    Unable to update modules
    20 Posts 3 Posters 7.3k Views 3 Watching
    • K Offline
      KumarTRD
      When attempting to update my magic mirror modules I get the following error messgae
      “pi@raspberrypi:~/MagicMirror/modules/MMM-Todoist $ git pull
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting”
      1)How do i solve this?
      2) What caused this “package-lock.json”?
      3) Anyway to remove this package permanently?
        @KumarTRD said in Unable to update modules:
        package-lock.json
        erase the package-lock.json and then git pull again, and npm install
        • K Offline
          KumarTRD @sdetweil
          @sdetweil I’ve tired to run rm package-lock.json but tells me there is no active directory.
            sdetweil @KumarTRD
            @KumarTRD you are in the module folder, right?
            cd  ~/MagicMirror/modules/MMM-Todoist
              this file is rebuilt each time by npm install
              but it is also included in the git repo for this module, it should not be
              • K Offline
                KumarTRD @sdetweil
                @sdetweil correct Sam but do I run the rm package-lock.json in the module folder or in cd /MagicMirror folder? I haven’t tried it in the module folder
                  sdetweil @KumarTRD
                  in the module folder, thats where you were when u got the error
                  • K Offline
                    KumarTRD @sdetweil
                    @sdetweil it looks like it’s present in all my modules because I get the same error when attempting to up those as well and my MagicMirror software as well. Any way to complete remove it ?
                      sdetweil @KumarTRD
                      @KumarTRD every module that has a package.json file and uses the step npm install will have a lock file.
                      but as I said, it should NOT have been included in the git package, because it produces this error, and prevents users from moving forward
                      • K Offline
                        KumarTRD @sdetweil
                        @sdetweil ok I’ll give it a try thanks for your assistance.
                        • K Offline
                          KumarTRD @sdetweil
                          @sdetweil any way to remove it manually?
                            sdetweil @KumarTRD
                            @KumarTRD to update MagicMirror itself, use my update script
                            see here
                            its a 2 step process… run once to understand what is going on and things u might have to do, run second time to DO the update
                              sdetweil @KumarTRD
                              yes, the rm command
                              • K Offline
                                KumarTRD @sdetweil
                                @sdetweil thanks for the script I’ll save it for later use and it worked thanks!!
                                  rmcon
                                  Resurrecting an old thread. Still fairly new to this stuff and trying to learn how to solve problems others have had before…
                                  I’ve got notifications that several modules need to be updated and I’m trying to get them done. Currently attempting to update MMM-Remote-Control using the instructions provided :
                                  cd ~/MagicMirror/modules/MMM-Remote-Control # adapt directory if you are using a different one
                                  git pull
                                  npm install # install (new) dependencies
                                  I am getting the same messages as the OP. I am in the module folder and tried running the rm command and I get this:
                                  ~/MagicMirror/modules/MMM-Remote-Control $ rm package-lock.json
                                  rm: cannot remove ‘package-lock.json’: No such file or directory
                                  I thought maybe that meant that I had deleted the package-lock and tried running the update command again, but keep getting the same message.
                                  I tried running the install script again, and when asked if I wanted to update (Y), I ended up with the same problem.
                                  Appreciate any guidance. Running MM v2.30.0 (installed using Sam’s scripts) on RPI 3B+.
                                    sdetweil @rmcon
                                    @rmcon post results of
                                    git status
                                    in the mmm-remote-control
                                    folder
                                      rmcon @sdetweil
                                      ~/MagicMirror/modules/MMM-Remote-Control $ git status
                                      On branch master
                                      Your branch is behind ‘origin/master’ by 8 commits, and can be fast-forwarded.
                                      (use “git pull” to update your local branch)
                                      (use “git add/rm …” to update what will be committed)
                                      (use “git restore …” to discard changes in working directory)
                                      modified: modules.json
                                      deleted: package-lock.json
                                      modified: package.json
                                      no changes added to commit (use “git add” and/or “git commit -a”)
                                        sdetweil @rmcon
                                        @rmcon ok the quick way
                                        git reset --hard HEAD
                                        then
                                        git pull
                                        Then
                                        npm install
                                          rmcon @sdetweil
                                          That worked! No idea what we just did, but the update went through and MM worked fine after reboot, to include the module,
                                          Sam, you’re a wizard as far as I’m concerned. Thanks for taking the time to assist us less savvy folks.
                                            sdetweil @rmcon
                                            @rmcon thanks, but no wizardry
                                            a little info
                                            we use a source code repository, that keeps track of every file change, add, delete, rename, whatever.
                                            on linux there is no hidden file attribute, like on Windows… but by convention, if a file or folder starts with a dot(.) then it is not shown unless explicitly requested
                                            git is the source code repository we all use (MM and the modules)
                                            it is called a distributed scm (source code mgmt) system, because whenever you have some of a repo, you have ALL of it from its start to now…
                                            you git clone to make a local copy (linked to the source of the clone)
                                            on linux that is stored in the .git folder (notice the .)
                                            it knows about every little change to any of the files… oh
                                            when you see them, that is called the ‘working copy’… may match the repo, might not
                                            so, we asked git, tell me the status of the working copy as compared to the repository (in the .git folder)
                                            and it said some file hadchanged and some file had been deleted.
                                            neither of those files (package.json or package-lock.json) affect the actual running of the module, they are part of the housekeeping, setup, installation…
                                            now, you said you were going to UPDATE cause the module had changed,
                                            so you don’t NEED those files as they exist(or don’t) , cause you are going to PULL a NEW copy of the repo to your system (repo and working copy)
                                            git provides commands to do lots of things,
                                            you can look thru the history of the repo, with git log and git history
                                            an important idea, is a pointer to the top of the last incorporated (committed) changes
                                            that term is called HEAD, the HEAD of the change tree…
                                            so, we asked git, please restore our working copy (and any potential additions (commits) to the repo BACK to the HEAD position
                                            AND reset all the working copy files too…
                                            –hard means and working copy
                                            ok, so NOW we have the working copy matching the repo state of the clone you did
                                            now lets ask to refresh the local repo with the repo copy that has changed
                                            that action is PULL the repo to us, and resynch
                                            (it doesn’t like it when the working copy doesn’t match its expectations, so we ‘forced’ it back to HEAD)
                                            now the PULL updates the repo, AND the working copy… phew… and it updated the two files it was unsure about before
                                            but who knows what the impact of the change are (the module author, did we look at any comments he might have made (no… not me!)…)
                                            so, lets just redo the node package managers view of the system
                                            npm install will recheck any locally added libraries (in node_modules folder)
                                            and do any pre/post install tasks defined in the package.json
                                            NOW we are file level up to date with the latest official repo
                                            AND we are runtime up to date
