    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 30.3k Views 13 Watching
      schmucke @HeikoGr
      @HeikoGr said in MMM-Webuntis:
      @schmucke at the moment this module asks explicitly for the „own“ timetable. So the error is absolutely because of the parents account. I will look, if i can get the students data out of an existing parents account.
      this would be nice! If i can help you to get any debuginfo, tell me.
      Thank you.
      • H Offline
        HeikoGr @schmucke
        @schmucke unfortunately I am not able to get the informations via the npm webuntis class from the untis API.
        Don’t your children have own accounts you can use? Or do they have an MS365 login? In this case you can use the qr code login method.
          schmucke @HeikoGr
          @HeikoGr no Problem.
          Of cource, they have a login - but they dont know they passwords… i just try to get the Information from the teachers. Thank you!
          • E Offline
            Eli @Eli
            It works on my mirror now. But I can only see the info page telling that all is according to plan. Unfortunately, the school is only striking the lessons in the schedule without any comment. But I can’t manage to display the students schedule. I log in with password, not qr. Maybe I miss a simple option?
            Maybe as a small improvement you might want to update your example config and add a few options+screenshots? Might help some of us…
            But great work! Thumbs up!
            • H Offline
              HeikoGr
              The default is to show only changes in the schedule.
              But you are right: a few more examples and screenshots are on my todo list!
              You can try this (look for showRegularLessons).
                          disabled: false,
                          module: "MMM-Webuntis",
                          header: "schedule for next 3 days",
                              students: [
                                      title: "children",
                                      qrcode: "untis://s",
                              days: 3,
                              showRegularLessons: true
              • E Offline
                Eli @HeikoGr
                @HeikoGr Thanks for coming back on this, appreciate!
                Unfortunately I have no luck with this either.
                I added the days option, also the examsDays.
                I still get only “Unterricht nach Plan - no changes, all according to plan” (and now also “no exams planned” - of course).
                I also added useClassTimeTable and showRegularLessons and showSubject - no change.
                It seems the school is hiding all info :)
                On the web interface I can see the schedule and the changes are visible in that schedule/table by stroke thru boxes for the specific lessons only, no comments in addition.
                But it would already help if I could see the table in my mirror.
                I tried without any options - I guess this is what brings up your screenshot - but same result.
                I assume the QR option should be no difference compared to user/password, right?
                I checked startup log and I see an error for this module now - no clue how to fix though…
                using latest version
                [2025-01-21 17:40:37.807] [ERROR] ERROR! Could not find main module js file for untis
                [2025-01-21 17:40:37.961] [ERROR] GitError: Error: spawn git ENOENT
                at ChildProcess._handle.onexit (node:internal/child_process:284:19)
                at onErrorNT (node:internal/child_process:477:16)
                at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                at Object.action (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1445:25)
                at PluginStore.exec (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1494:29)
                at C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1921:43
                at new Promise ()
                at GitExecutorChain.handleTaskData (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1919:16)
                at GitExecutorChain. (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1903:44)
                at Generator.next ()
                at fulfilled (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:52:24) {
                task: {
                commands: [ ‘remote’, ‘-v’ ],
                format: ‘utf-8’,
                parser: [Function: parseGetRemotesVerbose]
                If I use the debug option, I don’t get the above error, but I see:
                [2025-01-21 17:49:39.758] [LOG] Connecting socket for: MMM-Webuntis
                [2025-01-21 17:49:39.879] [INFO] [MMM-Webuntis] Node helper started
                [2025-01-21 17:49:39.984] [LOG] Sockets connected & modules started …
                [2025-01-21 17:49:40.077] [INFO]
                Ready to go! Please point your browser to: blabla
                [2025-01-21 17:49:47.299] [LOG] Create new calendarfetcher for url: https://calendar.googlblabla
                [2025-01-21 17:49:47.643] [INFO] [MMM-Webuntis] Successfully fetched data
                [2025-01-21 17:49:47.648] [INFO] updatenotification: Updater Class Loaded!
                [2025-01-21 17:49:47.652] [INFO] updatenotification: Checking PM2 using…
                [2025-01-21 17:49:47.659] [INFO] Checking git for module: MMM-Webuntis
                [2025-01-21 17:49:47.746] [INFO] updatenotification: [PM2] You are not using pm2
                [2025-01-21 17:49:47.759] [INFO] Checking git for module: MMM-Videoplayer
                [2025-01-21 17:49:47.836] [INFO] Checking git for module: MagicMirror
                [2025-01-21 17:49:48.305] [LOG] [MMM-Webuntis] ERROR for student: TypeError: Cannot read properties of undefined (reading ‘0’)
                • H Offline
                  HeikoGr @Eli
                  @Eli looks interesting
                  • Why are the references to c:\ do you run magicmirror on windows?
                  • what’s your way to install a new module? Do you use an module for this?
                  • H Offline
                    HeikoGr @Eli
                    @Eli the module surely isn‘t running properly.
                    I think the module MMM-Remote-Control tries to run git to get the npm module untis (which is required by my module) and has no success.
                    But this is only a guess… could be totally wrong
                    • O Offline
                      OliWer
                      Hey,
                      first let me say thanks for this module and your work!
