    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 33.9k Views 13 Watching
    • E
      Eli @HeikoGr
      @HeikoGr Thanks for coming back on this, appreciate!
      Unfortunately I have no luck with this either.
      I added the days option, also the examsDays.
      I still get only “Unterricht nach Plan - no changes, all according to plan” (and now also “no exams planned” - of course).
      I also added useClassTimeTable and showRegularLessons and showSubject - no change.
      It seems the school is hiding all info :)
      On the web interface I can see the schedule and the changes are visible in that schedule/table by stroke thru boxes for the specific lessons only, no comments in addition.
      But it would already help if I could see the table in my mirror.
      I tried without any options - I guess this is what brings up your screenshot - but same result.
      I assume the QR option should be no difference compared to user/password, right?
      I checked startup log and I see an error for this module now - no clue how to fix though…
      using latest version
      [2025-01-21 17:40:37.807] [ERROR] ERROR! Could not find main module js file for untis
      [2025-01-21 17:40:37.961] [ERROR] GitError: Error: spawn git ENOENT
      at ChildProcess._handle.onexit (node:internal/child_process:284:19)
      at onErrorNT (node:internal/child_process:477:16)
      at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      at Object.action (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1445:25)
      at PluginStore.exec (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1494:29)
      at C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1921:43
      at new Promise ()
      at GitExecutorChain.handleTaskData (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1919:16)
      at GitExecutorChain. (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1903:44)
      at Generator.next ()
      at fulfilled (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:52:24) {
      task: {
      commands: [ ‘remote’, ‘-v’ ],
      format: ‘utf-8’,
      parser: [Function: parseGetRemotesVerbose]
      If I use the debug option, I don’t get the above error, but I see:
      [2025-01-21 17:49:39.758] [LOG] Connecting socket for: MMM-Webuntis
      [2025-01-21 17:49:39.879] [INFO] [MMM-Webuntis] Node helper started
      [2025-01-21 17:49:39.984] [LOG] Sockets connected & modules started …
      [2025-01-21 17:49:40.077] [INFO]
      Ready to go! Please point your browser to: blabla
      [2025-01-21 17:49:47.299] [LOG] Create new calendarfetcher for url: https://calendar.googlblabla
      [2025-01-21 17:49:47.643] [INFO] [MMM-Webuntis] Successfully fetched data
      [2025-01-21 17:49:47.648] [INFO] updatenotification: Updater Class Loaded!
      [2025-01-21 17:49:47.652] [INFO] updatenotification: Checking PM2 using…
      [2025-01-21 17:49:47.659] [INFO] Checking git for module: MMM-Webuntis
      [2025-01-21 17:49:47.746] [INFO] updatenotification: [PM2] You are not using pm2
      [2025-01-21 17:49:47.759] [INFO] Checking git for module: MMM-Videoplayer
      [2025-01-21 17:49:47.836] [INFO] Checking git for module: MagicMirror
      [2025-01-21 17:49:48.305] [LOG] [MMM-Webuntis] ERROR for student: TypeError: Cannot read properties of undefined (reading ‘0’)
      H 1 Reply Last reply
      • H
        HeikoGr @Eli
        @Eli looks interesting
        • Why are the references to c:\ do you run magicmirror on windows?
        • what’s your way to install a new module? Do you use an module for this?
        E 1 Reply Last reply
        • H
          HeikoGr @Eli
          @Eli the module surely isn‘t running properly.
          I think the module MMM-Remote-Control tries to run git to get the npm module untis (which is required by my module) and has no success.
          But this is only a guess… could be totally wrong
          • O
            OliWer
            Hey,
            first let me say thanks for this module and your work!
            I have a similar issue as Eli:
            I only get info “all according to plan”. Even if I use “showRegularLessons”: true, I’m not getting anything else.
            in the startuplog I get this error for MMM-Webuntis:
            1|MagicMirror | [2025-01-22 09:02:11.901] [LOG] [MMM-Webuntis] ERROR for : TypeError: Cannot read properties of undefined (reading ‘0’)
            My config is as follow (removed real data from URL:
                                    module:"MMM-Webuntis",
                                    position:"bottom_left",
                                    header:"Emma Schule",
                                            students: [
                                                            title:"",
                                                            qrcode:"untis://setschool?url=ikarus.webuntis.com&school=12345&user=MyChild&key=Realkey&schoolNumber=123456789",
                                                            days:"10",
                                            showRegularLessons: true
            Any help is much appreciated, cause I find the idea really good!
            • H
              HeikoGr
              Note to myself: enhance error handling
              I did a clean reinstall on my machine and it worked with your config (and our qr code).
              Maybe the school doesn’t publish personal timetables?
              Can you try to set useClassTimetable: true,
              O 1 Reply Last reply
              • O
                OliWer @HeikoGr
                @HeikoGr
                added that to my config, but nothing changed.
                When I login to WebUntis via Browser, I can see a “My Timetable” (Mein Stundenplan). Not sure if there is a language difference or something.
                When I change the login information, I get error messages in the log, so the login itself seems to work and it gets data, even if it is just “all according to plan”. But not the data.
                What I also noticed is that there are two “My Timetable” in the web overview - one marked with beta.
