    upgrading to latest MM version
    18 Posts 2 Posters 5.6k Views 2 Watching
      sdetweil @JMac
      @JMac to restore, you run the restore script . it takes parameters to tell it what to do
        JMac @sdetweil
        @sdetweil This is useful to know.
        Just add, I’ve had the same Issue as the last MM update, Calendar EXT3 is no longer pulling information from the base calendar module.
          sdetweil @JMac
          @JMac did you put on the fix
          see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
          J 2 Replies Last reply
            JMac @sdetweil
            @sdetweil I hadn’t seen that, I was about to update the module individually then do some digging on here to see if others had had the issue.
            do I use the list of commands in the link above, or the ones in this link?
            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
              JMac @sdetweil
              @sdetweil I’ve hit this at the 3 command,
              MagicMirror@raspberrypi:~/MagicMirror $ git switch _fix_clipping
              error: Your local changes to the following files would be overwritten by checkout:
              package-lock.json
              Please commit your changes or stash them before you switch branches.
              Aborting
                sdetweil @JMac
                @JMac rm package-lock.json
                J 1 Reply Last reply
                  JMac @sdetweil
                  @sdetweil do I run that in just the MagicMirror directory or the Calendar EXT3 module directory?
                  Below was your guidance from another of my topics with issues with this module, will it work?
                  (#)put package-lock.json back to last git clone state
                  git reset package-lock.json
                  (#) update the module
                  git pull
                  (#) rerun npm install with new code
                  npm install
                  had to put the # in () to stop the font going enormous
                    sdetweil @JMac
                    @JMac in the folder you are in!
                      JMac @sdetweil
                      MagicMirror@raspberrypi:~/MagicMirror $ rm package-lock.json
                      rm: cannot remove ‘package-lock.json’: No such file or directory
                      guessing I’m not doing this right
                        sdetweil @JMac
                        package-lock.json
                        Aborting
                        so it HAS to be there
                        ls and see if you see it
                        once you have it so it is NOT there
                        then do the switch again
                          JMac @sdetweil
                          getting this now,
                          Already on ‘_fix_clipping’
                          so assuming I can now restart mm?
                            sdetweil @JMac
                            @JMac correct, thats what the instructions say
                              JMac @sdetweil
                              @sdetweil restarted the MM with PM2, still no info being displayed in the CalendarEXT3 module.
                              edit to add, after letting the mirror settle down, it’s now pulling the data
                                sdetweil @JMac
                                @JMac Ext3 tries NOT to to flash on every update so the screen doesn’t flicker
                                he has parameters you can change to adjust the timing
                                the base cal module does take a little longer to process large calendars
