    MMM-Carousel - how to configure a module multiple times on the SAME page?
    29 Posts 6 Posters 16.3k Views 6 Watching
      sdetweil @reverendz
      @reverendz so those are the fonticon numbers for different icons
      all that stuff went in custom.css right?
      R 1 Reply Last reply
        reverendz @sdetweil
        @sdetweil Yep!
        They don’t show up anywhere. Which means I likely missed something major.
        I see the regular dots.
          sdetweil @reverendz
          @reverendz see the second link in my signature below on how to use the dev window
            reverendz @sdetweil
            Sure, I’ve been looking at that already.
            I figured out I had formatting error.
            So I fixed it and now I see icons.
            However, they’re still not clickable and do nothing. Fixed the formatting. Now I have a bunch of icons the previous poster mentioned.
            .MMM-page-indicator div.module-content div i:nth-child(1)::before {
                    font-size: 20px;
                    content: "\f073";
                    font-family: FontAwesome;
            .MMM-page-indicator div.module-content div i:nth-child(2)::before {
                    font-size: 20p;
                    content: "\f2c9";
            .MMM-page-indicator div.module-content div i:nth-child(3)::before {
                    font-size: 20px;
                    content: "\f1b9";
            .MMM-page-indicator div.module-content div i:nth-child(4)::before {
                    font-size: 20px;
                    content: "|f70c";
            .MMM-page-indicator div.module-content div i:nth-child(5)::before {
                    font-size: 20px;
                    content: "\f19d";
            .MMM-page-indicator div.module-content div i:nth-child(6)::before {
                    font-size: 20px;
                    content: " flea";
            .MMM-page-indicator div.module-content div i:nth-child(7)::before {
                    font-size:20px;
                    content: "\f03d";
            .MMM-page-indicator div.module-content div i:nth-child(8)::before {
                    font-size: 20px;
                    content: "\e5ac";
            .MMM-page-indicator div.module-content div i:nth-child(9)::before {
                    font-size: 20px;
                    content: "\f5ee";
            .MMM-page-indicator div.module-content div i:nth-child (10): :before {
                    font-size: 20px;
                    content: " f013";
              sdetweil @reverendz
              @reverendz I pasted your def into my custom.css and the icons showed and I can click them
                reverendz @sdetweil
                I don’t know what to do then. It’s 100% not working.
                I added buttons to a separate module in another region and those work. I can click on calendar events, but those items show up but aren’t clickable.
                        font-size: 20px;
                        content: "\f015";
                        font-size: 20px;
                        content: "\f04e";
                        font-size: 20px;
                        content: "\f04e";
                        font-size: 20px;
                        content: "\f04e";
                Can you provide a simple example like what I have above and how it ties to mmm-page-indicator?
                I can only think that this css is providing buttons but they’re not tied to something?
                S 2 Replies Last reply
                  sdetweil @reverendz
                  @reverendz all we did was change the icon over
                  the <a link in the html generated by page-indicator
                  you can open the developers window and look at the html
                  see the second link in my sig below
                  if you rename custom.css to done other name and reload tye MagicMirror page the circles will be back. do they work?
                    sdetweil @reverendz
                    @reverendz the what
                    css allows one to override/replace styles specified in an html document
                    MagicMirror is a html page
                    each modules content has a class name that matches the module name
                    in css the part before the {, is called the selector clause
                    is SELECTS the html elements the stuff inside the braces will be applied to.
                    a dot prefix means classname, class=
                    a pound sign prefix means id id=
                    no prefix means and html tag name
                    .MMM-page-indicator // element tree with modulename
                    div.module-content // a div tree with class module_content
                    div //with a div
                    i:nth-child(1)::before { // with an i (icon(1st in array of them) and use the ::before placement
                    if you oen the developers window you can see this
                      reverendz @sdetweil
                      @sdetweil Thank you for all your help.
                      I figured it out: I’m a dummy (or noob, take your pick).
                      I have run into the infamous “stacking” behavior.
                      Basically, the controls showed up, but were too close to something else and so even though they didn’t overlap visually, I couldn’t click on the buttons bc of proximity to another element.
                      Once I removed the element, it worked.
                      Thanks!
                      It’d be nice if there were some way to either set precedence or set a padding around each element so that I didn’t lose clickability when something is nearby.
                        sdetweil @reverendz
                        @reverendz zindex:1-99 will move it up the stack -1… etc will move it down the stack (that is how fullscreen_below works)
                          reverendz @sdetweil
                          @sdetweil Thank you again!
                          That did it!
                          I found this on the zindex and once I set it to 1, I was able to click the buttons.
                          Huzzah!
                          https://forum.magicmirror.builders/topic/4866/troubleshooting-changing-z-index-of-different-modules/4
                            sdetweil @reverendz
                            @reverendz zindex definitely takes negative numbers too
