    I cant get my Calender or my MMMBitcoin to work, any help please?
    19 Posts 3 Posters 2.2k Views 3 Watching
      sdetweil @clarkcrew32
      @clarkcrew32 the calendar module ONLY processes ics files…
      there is no embedded view support.
      you can use one of the modules that does iframe and view the calendar that way
      or use the default with ICS and use something like MMM-CalendarExt3 or MMM-MiniMonth to see a wall calendar view
      on bitcoin
      can you show the message output from npm start
      if you are using pm2 to autolaunch MM, then
      pm2 logs --lines=xxxx
      where xxx is some number of the most recent lines, default 15 (may need 100 or more to view that far back_
        clarkcrew32 @sdetweil
        @sdetweil how do i clear my config.js and start from default?
          @clarkcrew32
          cd ~/MagicMirror/config
          cp config.js.sample config.js
          that copies the sample we provide
          C 2 Replies Last reply Reply Quote 0
            @sdetweil awesome thakn you, anyway for me to check for errors before i leave nano config.js screen?
              @sdetweil you are like gold lol
              still cant get this to work tho as i found a way to do .ics file calender
                @clarkcrew32 that fetch us on every 7 days
                during dev i would change it to a few minutes 5*60*1000
                another thing to test
                from a terminal window try to download the ics
                curl -sL  the_cal_url >somefile.txt
                then examine the contents of somefile.txt
                for BEGIN:VEVENT…
                  @clarkcrew32 check for errors
                  not in nano
                  but you can run the checker
                  npm run config:check
                  we do that on every startup now and fail if there is some problem.
                    raymondjspigot @sdetweil
                    @clarkcrew32 hiya I’m not familiar with the MMM-Bitcoin module, but just taking a look at the github page for it at https://github.com/valmassoi/MMM-bitcoin it doesn’t look like the install instructions are complete (it only suggests adding the module config to your config.js)
                    AFAIK to install a module to your mirror, you’re going to need to clone the repository to your modules directory, as well as add its config.
                    (apologies, you might know to do this all already, but just to make sure …)
                    try going
                    cd ~/MagicMirror/modules
                    git clone https://github.com/valmassoi/MMM-bitcoin
                    and the module should be cloned to your modules directory
                    then add the config entry into your config.js file, save the changes and try running your MagicMirror again.
                    (I don’t see any obvious typos for the MMM-Bitcoin entry in your config.js screenshot at the top, it looks like you edited it with nano just fine the first time).
                      @clarkcrew32 the bitcoin module has a problem.
                      it uses s library we stopped shipping 3 years ago.
                      but the author didn’t document its use.
                      so, in the module folder do
                      npm install request
                        im geting an error at the very last line here
