    Electron quit periodically
    26 Posts 3 Posters 6.3k Views 4 Watching
      sdetweil @jefftse
      @jefftse but the info is there now
      J 1 Reply Last reply
        jefftse @sdetweil
        @sdetweil > magicmirror@2.29.0 start
        0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
        0|mm | [2024-12-18 09:29:44.580] [LOG] Starting MagicMirror: v2.29.0
        0|mm | [2024-12-18 09:29:44.647] [LOG] Loading config …
        0|mm | [2024-12-18 09:29:44.654] [LOG] config template file not exists, no envsubst
        0|mm | [2024-12-18 09:29:46.022] [INFO] Checking config file /home/jeff/MagicMirror/config/config.js …
        0|mm | [2024-12-18 09:29:46.254] [INFO] Your configuration file doesn’t contain syntax errors :)
        0|mm | [2024-12-18 09:29:46.257] [INFO] Checking modules structure configuration …
        0|mm | [2024-12-18 09:29:46.526] [INFO] Your modules structure configuration doesn’t contain errors :)
        0|mm | [2024-12-18 09:29:46.532] [LOG] Loading module helpers …
        0|mm | [2024-12-18 09:29:46.536] [LOG] No helper found for module: alert.
        0|mm | [2024-12-18 09:29:46.555] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:46.557] [LOG] Module helper loaded: updatenotification
        0|mm | [2024-12-18 09:29:46.559] [LOG] No helper found for module: clock.
        0|mm | [2024-12-18 09:29:46.860] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:46.861] [LOG] Module helper loaded: calendar
        0|mm | [2024-12-18 09:29:47.085] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:47.086] [LOG] Module helper loaded: newsfeed
        0|mm | [2024-12-18 09:29:48.025] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:48.026] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
        0|mm | [2024-12-18 09:29:48.264] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:48.265] [LOG] Module helper loaded: MMM-Screencast
        0|mm | [2024-12-18 09:29:49.970] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:49.972] [LOG] Module helper loaded: MMM-AVStock
        0|mm | [2024-12-18 09:29:50.472] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:50.473] [LOG] Check MagicMirror² version for node helper ‘MMM-CoinMarketCap’ - Minimum version: 2.2.1 - Current version: 2.29.0
        0|mm | [2024-12-18 09:29:50.475] [LOG] Version is ok!
        0|mm | [2024-12-18 09:29:50.476] [LOG] Module helper loaded: MMM-CoinMarketCap
        0|mm | [2024-12-18 09:29:50.709] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:50.710] [LOG] Module helper loaded: MMM-BackgroundSlideshow
        0|mm | [2024-12-18 09:29:50.826] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:50.827] [LOG] Module helper loaded: MMM-Pir
        0|mm | [2024-12-18 09:29:50.869] [LOG] Initializing new module helper …
        0|mm | [2024-12-18 09:29:50.870] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
        0|mm | [2024-12-18 09:29:50.870] [LOG] All module helpers loaded.
        0|mm | [2024-12-18 09:29:50.889] [LOG] Starting server on port 8080 …
        0|mm | [2024-12-18 09:29:54.510] [LOG] Server started …
        0|mm | [2024-12-18 09:29:54.515] [LOG] Connecting socket for: updatenotification
        0|mm | [2024-12-18 09:29:54.521] [LOG] Starting module helper: updatenotification
        0|mm | [2024-12-18 09:29:54.527] [LOG] Connecting socket for: calendar
        0|mm | [2024-12-18 09:29:54.536] [LOG] Starting node helper for: calendar
        0|mm | [2024-12-18 09:29:54.538] [LOG] Connecting socket for: newsfeed
        0|mm | [2024-12-18 09:29:54.541] [LOG] Starting node helper for: newsfeed
        0|mm | [2024-12-18 09:29:54.543] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
        0|mm | [2024-12-18 09:29:54.550] [LOG] Connecting socket for: MMM-Screencast
        0|mm | [2024-12-18 09:29:54.557] [LOG] Connecting socket for: MMM-AVStock
        0|mm | [2024-12-18 09:29:54.563] [LOG] Connecting socket for: MMM-CoinMarketCap
        0|mm | [2024-12-18 09:29:54.569] [LOG] MMM-CoinMarketCap: module loaded! Path: /home/jeff/MagicMirror/modules/MMM-CoinMarketCap
        0|mm | [2024-12-18 09:29:54.574] [LOG] MMM-CoinMarketCap: Path “/logos” configured successfully.
