    Shelly-PM not working?
    6 Posts 2 Posters 648 Views 2 Watching
      sdetweil @chrisfr1976
      @chrisfr1976 see
        chrisfr1976 @sdetweil
        @sdetweil Hi, that fixed the startup problem. Many thanks!
        But there are still some errors. I`ll check and maybe reopen this topic.
        Regards, Chris.
          chrisfr1976 @chrisfr1976
          Okay, maybe someone is successfully running this module and can help. I get this message:
          0|mm  | [2024-10-21 14:58:00.242] [ERROR] Whoops! There was an uncaught exception...
          0|mm  | [2024-10-21 14:58:00.242] [ERROR] Error: undefined is not a valid uri or options object.
          0|mm  |     at request (/home/chris/MagicMirror/modules/node_modules/request/index.js:44:11)
          0|mm  |     at Class.socketNotificationReceived (/home/chris/MagicMirror/modules/MMM-Shelly-PM/node_helper.js:30:4)
          0|mm  |     at Socket.<anonymous> (/home/chris/MagicMirror/js/node_helper.js:91:10)
          0|mm  |     at Socket.onevent (/home/chris/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
          0|mm  |     at Socket._onpacket (/home/chris/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
          0|mm  |     at /home/chris/MagicMirror/node_modules/socket.io/dist/client.js:214:24
          0|mm  |     at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
          0|mm  | [2024-10-21 14:58:00.243] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm  | [2024-10-21 14:58:00.244] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
          I had a look in the index.js and the node_helper.js but I can‘t see whats not working.
          Cheers,
          Chris.
          Regards, Chris.
            @chrisfr1976 so, it is trying to use the config parm you should have set
            uri: self.config.uri
            do you have a uri : property in the module config?
            there is no default set by the module
              @chrisfr1976 the author posted a replay to
              https://github.com/stefanjacobs/MMM-Shelly-PM/issues/1
              about an hour ago
