    Electron quit periodically
    26 Posts 3 Posters 6.3k Views 4 Watching
      jefftse
      my MM quits and restarts periodically. When I looked at the logs from pm2 and here is what I get. I wonder if anyone is experiencing the same thing and any solutions?
      0|mm | MEMORY-ERROR: electron[20099]: GSlice: assertion failed: sinfo->n_allocated > 0
      0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
        sdetweil @jefftse
        @jefftse i haven’t seen that reported before
        can you show the startup info from the logs?
        and also output of
        free -m
        J 1 Reply Last reply
          jefftse @sdetweil
          total           used        free        shared  buff/cache   available
          Mem:            3791        1127        1276         210        1674        2664
          Swap:            511           0         511
          how do i get you the startup info from the logs? pm2 log? or npm log?
            sdetweil @jefftse
            @jefftse pm2 logs --lines=xxx
            where xxx is the number of most recent lines to show
              jefftse @sdetweil
              @sdetweil I’m sorry but i’m not following…
                sdetweil @jefftse
                @jefftse
                pm2 logs --lines=15
                will show the last 15 lines of the captured output
                if your instance has been running for a day
                the LAST 15 lines are not useful, as the info is near the top (AND the log accumulates runs)
                you can also look at the file holding the output
                it is in the
                ~/.pm2/logs folder
                notice the dot in front of pm2
                  jefftse @sdetweil
                  @sdetweil gotcha. yea. i tried to upload the whole error log but i realized there is no way to do it here.
                    sdetweil @jefftse
                    @jefftse just need the 4 lines
                      jefftse @sdetweil
                      @sdetweil waiting for the next crash
                        sdetweil @jefftse
                        @jefftse but the info is there now
                          jefftse @sdetweil
                          @sdetweil > magicmirror@2.29.0 start
                          0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                          0|mm | [2024-12-18 09:29:44.580] [LOG] Starting MagicMirror: v2.29.0
                          0|mm | [2024-12-18 09:29:44.647] [LOG] Loading config …
                          0|mm | [2024-12-18 09:29:44.654] [LOG] config template file not exists, no envsubst
                          0|mm | [2024-12-18 09:29:46.022] [INFO] Checking config file /home/jeff/MagicMirror/config/config.js …
                          0|mm | [2024-12-18 09:29:46.254] [INFO] Your configuration file doesn’t contain syntax errors :)
                          0|mm | [2024-12-18 09:29:46.257] [INFO] Checking modules structure configuration …
                          0|mm | [2024-12-18 09:29:46.526] [INFO] Your modules structure configuration doesn’t contain errors :)
                          0|mm | [2024-12-18 09:29:46.532] [LOG] Loading module helpers …
                          0|mm | [2024-12-18 09:29:46.536] [LOG] No helper found for module: alert.
                          0|mm | [2024-12-18 09:29:46.555] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:46.557] [LOG] Module helper loaded: updatenotification
                          0|mm | [2024-12-18 09:29:46.559] [LOG] No helper found for module: clock.
                          0|mm | [2024-12-18 09:29:46.860] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:46.861] [LOG] Module helper loaded: calendar
                          0|mm | [2024-12-18 09:29:47.085] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:47.086] [LOG] Module helper loaded: newsfeed
                          0|mm | [2024-12-18 09:29:48.025] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:48.026] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
                          0|mm | [2024-12-18 09:29:48.264] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:48.265] [LOG] Module helper loaded: MMM-Screencast
                          0|mm | [2024-12-18 09:29:49.970] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:49.972] [LOG] Module helper loaded: MMM-AVStock
                          0|mm | [2024-12-18 09:29:50.472] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:50.473] [LOG] Check MagicMirror² version for node helper ‘MMM-CoinMarketCap’ - Minimum version: 2.2.1 - Current version: 2.29.0
                          0|mm | [2024-12-18 09:29:50.475] [LOG] Version is ok!
                          0|mm | [2024-12-18 09:29:50.476] [LOG] Module helper loaded: MMM-CoinMarketCap
                          0|mm | [2024-12-18 09:29:50.709] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:50.710] [LOG] Module helper loaded: MMM-BackgroundSlideshow
                          0|mm | [2024-12-18 09:29:50.826] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:50.827] [LOG] Module helper loaded: MMM-Pir
                          0|mm | [2024-12-18 09:29:50.869] [LOG] Initializing new module helper …
                          0|mm | [2024-12-18 09:29:50.870] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
                          0|mm | [2024-12-18 09:29:50.870] [LOG] All module helpers loaded.
