    MMM-CalendarExt3 no Entries since last update
    17 Posts 3 Posters 3.2k Views 3 Watching
      MMRIZE @Andreas1956
      @Andreas1956
      I checked your config and css but nothing seems wrong.
      From which version were you updated to new one? (I think you cannot remember, but how long has it been since the previous update?)
      Anyway, I think you may have missed something in the last update.
      1. Go to the CX3 module directory, then;
      git pull
      npm update
      I doubt you may miss npm update part in your last update process.
      1. If it still does not work, do this in your CX3 module directory
      git submodule update --init --recursive
      1. Still not working; remove the CX3 directory and then reinstall again.
      2. Still not working; let’s discuss deeper.
        Andreas1956 @MMRIZE
        @MMRIZE
        ok, thanks
        if i have an updatenotification, i do it same or next day
        now
        • did Points 1.-3.,
        • changed .cx2 to .cx3 in css
        • updated magicmirror too
        • startet all new
        • checked my google calendars - everything ok. on iPhone and iPad
        • tried to remove the color property from one calendar entry
        what i forgot to say, it’s running under windows11 (but since end of March 2023 without any problems)
        Same as in screenshot, no text, only colored blocks for appointments
          MMRIZE @Andreas1956
          @Andreas1956
          OK. Look inside deeper.
          1. Execute MM as dev mode.
          • If you are using pm2, stop it first.
          • In your MM directory, run this script.
          npm run start:dev
          1. Or alternatively, After MM’s normal execution, Ctrl + Shift + i (Or Alt+F12, it could be different by your system environment), Anyway, open the dev-console on the browser/client with hotkeys.
          2. It will open this kind of dev-console as a side panel.
          1. At the panel, you can see Elements or Console tab. Go to Elements Tab.
          1. There would also be cursor icon (left side of the Elements Tab mark); select it and click to any event element
          1. Now, the side Elements tab will focus on the HTML code for the element you clicked.
          2. navigate into the title element
          1. Check whether proper text exists there.
          1. And See the Styles tab.(Somewhere in the side panel. Usually below the Elements window)
          You can see there are --calendarColor and oppositeColor attributes there. And there is no other overridden colors.
          1. Or you can check this in Computed tab.
          There are some calculated results for the style.
          Could you find any suspicious things on watching your case?
            Andreas1956 @MMRIZE
            @MMRIZE
            Thanks, a lot of Information event =true on 19th but nothing like title
            I will check for warnings or errors tomorrow
              MMRIZE @Andreas1956
              @Andreas1956
              You are clicking the day cell, not event.
              A 2 Replies Last reply Reply Quote 0
                Andreas1956 @MMRIZE
                @MMRIZE
                I would, but there is no event cell under the day … i think this is the Problem
                S A 2 Replies Last reply Reply Quote 0
                  sdetweil @Andreas1956
                  @Andreas1956
                  there is an event cell that spans into the 19th (pink arrow)
                    Andreas1956 @sdetweil
                    Yes, but this Screenshot is shrinkt, cause of the debug window on the right side.
                    And until last update begin of the week, everything was ok. I didnd change anything on my config files since months.
                      @Andreas1956 yes, but its the event bubbles that are empty. and he wanted to see that
                        Andreas1956 @MMRIZE
                        @MMRIZE said in MMM-CalendarExt3 no Entries since last update:
                        @Andreas1956
                        ok, found the event cells now.
                        think the problem comes from the font-awesome symbols. i removed the symbol property from all 5 calendar entries, then everything was ok but no symbols (only the standard calendar symbol)
                        then i added symbol:[“trash”] to the calendar garbage again - title disappeared again.
                          Andreas1956 @Andreas1956
                          @Andreas1956
                          ok, got it. i removed the square bracket from the symbol property like - symbol: “trash” ans everything works fine.
                          Screenshot is from your github Page
