    ReferenceError: fetch is not defined
    6 Posts 2 Posters 1.2k Views 2 Watching
      ReD1470
      Could not find anything helpfull on the web, of this forum so here goes.
      MM was running fine until latest update. Weather stopped working.,
      Fixed it by using the sample settings, they changed from openweather to openmeto. ok, no prob.
      But now, dont ask, calender and newsfeed keep loading.
      I tried;
      • git pull in Magic mirror folder
      • ran npm install node-fetch@2 in Magic mirror and calender module folder
      • ran sdetweil repair script (
      • updated Pi3, running bookwork
      the log shows this
      0|mm | [2024-10-18 14:59:19.435] [ERROR] Whoops! There was an uncaught exception…
      0|mm | [2024-10-18 14:59:19.448] [ERROR] ReferenceError: fetch is not defined
      0|mm | at fetchCalendar (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:51:3)
      0|mm | at CalendarFetcher.startFetch (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:96:3)
      0|mm | at Class.createFetcher (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:79:11)
      0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:15:9)
      0|mm | at Socket. (/home/pi/MagicMirror/js/node_helper.js:91:10)
      0|mm | at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
      0|mm | at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
      0|mm | at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:214:24
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
      Strange, but have Hyper-v debian running with MM and no problem there
      Anyone?
        sdetweil @ReD1470
        @ReD1470 what nodejs version are you running?
        node -v
        you need 20.9.0 or above, but not any v 21
        the npm install should fail on v 2.29.0 as it checks the version too
        my upgrade script is 2 part right?
        without any parameters its it just a test, no changes
        with a parameter it will DO the upgrade, nodejs too
          ReD1470 @sdetweil
          Yes node -v
          v20.9.0
          Yes the install script was applied with apply
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          If you want i can try and zip and post the upgrade.log
            sdetweil @ReD1470
            @ReD1470 note… IF you tried to do it manually, my script will abort if you try to auto upgrade again…
            (I will not install updates over already updated)
            so you have to change apply to force, to FORCE the scrip to do it anyhow
            don’t need the whole upgrade log just the last 20 lines
              ReD1470 @sdetweil
              WOW that did alot… i think
              but you sure now your stuf… problem fixed. I got my calender back
              TNX!
              here are the last lines of the log
              npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
              added 48 packages, and audited 49 packages in 8s
              2 packages are looking for funding
              run npm fund for details
              2 moderate severity vulnerabilities
              Some issues need review, and may require choosing
              a different dependency.
              Run npm audit for details.
              processing complete for module MMM-SystemStats
              restoring custom.css
              removing git alias
              Upgrade ended - Sun Oct 20 17:53:11 CEST 2024
                sdetweil @ReD1470
                @ReD1470 awesome. glad it’s working
                • R ReD1470 has marked this topic as solved on