                          0|mm | [2024-12-18 09:29:50.889] [LOG] Starting server on port 8080 …
                          0|mm | [2024-12-18 09:29:54.510] [LOG] Server started …
                          0|mm | [2024-12-18 09:29:54.515] [LOG] Connecting socket for: updatenotification
                          0|mm | [2024-12-18 09:29:54.521] [LOG] Starting module helper: updatenotification
                          0|mm | [2024-12-18 09:29:54.527] [LOG] Connecting socket for: calendar
                          0|mm | [2024-12-18 09:29:54.536] [LOG] Starting node helper for: calendar
                          0|mm | [2024-12-18 09:29:54.538] [LOG] Connecting socket for: newsfeed
                          0|mm | [2024-12-18 09:29:54.541] [LOG] Starting node helper for: newsfeed
                          0|mm | [2024-12-18 09:29:54.543] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
                          0|mm | [2024-12-18 09:29:54.550] [LOG] Connecting socket for: MMM-Screencast
                          0|mm | [2024-12-18 09:29:54.557] [LOG] Connecting socket for: MMM-AVStock
                          0|mm | [2024-12-18 09:29:54.563] [LOG] Connecting socket for: MMM-CoinMarketCap
                          0|mm | [2024-12-18 09:29:54.569] [LOG] MMM-CoinMarketCap: module loaded! Path: /home/jeff/MagicMirror/modules/MMM-CoinMarketCap
                          0|mm | [2024-12-18 09:29:54.574] [LOG] MMM-CoinMarketCap: Path “/logos” configured successfully.
                          0|mm | [2024-12-18 09:29:54.575] [LOG] Connecting socket for: MMM-BackgroundSlideshow
                          0|mm | [2024-12-18 09:29:54.581] [LOG] Connecting socket for: MMM-Pir
                          0|mm | [2024-12-18 09:29:54.584] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
                          0|mm | [2024-12-18 09:29:54.585] [LOG] Starting node_helper for MMM-OpenWeatherMapForecast
                          0|mm | [2024-12-18 09:29:54.589] [LOG] Sockets connected & modules started …
                          0|mm | [2024-12-18 09:29:55.384] [LOG] Launching application.
                          0|mm | [2024-12-18 09:29:57.817] [INFO] System information:
                          0|mm | ### SYSTEM: manufacturer: ; model: ; virtual: false
                          0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
                          0|mm | ### VERSIONS: electron: 31.7.6; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.3
                          0|mm | ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                          0|mm | [30914:1218/092957.948903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.949629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.950132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.950420:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.950944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.951547:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.952173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.952551:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.953858:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.954350:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.955047:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.955602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.956790:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.957248:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.961329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.961766:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.962348:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.962797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.963454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.963887:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.964501:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.964979:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.965605:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                          0|mm | [30914:1218/092957.966056:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                          0|mm | [30914:1218/092957.966665:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or director
                            sdetweil @jefftse
                            @jefftse said in Electron quit periodically:
                            that is what I needed
                              @jefftse ok, this is related to the Wayland compositor
                              can you switch back to X11
                              use the raspi-config app
                              sudo raspi-config
                              advanced
                              Wayland
                              X11
                              you will have to reboot after that
                              J 3 Replies Last reply
                                jefftse @sdetweil
                                @sdetweil ok, i just did it and will report back. I guess i lost VNC from switching.
                                  jefftse @sdetweil
                                  @sdetweil it did just crash with this
                                  0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                  PM2 | App [mm:0] exited with code [1] via signal [SIGINT]
                                  PM2 | App [mm:0] starting in -fork mode-
                                  PM2 | App [mm:0] online
                                  0|mm | > magicmirror@2.29.0 start
                                    sdetweil @jefftse
                                    @jefftse different vnc setup on x11
                                    i use ssh to avoid all this graphical crud.
                                    see this topic on using other tools from Windows
                                    https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
                                      sdetweil @jefftse
                                      what was before that line?
                                        jefftse @sdetweil
                                        @sdetweil 0|mm | MEMORY-ERROR: electron[3627]: GSlice: assertion failed: sinfo->n_allocated > 0
                                          sdetweil @jefftse
                                          @jefftse ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …) not electron problems…
                                          I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…
                                            jefftse @sdetweil
                                            @sdetweil my setup is pretty simple and its freshly built yesterday. here is my config…
                                            deleted
