    Failed to install MM@2.30.0 to Raspberry Pi 3B+ node v18.19.0
    4 Posts 2 Posters 1.4k Views 2 Watching
      Macky
      Good day and hope everyone is doing well.
      May I request for assistance on how to move forward with the MM version that is compatible with my existing Raspberry Pi 3B+.
      I tried to reinstall MagicMirror2 to my old Raspberry Pi 3B+ using a Samsung 32GB micro SDHC Card, with reference to the latest available version indicated in the documentation @2.30.0.
      However, at some point it failed with errors as indicated below, which I captured from the generated log file …
      44 verbose pkgid magicmirror@2.30.0
      45 verbose cwd /home/miiprado/MagicMirror
      46 verbose Linux 6.6.62+rpt-rpi-v8
      47 verbose node v18.19.0
      48 verbose npm v9.2.0
      49 error code EBADENGINE
      50 error engine Unsupported engine
      51 error engine Not compatible with your version of node/npm: magicmirror@2.30.0
      52 error notsup Not compatible with your version of node/npm: magicmirror@2.30.0
      52 error notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
      52 error notsup Actual: {“npm”:“9.2.0”}
      53 verbose exit 1
      54 timing npm Completed in 7361ms
      55 verbose unfinished npm timer reify 1738135585445
      56 verbose unfinished npm timer reify:loadTrees 1738135585454
      57 verbose code 1
      I do appreciate anyone for kind assistance. Thank you in advance.
      S 2 Replies Last reply
        sdetweil @Macky
        @Macky see
        https://forum.magicmirror.builders/topic/19271/version-2-30-0-requires-updated-nodejs-warning-for-pi0w-installations?page=3
        if you run my upgrade script step 2 and change the word apply to force it will fix it for you
        or erase the MagicMirror folder and run the install script
          sdetweil @Macky
          @Macky also the doc says see the release
          info (link)
            Macky
            @sdetweil … Good day and your response / feedback is much appreciated. I’ll run through your recommendation and keep you posted in case encountered errors again.
            Have a great and safe day ahead. Cheers !!
