    MMM-Carousel & basic KeyBindings not working
    13 Posts 2 Posters 1.7k Views 2 Watching
      brentmatthews
      Hi all,
      I had set up MMM-Carousel and MMM-KeyBindings with the default suggestions on the module pages for running these two together with a regular keyboard, however the arrow keys are not changing the slides. Please see below, any help would be great.
      			module: "MMM-KeyBindings",
      			evdev: {enabled: false},
      			enableKeyboard: true,
      			module: "MMM-Carousel",
      			disabled: false,
            			position: "bottom_bar", // Required only for navigation controls
              			transitionInterval: 10000, //20000,
              			ignoreModules: ['alert', 'updatenotification', 'MMM-KeyBindings'],
      				mode: "slides",
                      		showPageIndicators: true,
                      		showPageControls: true,
      				slides: {
                				main: ['clock', 'MMM-OpenWeatherForecast', 'MMM-WOTD', 'MMM-BackgroundSlideshow'],
                				"Slide 2": ['clock', 'MMM-OpenWeatherForecast', 'MMM-MyCalendar', 'MMM-TomTomCalculateRouteTraffic', 'MMM-MyWastePickup', 'MMM-BackgroundSlideshow'],
      					"Slide 3": ['clock', 'MMM-OpenWeatherForecast', 'MMM-WOTD', 'MMM-BackgroundSlideshow'],
      				keyBindings: {
      					enabled: true,
      					map: {
      						NextSlide: "ArrowRight",
      						PrevSlide: "ArrowLeft",
      						Pause: "ArrowDown",
      						Slide0: "Home"
      						mode: "DEFAULT"
        sdetweil @brentmatthews
        @brentmatthews can you install mmm-ViewNotifications
        so you can tell if keybindings is sending the notification
          brentmatthews @sdetweil
          @sdetweil There are no notifications being sent when I hit the keyboard buttons.
            @brentmatthews so keybindings is having trouble
            can you open the developers window, ctrl-shift-i
            and select the console tab, and scroll to the top to see if there are any errors reported.
              @brentmatthews I installed keybindings and viewnotifications
              and I see the keypress for left/right arrow (in the notifications window)
              but looking any Carousel it says
              if (notification === "KEYPRESS") Log.log(`${this.config.name}: notification ${notification} from ${sender.name}`);
              ok… but that doesn’t DO anything except report the keypress…
                @sdetweil I will check it out tonight and see if I can find any errors.
                  @sdetweil I am unable to jump on the computer tonight.
                  Would the pages module work with keybindings to move through the pages? Or to the hidden page. Essentially want the main page and a second or hidden page that only comes up with a button click.
                  Also considering the remote module to have the toggle switch to just turn on the extra modules I have shown on the second page when needed.
                    @brentmatthews i think the default config for keybindings is not correct
                      @sdetweil I just managed to jump on. I may have to upgrade my mirror as I saw a minimum requirements and my current version of MM was under that. I am trying to find your update scripts at the moment.
                        @sdetweil I have switched back to MMM-pages as it is much cleaner. I will see what other options I have in the notification sending arena to suit me.
                        Any simple suggestions welcome.
