    Electron quit periodically
    26 Posts 3 Posters 6.3k Views 4 Watching
      sdetweil @jefftse
      @jefftse different vnc setup on x11
      i use ssh to avoid all this graphical crud.
      see this topic on using other tools from Windows
      https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine
        sdetweil @jefftse
        @jefftse said in Electron quit periodically:
        0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        what was before that line?
        J 1 Reply Last reply
          jefftse @sdetweil
          @sdetweil 0|mm | MEMORY-ERROR: electron[3627]: GSlice: assertion failed: sinfo->n_allocated > 0
          0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
            sdetweil @jefftse
            @jefftse ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …) not electron problems…
            I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…
              jefftse @sdetweil
              @sdetweil my setup is pretty simple and its freshly built yesterday. here is my config…
              deleted
                sdetweil @jefftse
                @jefftse please use code marker around logs and config
                paste the text into the forum editor, blank line above and below
                select the text you pasted
                push the </> button
                as I said, I don’t SEE anything causing this…
                but…
                only way is to disable one module at a time to see if we can find it
                add
                disabled:true,
                after the module: line
                  jefftse @sdetweil
                  @sdetweil I might have found the problem. it’s the backgroundslideshow. I disabled resizing and it hasn’t crashed yet. we will report again!
                  S karsten13K 2 Replies Last reply
                    sdetweil @jefftse
                    @jefftse cool…
                    • karsten13K
                      karsten13 @jefftse
                      @jefftse
                      I deleted your config posted above because you published all your secrets in it …
                        jefftse @karsten13
                        @karsten13 Ha! thank you!!! i totally overlooked it!! appreciated it!
                          jefftse @sdetweil
                          my setup is pretty simple.