                      I have a similar issue as Eli:
                      I only get info “all according to plan”. Even if I use “showRegularLessons”: true, I’m not getting anything else.
                      in the startuplog I get this error for MMM-Webuntis:
                      1|MagicMirror | [2025-01-22 09:02:11.901] [LOG] [MMM-Webuntis] ERROR for : TypeError: Cannot read properties of undefined (reading ‘0’)
                      My config is as follow (removed real data from URL:
                                              module:"MMM-Webuntis",
                                              position:"bottom_left",
                                              header:"Emma Schule",
                                                      students: [
        title:"",
        qrcode:"untis://setschool?url=ikarus.webuntis.com&school=12345&user=MyChild&key=Realkey&schoolNumber=123456789",
        days:"10",
                      Any help is much appreciated, cause I find the idea really good!
                      • H Offline
                        HeikoGr
                        Note to myself: enhance error handling
                        I did a clean reinstall on my machine and it worked with your config (and our qr code).
                        Maybe the school doesn’t publish personal timetables?
                        Can you try to set useClassTimetable: true,
                        • O Offline
                          OliWer @HeikoGr
                          @HeikoGr
                          added that to my config, but nothing changed.
                          When I login to WebUntis via Browser, I can see a “My Timetable” (Mein Stundenplan). Not sure if there is a language difference or something.
                          When I change the login information, I get error messages in the log, so the login itself seems to work and it gets data, even if it is just “all according to plan”. But not the data.
                          What I also noticed is that there are two “My Timetable” in the web overview - one marked with beta.
                          URL for non-beta: https://ikarus.webuntis.com/timetable-students-my/
                          URL for beta: https://ikarus.webuntis.com/timetable-new/my-student
                          URL for class: https://ikarus.webuntis.com/timetable-classes/
                          So I think the school allowed the timetables you are asking for.
                          Thanks for taking your time! Let me know if I can provide further information.
                          • K Offline
                            kurkarte
                            I am experiencing an issue with your MMM-WebUntis module. Despite following the setup instructions and providing the correct credentials, I am unable to log in. After testing, I believe the issue may be related to the presence of an umlaut (e.g., ö) and/or a whitespace in the school name.
                            My Setup:
                            MagicMirror Version: v2.29.0
                            MMM-WebUntis Module Version: Latest from repository
                            School Name: Contains an umlaut (ö) and a space
                            Login Method: My school uses iserv (iserv.de) for authentication. I do not have direct login credentials for the WebUntis portal but instead rely on the QR code provided by the school, which works in the official WebUntis app.
                            Configuration:
                            Here is an example of my configuration (with pseudodata replacing sensitive values):
                              header: "WebUntis Schedule",
                                students: [
                                    title: "Student1",
                                    qrcode: "untis://setschool?url=kadmos.webuntis.com&school=schulname with ö and space&user=username&key=ABC12345&schoolNumber=1234567",
                                days: 10,
                                mode: "verbose"
                            Error Messages:
                            Here are the errors I encountered:
                            When using the QR code:
                            [LOG]   ERROR for Student1: Error: Request failed with status code 400
                            Debugging with the check.js script
                            Error: getaddrinfo ENOTFOUND undefined
                            When manually entering the school name, username, and password instead of using qrcode:
                            Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}
                            Observations:
                            The QR code provided by webuntis contains the following (copied directly from the QR code content):
                            You see, the miscoding of the ö.
                            untis://setschool?url=example.webuntis.com&school=school name with � and space&user=username&key=ABC12345&schoolNumber=1234567
                            Notably:
                            The umlaut (ö) in the school name seems to cause issues.
                            There is also a whitespace in the school name.
                            Even when encoding the URL (e.g., using %C3%B6 for ö and %20 for the whitespace), I still encounter errors. I tried various configurations, including:
                            "school%20name%20with%20%C3%B6%20and%20space"
                            "schoolname with ö and space"
                            "schoolname+with+oe+and+space"
                            The QR code works perfectly in the WebUntis app, so I believe the credentials and format are correct. But my school uses iserv for authentication, meaning I do not have a standard WebUntis username and password.
                            • H Offline
                              HeikoGr @kurkarte
                              @kurkarte you can try to search your school at https://webuntis.com/ . On the next site the school name in the URL could work if you replace empty spa es with „+“ signs.
                              • H Offline
                                HeikoGr @OliWer
                                @OliWer i pushed a fix to github.
                                I was able to reproduce your error.
                                it should work now.
                                E 1 Reply Last reply Reply Quote 2
                                • O Offline
                                  OliWer
                                  Data is getting displayed now, will play around with it more later. Thank you very much!
                                  • E Offline
                                    Eli @HeikoGr
                                    @HeikoGr
                                    Hi, I am running on an RPI normally. The test system is running on Windows, yes. But both show the same issue.
                                    I install modules the standard way, fro a git console by pulling and npm install.
                                    I also tried without remote control module - same issue.
                                    • E Offline
                                      Eli @HeikoGr
                                      @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
                                      • E Offline
                                        Eli @Eli
                                        @Eli said in MMM-Webuntis:
                                        Small update: Seems to work only when debug mode is true…
                                        • H Offline
                                          HeikoGr @Eli
                                          @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
                                          Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
                                          H E 2 Replies Last reply Reply Quote 0
                                          • H Offline
                                            HeikoGr @HeikoGr
                                            @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
                                            • 1 / 5
