    Pi Zero
    pizero
    37 Posts 10 Posters 58.8k Views 12 Watching
    • N
      Neokamikaze
      Hi @nigel-daniels, i don’t touch kweb configuration. I just add on “~/.config/lxsession/LXDE-pi/autostart” file this:
      @lxpanel --profile LXDE-pi
      @pcmanfm --desktop --profile LXDE-pi
      @xscreensaver -no-splash
      and in “/etc/xdg/lxsession/LXDE-pi/autostart” this:
      @xset s noblank
      @xset s off
      @xset -dpms
      After for configure my display i change the configuration in “/boot/config.txt”.
      N 1 Reply Last reply
      • N
        nigel-daniels @Neokamikaze
        @Neokamikaze HI thanks for the suggestion, I’ve ensured both my versions of these files match yours, but somewhere DPMS is being enabled… 10 mins in the screen blanks. I can see in the file /var/log/Xorg.0.log the following lines:
        [ 81.864] (II) FBTURBO(0): enabled fbdev copyarea acceleration
        [ 81.865] (==) FBTURBO(0): Backing store enabled
        [ 81.875] (==) FBTURBO(0): DPMS enabled
        [ 81.875] (II) FBTURBO(0): failed to enable hardware cursor
        Something somewhere is setting DPMS up and for some reason the xset -dpms command is being skipped. I’ll try adding the set command to the start.sh and see if that forces the issue.
        • N
          Neokamikaze
          Hi @nigel-daniels, if you use jessie i think there is a problem with DPMS. There is a GUI package for configure this. If you want test install “xscreensaver” package
          • N
            @Neokamikaze Thanks I’ll give that a shot. This is Jessy, and it sounds like the sort of problem I’m seeing.
            Me thinks it will need to be in the morning now… gone midnight in my TZ so I’ll get screensaver on board and deal with pulling the mirror apart to get the minikbd plugged back in till then.
            I’ll let you know how it works out.
            • N
              nigel-daniels @nigel-daniels
              @nigel-daniels sigh ok tried that rebooted into the GUI and used the screensaver config to switch off the screensaver. Then reconfigured the system to log into the CLI and use the start.sh to kick of X/Kweb… 10 mins later a black screen. I’m running out of locations to try using the set commends, I even added them to the start.sh.
                darkeagl105
                So my promised input to the whole thing:
                I gave up on kweb and using midori browser. It automaticly starts in fullscreen and kiosk mode. I have to put in a delay after “node serveronly” of 45s.
                Bootup in console mode and add this in /etc/rc.local
                sudo -u mirror /home/mirror/MagicMirror/serveronly
                sleep 45s;
                sudo -u mirror midori -e Fullscreen -a http://localhost:8080
                and thats it. Works for me.
                • N
                  nigel-daniels @darkeagl105
                  @darkeagl105 HI thanks for the update, I did end up recompiling Kweb which worked once I’d figured out I had to do that… I’m just now stuck figuring out how to stop my screen blanking after 10 mins! I think I’ve added the xset commands in about 5 locations and still nothing!
                  H 1 Reply Last reply
                    canadrian
                    Getting an:
                    /home/pi/start.sh: line 4: xinit: command not found
                    where line 4 is:
                    xinit /usr/bin/kweb -KJE4 “http://localhost:8080”
                    any help appreciated. thank you in advance.
                    • H
                      handfish @nigel-daniels
                      @nigel-daniels I realise this is really late, but I found a solution to my screen blanking on this site, at the bottom with “setterm -blank 0”.
                      • H
                        handfish
                        Sorry: got that wrong. I’m still back to it blanking.
                          bmarofsky
