Calendar feed the events for the CalendarExt3 module as it seems the latter has more flexibility for changes or css down the road.
      I was finally able to get the ‘calendar grid’ to appear after moving the positioning to the bottom. Its a 27in screen does the Ext3 module position need to be set on the ‘bottom’ to see the calendar grid?
      Config file with personal calendar redacted and a crude photo of the screen. Events are working as expected from the Google Calendar. processed-50594970-3D6B-41C2-B77E-1AD1B521B4CD.jpeg
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
          address: "localhost",   // Address to listen on
          port: 8080,
          basePath: "/",        // The URL path where MagicMirror² is hosted
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set IP addresses that are allowed to connect
          useHttps: false,      // Support HTTPS or not
          httpsPrivateKey: "",  // HTTPS private key path
          httpsCertificate: "", // HTTPS Certificate path
          language: "en",
          locale: "en-US",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for more logging
          timeFormat: 24,
          units: "metric",
                      broadcastPastEvents: true,
                              url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                              color: "#3399ff"
                  module: 'MMM-GoogleCalendar',
                  header: "My Google Calendar",
                              symbol: "calendar-week",
                              calendarID: "" // Replace with your calendar ID
                      mode: "month",
                      maximumEntries: 10,
                      maxDays: 30,
                      showEndTime: true,
                      showLocation: true,
                      showDescription: true,
                      showInvitees: false
                  module: "MMM-CalendarExt3",
                  position: "bottom_center",
                  title: "Events Calendar",
                      mode: "month",
                      weekIndex: 0,
                      weeksInView: 5,
                      instanceId: "basicCalendar",
                      locale: 'en-EN',
                      maxEventLines: 5,
                      firstDayOfWeek: 0,
                      refreshInterval: 120000,
                      animationSpeed: 0,
                      useSymbol: false,
                      calendarSet: []
          customCss: "css/custom.css"
      • E Offline
        elfklaus
        @MMRIZE said in CalendarExt3 and Google Calendar event display:
        You may need broadcastEvents: true, in MMM-GoogleCalendar module. I don’t know why, but that option is disabled by default unlike the default calendar module.
        This solved the issue I had completly, the Google calendar doesnt broadcast the events by default and I just saw the difference in the debug output comparing the normal “Calendar” and the “MMM-GoogleCalendar”.
        The calendar events from MMM-GoogleCalenda appear correctly after i used broadcastEvents: true in the config.
        Cheers :),
        Klaus
          MMRIZE @movingfish
          @movingfish
          To collaborate with GooglCalendar, see this; https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
            movingfish @MMRIZE
            @MMRIZE thanks for quick response.
            At this point I’m stuck on how to get the Google Calendar events (top left) fed into the CalendarExt3 calendar.
            Trying to put them in the same position seemed to cause me an error but will try another few tweaks.
            The top right calendar is just basic calendar for testing purposes.
              MMRIZE @movingfish
              @movingfish
              MMM-GoogleCalendar is incompatible with the standard default MM’s calendar module. It spits out incompatible broadcasting notifications, so you should convert it with preProcessor of MMM-CalendarExt3.
              Let’s check something in your config.
              1. preProcessor should be located in config block of MMM-CalendarExt3
                  preProcessor: (e) => {
                    if (e.startDate) return e // when event coming from default module, skip conversion.
                    if (e.start?.dateTime) {
                      e.startDate = new Date(e.start.dateTime).valueOf()
                    } else if (e.start?.date) {
                      e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                    if (e.end?.dateTime) {
                      e.endDate = new Date(e.end.dateTime).valueOf()
                    } else if (e.end?.date) {
                      e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                    e.title = e.summary
                    e.fullDayEvent = (e.start?.date) ? true : false
                    return e
                  ... // Your other configuration
              1. You may need broadcastEvents: true, in MMM-GoogleCalendar module. I don’t know why, but that option is disabled by default unlike the default calendar module.
                  broadcastEvents: true, // <-- You may need this
              1. Not related to this issue, but you did something wrong.
              • in mode: "month", weekIndex and weeksInView are out of sense. It has meaning only in mode: "week".
              • en-EN is not a proper locale. Use en-US or just en. (Of course, it depends on where you live, en-GB, en-IN, en-AU, …)
              • If you set a proper locale, you don’t need to declare firstDayOfWeek. That value will be assigned automatically by your locale.
              • You are refreshing the module every 2 minutes. Is it really needed?
                movingfish @MMRIZE
                @MMRIZE Thank you again for looking into this and the advice. A lot of this was a project on a whim mixed with OpenAI. Overestimated its ability to give coherent css and js.
                1. I did not immediately see the preProcessor for MMM-CalendarExt3 in the docs so that is clearly something I missed.
                2. After a lot of random tweaks figured I was overcomplicating and went back to the default ‘sample-config’ from the Ext3 module which has been a relief.
                **Opinion - is there any greater benefit to the ‘Google secret link’ (calendar) vs OAuth (MMM-GoogleCalendar)? Seems inherent security benefit with OAuth but not sure. That is what started me down using the separate module.
                1. again - thanks. some easy fixes.
                  shouldnt need to refresh the module that regularly. will adjust when I go to ‘prod’
                Can consider this solved at this point.
                As an aside - also want to thank @sdetweil . Anybody reading this in the future make sure to review this page and it will make modifying css much easier.
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues/4?_=1696523432686
                  sdetweil @movingfish
                  @movingfish and you can comment out the position for the calendar modules, they will still send broadcast used by ext3
                    MMRIZE @movingfish
                    @movingfish
                    Secret ics URL is easier to handle. But your config.js is weaker for peeping. (There is another alternative MMM-CalDAV)
                    • E Offline
                      elfklaus
                      Cheers :),
                      Klaus
