    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 33.9k Views 13 Watching
      RobertMuc @HeikoGr
      Hi @HeikoGr ,
      like your module.
      Unfortunately, I receive an error, when trying to start it.
      "/home/../MagicMirror/modules/MMM-Webuntis/check.js:18
                          const untis = new webuntis(s.school, s.username, s.password, s.server);
      TypeError: webuntis is not a constructor"
      Any idea how to fix that?
      Best,
      Robert
      H 1 Reply Last reply
      • H
        HeikoGr @RobertMuc
        Hello @RobertMuc,
        did this error occur when you run npm check?
        unfortunately i was not able to adopt the check.js file from https://github.com/r3wald/MMM-Webuntis
        R 1 Reply Last reply
        • H
          HeikoGr
          @RobertMuc did you run npm install? i was able to reconstruct your error message by uninstalling the npm package.
            RobertMuc @HeikoGr
            @HeikoGr Yes.
            I did fresh reinstall of MMM and all modules and then it suddenly worked… :-)
            Thanks for the support and thanks for the module.
            Best
            • E
              Eli @HeikoGr
              @HeikoGr really cool. I was about to start something like this, but even better now :) I’ll give it a try soon! Thanks!
              E 1 Reply Last reply
                schmucke
                Hello @HeikoGr ,
                i become the following error:
                [ERROR] [MMM-Webuntis] Error: Error: Can not find person in person array.
                    at WebUntisQR._otpLogin (/home/pi/MagicMirror/modules/MMM-Webuntis/node_modules/webuntis/dist/webuntis.js:957:13)
                    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                    at async WebUntisQR.login (/home/pi/MagicMirror/modules/MMM-Webuntis/node_modules/webuntis/dist/webuntis.js:1057:12)
                i think, the reason is, i just have a parent account, not a student account. is it possible to use the pearent account?
                Thank you
                • H
                  HeikoGr @schmucke
                  @schmucke at the moment this module asks explicitly for the „own“ timetable. So the error is absolutely because of the parents account. I will look, if i can get the students data out of an existing parents account.
                    schmucke @HeikoGr
                    @HeikoGr said in MMM-Webuntis:
                    this would be nice! If i can help you to get any debuginfo, tell me.
                    Thank you.
                    • H
                      HeikoGr @schmucke
                      @schmucke unfortunately I am not able to get the informations via the npm webuntis class from the untis API.
                      Don’t your children have own accounts you can use? Or do they have an MS365 login? In this case you can use the qr code login method.
                        schmucke @HeikoGr
                        @HeikoGr no Problem.
                        Of cource, they have a login - but they dont know they passwords… i just try to get the Information from the teachers. Thank you!
                        A 1 Reply Last reply
                        • E
                          Eli @Eli
                          It works on my mirror now. But I can only see the info page telling that all is according to plan. Unfortunately, the school is only striking the lessons in the schedule without any comment. But I can’t manage to display the students schedule. I log in with password, not qr. Maybe I miss a simple option?
                          Maybe as a small improvement you might want to update your example config and add a few options+screenshots? Might help some of us…
                          But great work! Thumbs up!
                          • H
                            HeikoGr
                            The default is to show only changes in the schedule.
                            But you are right: a few more examples and screenshots are on my todo list!
                            You can try this (look for showRegularLessons).
                                        disabled: false,
                                        module: "MMM-Webuntis",
                                        header: "schedule for next 3 days",
                                            students: [
                                                    title: "children",
                                                    qrcode: "untis://s",
                                            days: 3,
                                            showRegularLessons: true
                            • E
                              Eli @HeikoGr
                              @HeikoGr Thanks for coming back on this, appreciate!
                              Unfortunately I have no luck with this either.
                              I added the days option, also the examsDays.
                              I still get only “Unterricht nach Plan - no changes, all according to plan” (and now also “no exams planned” - of course).
                              I also added useClassTimeTable and showRegularLessons and showSubject - no change.
