    Electron quit periodically
    26 Posts 3 Posters 6.3k Views 4 Watching
      jefftse @sdetweil
      @sdetweil ok, i just did it and will report back. I guess i lost VNC from switching.
        jefftse @sdetweil
        @sdetweil it did just crash with this
        0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        PM2 | App [mm:0] exited with code [1] via signal [SIGINT]
        PM2 | App [mm:0] starting in -fork mode-
        PM2 | App [mm:0] online
        0|mm | > magicmirror@2.29.0 start
        0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
          sdetweil @jefftse
          @jefftse different vnc setup on x11
          i use ssh to avoid all this graphical crud.
          see this topic on using other tools from Windows
          https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
            sdetweil @jefftse
            @jefftse said in Electron quit periodically:
            what was before that line?
            J 1 Reply Last reply
              jefftse @sdetweil
              @sdetweil 0|mm | MEMORY-ERROR: electron[3627]: GSlice: assertion failed: sinfo->n_allocated > 0
              0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                sdetweil @jefftse
                @jefftse ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …) not electron problems…
                I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…
                  jefftse @sdetweil
                  @sdetweil my setup is pretty simple and its freshly built yesterday. here is my config…
                  deleted
                    sdetweil @jefftse
                    @jefftse please use code marker around logs and config
                    paste the text into the forum editor, blank line above and below
                    select the text you pasted
                    push the </> button
                    as I said, I don’t SEE anything causing this…
                    but…
                    only way is to disable one module at a time to see if we can find it
                    add
                    disabled:true,
                    after the module: line
                      jefftse @sdetweil
                      @sdetweil I might have found the problem. it’s the backgroundslideshow. I disabled resizing and it hasn’t crashed yet. we will report again!
                      S karsten13K 2 Replies Last reply
                        sdetweil @jefftse
                        @jefftse cool…
                        • karsten13K
                          karsten13 @jefftse
                          @jefftse
                          I deleted your config posted above because you published all your secrets in it …
                            jefftse @karsten13
                            @karsten13 Ha! thank you!!! i totally overlooked it!! appreciated it!
                              jefftse @sdetweil
                              my setup is pretty simple.
