    Difficulties with standard "clock" module
    4 Posts 2 Posters 959 Views 2 Watching
      rkorell Module Developer
      Dear team,
      I am not able to change the appearance of the (standard) clock module…
      Neither switching from digital to analog (I would prefer analog) nor any of the other options (e.g. clockBold or showWeek/showSuntime) is changing anything.
      Displayed is always the standard looking digital clock.
      Only working config parameter (so I’m pretty sure that I’m working at the right place) is position. if I change the position the clock behaves as expected.
      currently my code looks like:
      			module: "clock",
      			displayType: "analog",
      			analogSize: 300,
      			secondsColor: "red",
      			clockBold: true, // Remove the colon and bold the minutes to make a more modern look.
      			showWeek: true,
      			showSunTimes: true, // Turn off or on the section showing sunrise and sunset times (digital clock only)
      			lat: xxx.24127, // Latitude for sun/moon calculations.
      			lon: xxxx74403,
      Shown is (as mentioned above) standard digital clock without any additional information (no week, no sun and the digital colon is displayed…
      What I’m missing?
      Any hint highly appreciated…
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell you have the parameters in the wrong place
        all parms TO the module go in a
        config:{
        if there isn’t one , then the module uses its default value
        and you will have to add it
        see https://docs.magicmirror.builders/modules/configuration.html#example
        R 2 Replies Last reply
          Oh …
          did it again.
          shame on me!
          THANKS!
          Ralf
          • R rkorell has marked this topic as solved on
            can you enlighten me how I can use the provided different faces in the modules’ faces folder ? (face-001.svg - face-013.svg)
            • found by myself… sorry.
              Parameter analogFace …