                              It seems the school is hiding all info :)
                              On the web interface I can see the schedule and the changes are visible in that schedule/table by stroke thru boxes for the specific lessons only, no comments in addition.
                              But it would already help if I could see the table in my mirror.
                              I tried without any options - I guess this is what brings up your screenshot - but same result.
                              I assume the QR option should be no difference compared to user/password, right?
                              I checked startup log and I see an error for this module now - no clue how to fix though…
                              using latest version
                              [2025-01-21 17:40:37.807] [ERROR] ERROR! Could not find main module js file for untis
                              [2025-01-21 17:40:37.961] [ERROR] GitError: Error: spawn git ENOENT
                              at ChildProcess._handle.onexit (node:internal/child_process:284:19)
                              at onErrorNT (node:internal/child_process:477:16)
                              at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                              at Object.action (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1445:25)
                              at PluginStore.exec (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1494:29)
                              at C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1921:43
                              at new Promise ()
                              at GitExecutorChain.handleTaskData (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1919:16)
                              at GitExecutorChain. (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:1903:44)
                              at Generator.next ()
                              at fulfilled (C:\MagicMirror\modules\MMM-Remote-Control\node_modules\simple-git\dist\cjs\index.js:52:24) {
                              task: {
                              commands: [ ‘remote’, ‘-v’ ],
                              format: ‘utf-8’,
                              parser: [Function: parseGetRemotesVerbose]
                              If I use the debug option, I don’t get the above error, but I see:
                              [2025-01-21 17:49:39.758] [LOG] Connecting socket for: MMM-Webuntis
                              [2025-01-21 17:49:39.879] [INFO] [MMM-Webuntis] Node helper started
                              [2025-01-21 17:49:39.984] [LOG] Sockets connected & modules started …
                              [2025-01-21 17:49:40.077] [INFO]
                              Ready to go! Please point your browser to: blabla
                              [2025-01-21 17:49:47.299] [LOG] Create new calendarfetcher for url: https://calendar.googlblabla
                              [2025-01-21 17:49:47.643] [INFO] [MMM-Webuntis] Successfully fetched data
                              [2025-01-21 17:49:47.648] [INFO] updatenotification: Updater Class Loaded!
                              [2025-01-21 17:49:47.652] [INFO] updatenotification: Checking PM2 using…
                              [2025-01-21 17:49:47.659] [INFO] Checking git for module: MMM-Webuntis
                              [2025-01-21 17:49:47.746] [INFO] updatenotification: [PM2] You are not using pm2
                              [2025-01-21 17:49:47.759] [INFO] Checking git for module: MMM-Videoplayer
                              [2025-01-21 17:49:47.836] [INFO] Checking git for module: MagicMirror
                              [2025-01-21 17:49:48.305] [LOG] [MMM-Webuntis] ERROR for student: TypeError: Cannot read properties of undefined (reading ‘0’)
                              • H
                                HeikoGr @Eli
                                @Eli looks interesting
                                • Why are the references to c:\ do you run magicmirror on windows?
                                • what’s your way to install a new module? Do you use an module for this?
                                • H
                                  HeikoGr @Eli
                                  @Eli the module surely isn‘t running properly.
                                  I think the module MMM-Remote-Control tries to run git to get the npm module untis (which is required by my module) and has no success.
                                  But this is only a guess… could be totally wrong
                                  • O
                                    OliWer
                                    Hey,
                                    first let me say thanks for this module and your work!
                                    I have a similar issue as Eli:
                                    I only get info “all according to plan”. Even if I use “showRegularLessons”: true, I’m not getting anything else.
                                    in the startuplog I get this error for MMM-Webuntis:
                                    1|MagicMirror | [2025-01-22 09:02:11.901] [LOG] [MMM-Webuntis] ERROR for : TypeError: Cannot read properties of undefined (reading ‘0’)
                                    My config is as follow (removed real data from URL:
                                                            module:"MMM-Webuntis",
                                                            position:"bottom_left",
                                                            header:"Emma Schule",
        students: [
        title:"",
        qrcode:"untis://setschool?url=ikarus.webuntis.com&school=12345&user=MyChild&key=Realkey&schoolNumber=123456789",
        days:"10",
                                    Any help is much appreciated, cause I find the idea really good!