        0|mm | [2024-12-18 09:29:54.575] [LOG] Connecting socket for: MMM-BackgroundSlideshow
        0|mm | [2024-12-18 09:29:54.581] [LOG] Connecting socket for: MMM-Pir
        0|mm | [2024-12-18 09:29:54.584] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
        0|mm | [2024-12-18 09:29:54.585] [LOG] Starting node_helper for MMM-OpenWeatherMapForecast
        0|mm | [2024-12-18 09:29:54.589] [LOG] Sockets connected & modules started …
        0|mm | [2024-12-18 09:29:55.384] [LOG] Launching application.
        0|mm | [2024-12-18 09:29:57.817] [INFO] System information:
        0|mm | ### SYSTEM: manufacturer: ; model: ; virtual: false
        0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
        0|mm | ### VERSIONS: electron: 31.7.6; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.3
        0|mm | ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
        0|mm | [30914:1218/092957.948903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.949629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.950132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.950420:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.950944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.951547:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.952173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.952551:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.953858:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.954350:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.955047:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.955602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.956790:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.957248:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.961329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.961766:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.962348:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.962797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.963454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.963887:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.964501:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.964979:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.965605:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|mm | [30914:1218/092957.966056:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|mm | [30914:1218/092957.966665:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or director
          sdetweil @jefftse
          @jefftse said in Electron quit periodically:
          that is what I needed
            @jefftse ok, this is related to the Wayland compositor
            can you switch back to X11
            use the raspi-config app
            sudo raspi-config
            advanced
            Wayland
            X11
            you will have to reboot after that
            J 3 Replies Last reply
              jefftse @sdetweil
              @sdetweil ok, i just did it and will report back. I guess i lost VNC from switching.
                jefftse @sdetweil
                @sdetweil it did just crash with this
                0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                PM2 | App [mm:0] exited with code [1] via signal [SIGINT]
                PM2 | App [mm:0] starting in -fork mode-
                PM2 | App [mm:0] online
                0|mm | > magicmirror@2.29.0 start
                  sdetweil @jefftse
                  @jefftse different vnc setup on x11
                  i use ssh to avoid all this graphical crud.
                  see this topic on using other tools from Windows
                  https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
                    sdetweil @jefftse
                    what was before that line?
                      jefftse @sdetweil
                      @sdetweil 0|mm | MEMORY-ERROR: electron[3627]: GSlice: assertion failed: sinfo->n_allocated > 0
                      0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                        sdetweil @jefftse
                        @jefftse ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …) not electron problems…
                        I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…
                          jefftse @sdetweil
                          @sdetweil my setup is pretty simple and its freshly built yesterday. here is my config…
                          deleted
                            sdetweil @jefftse
                            @jefftse please use code marker around logs and config
                            paste the text into the forum editor, blank line above and below
                            select the text you pasted
                            push the </> button
                            as I said, I don’t SEE anything causing this…
                            but…
                            only way is to disable one module at a time to see if we can find it
                            add
                            disabled:true,
                            after the module: line
                              jefftse @sdetweil
                              @sdetweil I might have found the problem. it’s the backgroundslideshow. I disabled resizing and it hasn’t crashed yet. we will report again!
                              S karsten13K 2 Replies Last reply
                                sdetweil @jefftse
                                @jefftse cool…
                                • karsten13K
                                  karsten13 @jefftse
                                  @jefftse
                                  I deleted your config posted above because you published all your secrets in it …
                                    jefftse @karsten13
                                    @karsten13 Ha! thank you!!! i totally overlooked it!! appreciated it!
                                      jefftse @sdetweil
                                      my setup is pretty simple.
