    MMM-GoogleBirthdaysProvider
    6 Posts 2 Posters 978 Views 2 Watching
      Sebi76 0
      Hello i used this module long time ago and it works. Now i want to install this on a new Raspi.
      They wont start
      [ERROR] MMM-GoogleBirthdaysProvider: API Helper error: API Error: Error: invalid_grant
      [2025-01-31 18:16:10.000] [ERROR] (node:12013) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading 'data')
          at /home/magicmirror/MagicMirror/modules/MMM-GoogleBirthdaysProvider/google-api-helper.js:41:45
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [2025-01-31 18:16:10.000] [ERROR] (node:12013) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      then i install it new. But when i want to generate a Token and i click on the Link an before the last Step:
      "MMM-GoogleBirthdaysProvider wants to access your Google Account " and i click on forward
      it comes this :
      Connection failed
      Firefox cannot connect to the server at localhost.
        sdetweil @Sebi76 0
        @Sebi76-0 it sounds like you use Firefox on another machine,
        Most of these Auth implementations are required to be done on the same machine, you can’t run them over ssh
          Sebi76 0
          Re: MMM-GoogleBirthdaysProvider
          No i don’t on a another Machine, i local on my Raspi4.
          mmm-googlebirthdaysprovider@0.2.0 token:generate
          node ./google-api-credentials/generate-auth-token.js
          Authorize the app by visiting this url: https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fcontacts.readonly&response_type=code&client_id=xxxxxxxx-4hmsenjojbirtdvt47f00a0btomqlhbe.apps.googleusercontent.com&redirect_uri=http%3A%2F%2Flocalhost
          Enter the code from that page here:
            sdetweil @Sebi76 0
            @Sebi76-0 OK, the end of that url shows http://localhost
            with no port number, implying port 80
            I don’t see the module doc talk setting callback uris on the Google page, oauthClient setup
            Typically the code requesting the oauth callback has to say where it’s ‘server’ is listening. (And you have to hard code it in the Google setup) I don’t see that setup in his code either
              Sebi76 0
              npm run token:generate
              I only followed what you see there
                sdetweil @Sebi76 0
                @Sebi76-0 I understand, but I think he left out some steps
                There is an issue open on the module github page since 2023 about this
