    MMM-OpenWeatherMapForecast does not receive data from the Internet
    5 Posts 5 Posters 1.5k Views 5 Watching
    • K Offline
      Kostosso
      Good afternoon,
      My module MMM-OpenWeatherMapForecast does not receive data from the Internet.
      I installed MM on My Home Server in Docker. I used the karsten13/magicmirror image. Everything is set up and running great. In the default configuration, all modules worked except for the weather.
      I did not dwell on this, but installed my own configuration that had previously worked on Raspberry.
      All modules, including Google calendars, started up fine, but … But the weather forecast module does not work again.
      I checked that from the mm container the ping openweathermap.org
      command works fine.
      However, the mm logs contain the following entries:
      [OpenWeatherMapForecast] **ERROR** Error: socket hang up
      There are no more errors in the logs.
      Help me please. What is this error and how can it be removed?
      Thanks a lot in advance!
        Juliablack
        @Kostosso
        I a having a same things happens with me still not get solution.
        • F Offline
          Fogarty54
          thank you.
            Moss7
            thank you.
              Bentley96
              thank you for share this information…
