    Fork Mode
    11 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @davidgagne
      @davidgagne said in Fork Mode:
      but then I am stuck with it reporting everything back to the ssh
      and a learning thing
      on Windows you can use
      cd %HOME%\MagicMirror
      rem had to make a mm.cmd or mm.bat
      detach installers\mm.cmd
      to spin a job off in the background
      on linux, you end the command with &
      to do the same thing
      # only for  example, could have used the complete path
      installers/mm.sh &
      # or
      npm start &
        davidgagne @sdetweil
        @sdetweil Oh, nice. That’s a good tip. Thanks!
          @sdetweil said in Fork Mode:
          installers/mm.sh &
          That doesn’t seem to work:
          ~/MagicMirror $ installers/mm.sh &
          [1] 11788
          > magicmirror@2.28.0 start
          > ./run-start.sh $1
          [2024-08-04 16:01:09.618] [LOG] Starting MagicMirror: v2.28.0
          [2024-08-04 16:01:10.764] [LOG] Loading config ...
          [2024-08-04 16:01:10.845] [LOG] config template file not exists, no envsubst
          [2024-08-04 16:01:17.539] [LOG] Loading module helpers ...
          [2024-08-04 16:01:17.705] [LOG] No helper found for module: alert.
          [2024-08-04 16:01:19.196] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:19.283] [LOG] Module helper loaded: updatenotification
          [2024-08-04 16:01:19.535] [LOG] No helper found for module: clock.
          [2024-08-04 16:01:20.029] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:20.278] [LOG] Module helper loaded: mmm-systemtemperature
          [2024-08-04 16:01:20.396] [LOG] No helper found for module: weather.
          [2024-08-04 16:01:20.554] [LOG] No helper found for module: weather.
          [2024-08-04 16:01:27.632] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:27.767] [LOG] Module helper loaded: MMM-ThemeParkWaitTimes
          [2024-08-04 16:01:30.552] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:30.603] [LOG] Module helper loaded: MMM-birthdays
          [2024-08-04 16:01:30.714] [LOG] No helper found for module: MMM-CloneWarsQuotes.
          [2024-08-04 16:01:30.761] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:30.854] [LOG] Module helper loaded: MMM-ThemeParkWaitTimes
          [2024-08-04 16:01:31.469] [LOG] Initializing new module helper ...
          [2024-08-04 16:01:31.526] [LOG] Module helper loaded: MMM-ImagesPhotos
          [2024-08-04 16:01:31.561] [LOG] All module helpers loaded.
          [2024-08-04 16:01:32.866] [LOG] Starting server on port 8080 ...
          [2024-08-04 16:01:33.567] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [2024-08-04 16:01:35.645] [LOG] Server started ...
          It is still returning all the reporting to Terminal.
            @davidgagne yes, as the starting shell is still open, output is spooled there,
            BUT you can exit the window AND it will stay running… the output will be lost…
            (thats the value of pm2 spawning… it captures the output)
            if you get it running in the background, without pm2, then two ways to kill it
            reboot
            or run a kill script like this
            ps -ef | grep MagicMirror  | awk '{print $2}'| xargs sudo kill -9
            for info , the steps
            list the processes and their program path
            find the ones with MagicMirror
            print out just the process number
            sudo kill -9 the process number
              @sdetweil Oh. So just close that Terminal window and ssh into it again, you mean?
                @davidgagne yes
