    newsfeed
    11 Posts 4 Posters 2.6k Views 4 Watching
    • F Offline
      foggy
      I am trying to run newsfeed.
      my config file looks like this.
                              module: "newsfeed",
                              position: "bottom_bar",
                              animateIn: "slideInLeft",
                              animateOut: "slideOutRight",
                                feeds: [
                                    title: "New York Times",
                              //       url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                    url: "https://feeds.bbci.co.uk/news/world/rss.xml",
                                showSourceTitle: true,
                                showPublishDate: true,
                                broadcastNewsFeeds: true,
                                broadcastNewsUpdates: true
      However I just get no news at the moment. Can someone look to see if I have made an error?
      Best wishes.
      mumblebajM 1 Reply Last reply Reply Quote 1
      • mumblebajM Offline
        mumblebaj Module Developer @foggy
        @foggy Your config works fine as is for me. Are you seeing any errors in the logs or the developers window?
        • F Offline
          foggy
          Thank you for your response.
          When I run the program all I see is the news for NYT and not BBC.
          I am not really sure where to look for the files. Just in case it make a difference, I download MagicMirror using https://tteck.github.io/Proxmox/#magicmirror-server-lxc
          As I am using Proxmox.
          Best wishes.
            sdetweil @foggy
            @foggy are you editing the correct file?
            it looks like your changes are not in the config.js being used
              JohnGalt @sdetweil
              @foggy - @sdetweil may be onto something. I jsut added your url to my config.js file and I now get the BBC just fine.
              I also wonder whether the "{ " and “}” brackets are required but missing in your feeds array? I have each feed url in its own brackets and it works for me. See my config below, modified to add your BBC url.
              @sdetweil - related question: In the[recent] past my system has always restarted Magic Mirror when i commit a change to config.js using control-O, but lately it doesn’t and I have to manually restart MM. Is this expected behavior?
              Here is the file MagicMirror/config/config.js now correctly displaying BBC news.
              {module: "newsfeed",
                   disabled: false,
                   tableClass: "small",
                   position: "bottom_center",    // bottom_center bottom_bar
                   feeds: [
                      { title: "New York Times", url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml" },
                      { title: "BBC", url: "https://feeds.bbci.co.uk/news/world/rss.xml"},
                      { title: "Las Vegas Review Journal", url: "https://www.reviewjournal.com/feed/" },
                      { title: "Detroit Metro Times", url: "https://www.metrotimes.com/detroit/Rss.xml" },
                         reloadInterval: 600000, // Content fetch interval - 600000 = 10 minutes
                         updateInterval: 15000, //Display new headline interval - default = 10000 milliseconds / 10 seconds
                         broadcastNewsFeeds: false,
                         broadcastNewsUpdates: false
                sdetweil @JohnGalt
                @JohnGalt said in newsfeed:
                this is provided by PM2 file change detection… it is inconsistent, and I haven’t found any reason… for me it has NEVER worked on pi, or linux… but used to ALWAYS work on mac… (but now doesn’t as well) …
                in my config to setup the MagicMirror app I use a json file that provides that configuration.
                I don’t see any change in the pm2 doc for this
                  "apps" : [{
                    "name"        : "MagicMirror",
                    "script"      : "/home/pi/MagicMirror/installers/mm.sh",
                    "watch"       : ["/home/pi/MagicMirror/config/config.js"]  <-----  I adjust this for user and path
                  sdetweil @JohnGalt
                  @JohnGalt remember he is running under lxc container
                  so the files are NOT in exactly the same place… (they are linked into the container is the same logical place)
                    JohnGalt @sdetweil
                    @sdetweil - Thanks for both the update on the pm2 restart and on the reminder that the OP’s system structure is different.
                    OK, back to newsfeed behavior…
                      sdetweil @JohnGalt
                      @JohnGalt I think he might be editing the sample
                      • F Offline
                        foggy
                        Thank you all for your comments. Not sure what I did but the BBC is now working. Please close.
                        Best wishes.
                          sdetweil @foggy
                          @foggy you close. click the 3 dots to the right, and select mark this post…
                          • F foggy has marked this topic as solved on