                                    • H
                                      HeikoGr
                                      Note to myself: enhance error handling
                                      I did a clean reinstall on my machine and it worked with your config (and our qr code).
                                      Maybe the school doesn’t publish personal timetables?
                                      Can you try to set useClassTimetable: true,
                                      O 1 Reply Last reply
                                      • O
                                        OliWer @HeikoGr
                                        @HeikoGr
                                        added that to my config, but nothing changed.
                                        When I login to WebUntis via Browser, I can see a “My Timetable” (Mein Stundenplan). Not sure if there is a language difference or something.
                                        When I change the login information, I get error messages in the log, so the login itself seems to work and it gets data, even if it is just “all according to plan”. But not the data.
                                        What I also noticed is that there are two “My Timetable” in the web overview - one marked with beta.
                                        URL for non-beta: https://ikarus.webuntis.com/timetable-students-my/
                                        URL for beta: https://ikarus.webuntis.com/timetable-new/my-student
                                        URL for class: https://ikarus.webuntis.com/timetable-classes/
                                        So I think the school allowed the timetables you are asking for.
                                        Thanks for taking your time! Let me know if I can provide further information.
                                        • K
                                          kurkarte
                                          I am experiencing an issue with your MMM-WebUntis module. Despite following the setup instructions and providing the correct credentials, I am unable to log in. After testing, I believe the issue may be related to the presence of an umlaut (e.g., ö) and/or a whitespace in the school name.
                                          My Setup:
                                          MagicMirror Version: v2.29.0
                                          MMM-WebUntis Module Version: Latest from repository
                                          School Name: Contains an umlaut (ö) and a space
                                          Login Method: My school uses iserv (iserv.de) for authentication. I do not have direct login credentials for the WebUntis portal but instead rely on the QR code provided by the school, which works in the official WebUntis app.
                                          Configuration:
                                          Here is an example of my configuration (with pseudodata replacing sensitive values):
                                            header: "WebUntis Schedule",
                                              students: [
                                                  title: "Student1",
                                                  qrcode: "untis://setschool?url=kadmos.webuntis.com&school=schulname with ö and space&user=username&key=ABC12345&schoolNumber=1234567",
                                              days: 10,
                                              mode: "verbose"
                                          Error Messages:
                                          Here are the errors I encountered:
                                          When using the QR code:
                                          [LOG]   ERROR for Student1: Error: Request failed with status code 400
                                          Debugging with the check.js script
                                          Error: getaddrinfo ENOTFOUND undefined
                                          When manually entering the school name, username, and password instead of using qrcode:
                                          Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}
                                          Observations:
                                          The QR code provided by webuntis contains the following (copied directly from the QR code content):
                                          You see, the miscoding of the ö.
                                          untis://setschool?url=example.webuntis.com&school=school name with � and space&user=username&key=ABC12345&schoolNumber=1234567
                                          Notably:
                                          The umlaut (ö) in the school name seems to cause issues.
                                          There is also a whitespace in the school name.
                                          Even when encoding the URL (e.g., using %C3%B6 for ö and %20 for the whitespace), I still encounter errors. I tried various configurations, including:
                                          "school%20name%20with%20%C3%B6%20and%20space"
                                          "schoolname with ö and space"
                                          "schoolname+with+oe+and+space"
                                          The QR code works perfectly in the WebUntis app, so I believe the credentials and format are correct. But my school uses iserv for authentication, meaning I do not have a standard WebUntis username and password.
                                          • H
                                            HeikoGr @kurkarte
                                            @kurkarte you can try to search your school at https://webuntis.com/ . On the next site the school name in the URL could work if you replace empty spa es with „+“ signs.
                                            • 1 / 5
