    Electron quit periodically
    26 Posts 3 Posters 6.3k Views 4 Watching
      @jefftse ok, this is related to the Wayland compositor
      can you switch back to X11
      use the raspi-config app
      sudo raspi-config
      advanced
      Wayland
      X11
      you will have to reboot after that
      J 3 Replies Last reply
        jefftse @sdetweil
        @sdetweil ok, i just did it and will report back. I guess i lost VNC from switching.
          jefftse @sdetweil
          @sdetweil it did just crash with this
          0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          PM2 | App [mm:0] exited with code [1] via signal [SIGINT]
          PM2 | App [mm:0] starting in -fork mode-
          PM2 | App [mm:0] online
          0|mm | > magicmirror@2.29.0 start
          0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
            sdetweil @jefftse
            @jefftse different vnc setup on x11
            i use ssh to avoid all this graphical crud.
            see this topic on using other tools from Windows
            https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
              sdetweil @jefftse
              @jefftse said in Electron quit periodically:
              what was before that line?
              J 1 Reply Last reply
                jefftse @sdetweil
                @sdetweil 0|mm | MEMORY-ERROR: electron[3627]: GSlice: assertion failed: sinfo->n_allocated > 0
                0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                  sdetweil @jefftse
                  @jefftse ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …) not electron problems…
                  I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…
                    jefftse @sdetweil
                    @sdetweil my setup is pretty simple and its freshly built yesterday. here is my config…
                    deleted
                      sdetweil @jefftse
                      @jefftse please use code marker around logs and config
                      paste the text into the forum editor, blank line above and below
                      select the text you pasted
                      push the </> button
                      as I said, I don’t SEE anything causing this…
                      but…
                      only way is to disable one module at a time to see if we can find it
                      add
                      disabled:true,
                      after the module: line
                        jefftse @sdetweil
                        @sdetweil I might have found the problem. it’s the backgroundslideshow. I disabled resizing and it hasn’t crashed yet. we will report again!
                        S karsten13K 2 Replies Last reply
                          sdetweil @jefftse
                          @jefftse cool…
                          • karsten13K
                            karsten13 @jefftse
                            @jefftse
                            I deleted your config posted above because you published all your secrets in it …
                              jefftse @karsten13
                              @karsten13 Ha! thank you!!! i totally overlooked it!! appreciated it!
                                jefftse @sdetweil
                                my setup is pretty simple.
