    I can't for the love of god understand what's wrong with my config
    12 Posts 3 Posters 6.5k Views 3 Watching
      sdetweil @bougle
      @bougle if you edit the synced ics file, are there events present?
      ics is just a text file
        sdetweil @bougle
        @bougle said in I can't for the love of god understand what's wrong with my config:
        http://localhost:8080/modules/calendars/D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1.ics
        is the synced ics IN the modules folder tree??
        you had to MAKE that calendars folder, right?
        it MUST be in the MagicMirror folder tree to use localhost:8080
        B 1 Reply Last reply
          chrisfr1976 @bougle
          @bougle
          Try
          let config = {address: "0.0.0.0", …….
          And
          url: "http://0.0.0.0:8080/modules/calendars……..
          Worked for me.
          Br Chris
          Regards, Chris.
          S B 2 Replies Last reply
            sdetweil @chrisfr1976
            @chrisfr1976 technically you shouldn’t need this
            “0.0.0.0” means listen on all active network interfaces (wifi and ethernet) without having to specify their addresses ( which would be impossible to do for multiple interfaces)
            the http://0.0.0.0:8080 makes no sense to me , unless they coded in a hack to say keep looking for whatever interface works. although localhost does that same thing
            the other thing “0.0.0.0” does is allow incoming requests from outside this system, where localhost restricts incoming request to ONLY apps on this same system
              bougle @sdetweil
              @sdetweil Thank you for your reply.
              Yes I do already have all the three .ics files in
              ~/MagicMirror/modules/calendars
                bougle @chrisfr1976
                @chrisfr1976 Thanks for the suggestion. I will try it out today and report back.
                  sdetweil @bougle
                  @bougle ok, next, can you look at the output of npm start and see the message
                  broadcasting xxx events for calendar —url----
                  for each url?
                    @bougle make any progress?
                      bougle @sdetweil
                      Sorry for the late reply. Super swamped because of university.
                      here is the log:
                      [2024-11-09 10:34:54.714] [INFO]  Checking git for module: MMM-CalendarExt3Agenda
                      [2024-11-09 10:34:55.000] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/9F91CE4D-8088-4518-9239-C4FCC3DA0EC4.ics.
                      [2024-11-09 10:34:55.041] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/D8CC2057-AD72-45D1-9AC7-942E8C2A5DD1.ics.
                      [2024-11-09 10:34:55.055] [INFO]  Calendar-Fetcher: Broadcasting 0 events from http://0.0.0.0:8080/modules/calendars/1AAA8AEA-457E-487D-92E2-3060BF33C468.ics.
                      It shows that there are 0 events. And btw, the .ics files are completely empty.
                        bougle
                        UPDATE!!
                        Today, I re-ran
                        vdirsyncer discover
                        vdirsyncer sync
                        And was able to sync with the calendar and it works!! I am not exactly sure why but I did perform a iCloud sync too earlier.
                        Thanks @chrisfr1976 and @sdetweil for your help:)
                          sdetweil @bougle
                          @bougle awesome, glad you got it!