                URL for non-beta: https://ikarus.webuntis.com/timetable-students-my/
                URL for beta: https://ikarus.webuntis.com/timetable-new/my-student
                URL for class: https://ikarus.webuntis.com/timetable-classes/
                So I think the school allowed the timetables you are asking for.
                Thanks for taking your time! Let me know if I can provide further information.
                • K
                  kurkarte
                  I am experiencing an issue with your MMM-WebUntis module. Despite following the setup instructions and providing the correct credentials, I am unable to log in. After testing, I believe the issue may be related to the presence of an umlaut (e.g., ö) and/or a whitespace in the school name.
                  My Setup:
                  MagicMirror Version: v2.29.0
                  MMM-WebUntis Module Version: Latest from repository
                  School Name: Contains an umlaut (ö) and a space
                  Login Method: My school uses iserv (iserv.de) for authentication. I do not have direct login credentials for the WebUntis portal but instead rely on the QR code provided by the school, which works in the official WebUntis app.
                  Configuration:
                  Here is an example of my configuration (with pseudodata replacing sensitive values):
                    module: "MMM-Webuntis",
                    header: "WebUntis Schedule",
                      students: [
                          title: "Student1",
                          qrcode: "untis://setschool?url=kadmos.webuntis.com&school=schulname with ö and space&user=username&key=ABC12345&schoolNumber=1234567",
                      days: 10,
                      mode: "verbose"
                  Error Messages:
                  Here are the errors I encountered:
                  When using the QR code:
                  [LOG]   ERROR for Student1: Error: Request failed with status code 400
                  Debugging with the check.js script
                  Error: getaddrinfo ENOTFOUND undefined
                  When manually entering the school name, username, and password instead of using qrcode:
                  Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}
                  Observations:
                  The QR code provided by webuntis contains the following (copied directly from the QR code content):
                  You see, the miscoding of the ö.
                  untis://setschool?url=example.webuntis.com&school=school name with � and space&user=username&key=ABC12345&schoolNumber=1234567
                  Notably:
                  The umlaut (ö) in the school name seems to cause issues.
                  There is also a whitespace in the school name.
                  Even when encoding the URL (e.g., using %C3%B6 for ö and %20 for the whitespace), I still encounter errors. I tried various configurations, including:
                  "school%20name%20with%20%C3%B6%20and%20space"
                  "schoolname with ö and space"
                  "schoolname+with+oe+and+space"
                  The QR code works perfectly in the WebUntis app, so I believe the credentials and format are correct. But my school uses iserv for authentication, meaning I do not have a standard WebUntis username and password.
                  • H
                    HeikoGr @kurkarte
                    @kurkarte you can try to search your school at https://webuntis.com/ . On the next site the school name in the URL could work if you replace empty spa es with „+“ signs.
                    • H
                      HeikoGr @OliWer
                      @OliWer i pushed a fix to github.
                      I was able to reproduce your error.
                      it should work now.
                      Reply Quote 2
                      • O
                        OliWer
                        Data is getting displayed now, will play around with it more later. Thank you very much!
                        • E
                          Eli @HeikoGr
                          @HeikoGr
                          Hi, I am running on an RPI normally. The test system is running on Windows, yes. But both show the same issue.
                          I install modules the standard way, fro a git console by pulling and npm install.
                          I also tried without remote control module - same issue.
                          • E
                            Eli @HeikoGr
                            @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
                            • E
                              Eli @Eli
                              @Eli said in MMM-Webuntis:
                              Small update: Seems to work only when debug mode is true…
                              • H
                                HeikoGr @Eli
                                @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
                                Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
                                H E 2 Replies Last reply
                                • H
                                  HeikoGr @HeikoGr
                                  @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
                                  • O
                                    OliWer
                                    Fix works for me, thanks for your work!
                                    • E
                                      Eli @HeikoGr
                                      @HeikoGr Sorry, for the delayed reply. You are acorrect, also works without debug mode. Seems there was some other hickup with the server and just next time I enabled debug again is was working again. So all fine.
                                      • H
                                        HeikoGr
                                        Achtung, ich habe eine neue Version veröffentlicht und dabei die Konfigurations Variablen umbenannt - es muss die config.js angepasst werden.
                                        Dafür habe ich jetzt aber auch eine Tabellenansicht implementiert:
                                        T 1 Reply Last reply
                                        • T
                                          thk @HeikoGr
                                          @HeikoGr
                                          Hallo & Vielen Dank für dieses tolle Modul!
                                          I do love the module and especially the grid-view.
                                          Is there a way to limit the number of hours displayed?
                                          By that the vertical height of the grid-view could be reduced, I suppose.
                                          I am asking because the generated table is exceeding the needed length to display the last hours of actual school, especially when there are weekdays in the grid which span across the whole day, like “kein Unterricht”.
                                          I see there is a grid-comlumn-end, but I struggle to use it properly.
                                          Thanks a lot in advance for any hint :-)
                                          • H
                                            HeikoGr @thk
                                            @thk thank you for you kind word. I was able to implement a new config option “maxGridLessons” which will cut-off everything below the configured lesson. A “… more” badge is placed if an actual lesson is hidden because of this cutoff.
                                            • 2 / 5
