    Delete Fade In/Fade Out animation in the NewsFeed Module
    11 Posts 2 Posters 1.4k Views 2 Watching
    • V Offline
      victorjim
      First of all I want to say hello to this huge community.
      I recently created my first MagicMirror with the default modules and in the NewsFeed module (I have several news channels) I cannot read it naturally because the Description and Titles are constantly appearing and disappearing.
      Is there a solution so that no animation appears?
      Thanks for your answers.
        sdetweil @victorjim
        @victorjim the animationSpeed setting (default 2.5 seconds) determines how quickly the content changes
        see the documentation link in the header
        maybe make it 100 milliseconds, or 0, no delay
        • V Offline
          victorjim @sdetweil
          Thanks for your reply, but I’ve already given several values ​​to the animationSpeed ​​variable and I haven’t gotten the desired results.
          Would it be possible to remove the animation completely?
            sdetweil @victorjim
            @victorjim can you show me the config.js for newsfeed
            • V Offline
              victorjim @sdetweil
              @sdetweil Hello
              This is my code, I use a single screen to display 4 news.
              /* Config Sample
               * see https://docs.magicmirror.builders/configuration/introduction.html
               * and https://docs.magicmirror.builders/modules/configuration.html
               * You can use environment variables using a `config.js.template` file instead of `config.js`
               * which will be converted to `config.js` while starting. For more information
               * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
              let config = {
              	address: "localhost",	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
              	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
              	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
              	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
              	language: "es",
              	locale: "es-ES",
              	timeFormat: 24,
              	units: "metric",
              			module: "newsfeed",
              			position: "top_bar",
              			reloadInterval: 60000,
              			animationSpeed: 5*1000,
              				feeds: [
              					title: "Portada Periodico de Aragon",
              					url: "https://www.elperiodicodearagon.com/rss/section/23500"
              				showSourceTitle: true,
              				showPublishDate: true,
              				showDescription: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
              			module: "newsfeed",
              				feeds: [
              					title: "Portada Periodico ABC",
              					url: "https://www.abc.es/rss/2.0/portada/"
              			module: "newsfeed",
              				feeds: [
              					title: "Portada El Mundo",
              					url: "http://estaticos.elmundo.es/elmundo/rss/espana.xml"
              			module: "newsfeed",
              				feeds: [
              					title: "Portada Libertad Digital",
              					url: "http://feeds2.feedburner.com/libertaddigital/portada"
              I hope I haven´t written this code wrong.
              The reason for putting the 4 modules separately is so that I can control the space between them a bit since, I have no experience with CSS.
              Thank you.
                sdetweil @victorjim
                @victorjim
                those two properties are for the module, not MagicMirror, so they should be inside the config:{ section, here is the doc for module parameters for MagicMirror,
                https://docs.magicmirror.builders/modules/configuration.html#example
                means 5 seconds for each news item to appear and disappear. longer animation
                you want it to be shorter or not at all
                	animationSpeed: 0,
                • V Offline
                  victorjim @sdetweil
                  I changed the animationSpeed: value to 0, and it still does the Fade In/Fade Out animation.
                  Nothing has changed. What I would like is to remove the animation and leave the text fixed.
                  Thanks.
                    sdetweil @victorjim
                    @victorjim said in Delete Fade In/Fade Out animation in the NewsFeed Module:
                    did you MOVE the animationSpeed:0, INSIDE the config:{} section of the module definition??
                    otherwise the module will not see that setting
                    • V Offline
                      victorjim @sdetweil
                      I don’t understand well, I have changed the variable animationSpeed: 0 in the config.js file inside the /MagicMirror/config/ folder
                      Like this code:
                      			module: "newsfeed",
                      			animationSpeed: 0,  //  In this position
                      				feeds: [
                        @sdetweil said in Delete Fade In/Fade Out animation in the NewsFeed Module:
                        so
                        			module: "newsfeed",
                        // move These TWO parameters
                        			animationSpeed: 0,
                        // INSIDE the config:{ section
                        				feeds: [
                        				broadcastNewsUpdates: true,
                        // like this
                        			        animationSpeed: 0
                        module: …to config: { belong to MagicMirror, NOT the module
                        config: {… } belong to the module
                        • V Offline
                          victorjim @sdetweil
                          Ok
                          Now I understand.
                          The 2 variables must be set in the configuration of each news.
                          Now it is corrected and works.
                          Thank you very much.
