    Updated to 2.30.0 and Google Calendar no longer showing in 3rd-party module
    8 Posts 2 Posters 2.8k Views 2 Watching
      DarrenO 0
      I’ve just updated to v2.30.0 and the events of my Google Calendar are no longer showing via the MMM-MonthlyCalendar module.
      I noted the changes to the default Calendar module and added all options to my config.js file, setting applicable options as required, but the events are still not displayed.
      When I enable the default Calendar to be displayed (top_left), events show as expected.
        sdetweil @DarrenO 0
        @DarrenO-0 what is the setting for maximumEvents: in base calendar config?
        D 1 Reply Last reply
          DarrenO 0 @sdetweil
          @sdetweil Do you mean the maximumEntries setting, as I could not find a maximumEvents setting listed on the module’s config options?
          Not able to check right now, but I believe my setting for the maximumEntries setting is either 25 or 50, just based on what I recall seeing displayed by the default Calendar module when I uncommented the position: top_left setting.
            sdetweil @DarrenO 0
            @DarrenO-0 yes entries
            D 3 Replies Last reply
              DarrenO 0 @sdetweil
              @sdetweil OK, thanks.
              I’ll get back to you later on what exactly I have in my config.
                DarrenO 0 @sdetweil
                @sdetweil my maximumEntries setting is configured for 50, but I do have it in the general config{} section of the module.
                Should it be in the calendars[] section with the calendar’s URL?
                  DarrenO 0 @sdetweil
                  @sdetweil I’ve seen a similar post where you mentioned that you set the value for maximumEntries to 200, so I’ve now tried this and the calendar events show in the desired module.
                    sdetweil @DarrenO 0
                    @DarrenO-0 apply this fix
                    see
                    https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
